Bounding epsilon and convergence
Like Tree7Likes
  • 7 Post By shyam
Old   February 13, 2013, 06:06
Question Bounding epsilon and convergence
kirli is on a distinguished road
Hello Foamers.
I am kind of new in OpenFoam..
I am trying to run SimpleFoam turbulence simulation on a 3D geometry.
It is a kind of pipe with flow splitter. The fluid is water (one phase).
I got this kind of error:
DILUPBiCG: Solving for Ux, Initial residual = 1.96286e-14, Final residual = 1.96286e-14, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 3.56233e-14, Final residual = 3.56233e-14, No Iterations 0
DILUPBiCG: Solving for Uz, Initial residual = 1.38946e-13, Final residual = 1.38946e-13, No Iterations 0
DICPCG: Solving for p, Initial residual = 1, Final residual = 2.63715e+06, No Iterations 1001
time step continuity errors : sum local = 7.66448e+73, global = 1.60172e+66, cumulative = 1.60172e+66
[3] #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[3] #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[3] #2 in "/lib/libc.so.6"
[3] #3 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
What is the reason for the negative K?
Thanks
kirli is offline   Reply With Quote
Old   February 13, 2013, 08:39
Default Additional information
I believe that the problem is in the mesh.
I have made a CAD model (solidWorks) and then mesh it in salome. Import it in UNV format to OpenFoam
Old   June 5, 2013, 08:29
shyam prasad
shyam is on a distinguished road
Hi Kirli,
Most of us go through this problem of bounding epsilon or omega. Some of things which helped me are the following, which are taken from various threads of CFD-online.
check your mesh using the command checkMesh and look for non-orthogonality, if its between
a. 0 to 50 full corrected scheme is applicable,
b. 50 to 70 limited correction is required,
c. 70 to 80 stability possible, accuracy compromised,
d. above 80 stability very difficult to attain
For case b use the following settings in fvSchemes
gradSchemes
default faceLimited leastSquares 0.5;
laplacianSchemes
default Gauss linear limited 0.33;
snGradSchemes
default limited 0.33;
for case c and d I would suggest to revisit your mesh.
shyam is offline   Reply With Quote
Old   September 4, 2019, 07:47
Post
Manoj
Manoj Paithane is on a distinguished road
Originally Posted by shyam View Post
Hi Kirli,
gradSchemes
laplacianSchemes
snGradSchemes
what to do when mesh non orthogonality fall in between 70 to 80?
how to avoid K and epsilon bounding..?
Simulation show this type of iteration
Solving for fluid region fluid
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCGStab: Solving for Ux, Initial residual = 2.21117e-05, Final residual = 3.763e-08, No Iterations 1
DILUPBiCGStab: Solving for Uy, Initial residual = 0.000157765, Final residual = 1.72667e-08, No Iterations 1
DILUPBiCGStab: Solving for Uz, Initial residual = 0.00014488, Final residual = 2.0605e-08, No Iterations 1
DILUPBiCGStab: Solving for O2, Initial residual = 0.000226158, Final residual = 2.88741e-07, No Iterations 1
DILUPBiCGStab: Solving for H2O, Initial residual = 0.000183538, Final residual = 2.31311e-07, No Iterations 1
DILUPBiCGStab: Solving for h, Initial residual = 7.57334e-05, Final residual = 2.42469e-09, No Iterations 1
Min/max T:359.675 873.567
GAMG: Solving for p_rgh, Initial residual = 0.00126951, Final residual = 4.47571e-06, No Iterations 1
time step continuity errors : sum local = 5.48993e-09, global = 1.49437e-09, cumulative = 1.49437e-09
Min/max rho:42.5686 103.34
GAMG: Solving for p_rgh, Initial residual = 8.0525e-06, Final residual = 7.49119e-08, No Iterations 4
time step continuity errors : sum local = 9.41727e-11, global = 3.81731e-12, cumulative = 1.49819e-09
DILUPBiCGStab: Solving for epsilon, Initial residual = 8.46681e-06, Final residual = 6.31942e-09, No Iterations 1
bounding epsilon, min: -10.8933 max: 719259 average: 7597.29
DILUPBiCGStab: Solving for k, Initial residual = 3.15017e-05, Final residual = 5.1379e-08, No Iterations 1
Solving for solid region metal
DICPCG: Solving for h, Initial residual = 6.85466e-05, Final residual = 2.75706e-11, No Iterations 1
Min/max T:305.063 791.245
ExecutionTime = 8076.51 s ClockTime = 8290 s
Region: fluid Courant Number mean: 0.035771 max: 0.598896
Region: metal Diffusion Number mean: 2.45178e-05 max: 0.000784157
deltaT = 3.88385e-05
Time = 0.19064
Manoj Paithane is offline   Reply With Quote
Old   September 4, 2019, 10:58
Default Quick question
Vincent
vince_cfd is on a distinguished road
I'm running a turbulent chtMultiRegionFoam case and I can't reach convergence. I used the checkMesh tool and found:
Mesh non-orthogonality Max: 85.1202 average: 19.8936
*Number of severely non-orthogonal (> 70 degrees) faces: 25401.
Non-orthogonality check OK.
<<Writing 25401 non-orthogonal faces to set nonOrthoFaces
Face pyramids OK.
Max skewness = 3.6605 OK.
Coupled point location match (average 0) OK.
My total faces are 2335052, so about 1% of the faces are above the recommended value of 80 (and 70). Is it likely my convergence problems come from this, or is it alright to have some faces over the recommended value?
Greetings
vince_cfd is offline   Reply With Quote
Old   September 5, 2019, 01:58
Aashay Tinaikar
ARTisticCFD is on a distinguished road
I think the non-orthogonality check is passed. However, 85 seems to be quite skewed. See whether you can improve on it.
Could you give more details? Could you comment on the ranges of Courant number during your run?
ARTisticCFD is offline   Reply With Quote
Old   September 5, 2019, 05:40
Default Details
Vincent
check post below
Last edited by vince_cfd; September 5, 2019 at 09:57. Reason: higher quality post just below, thought my first post got lost
Old   September 5, 2019, 08:06
Default More Details
Vincent
Hey, thank you for your reply. I already answered this morning, but somehow my answer got lost in the aether.
Im already working on it, but Im not to sure if I can. The geometry is a spiral, so its destined to have some non-orthogonality.
Some details: metal temperature 70°C, cooling water temperature 30°C. Reynolds ranging from 7500-15000. Turbulence modeled with kOmegaSST.
Courant Number is set to max. 1.0, but reaches about 1.2 during the working part of the simulation. After approx. 0.04s the "good-looking" values start spiraling out of control and within 1-2 timesteps they print negative temperatures, negative rho and courant number arround 1e7.
Any ideas on what is happening? I can provide more information if needed.
Greetings
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 10:48
[swak4Foam] groovyBC issue - k and epsilon sagnikmazumdar OpenFOAM Community Contributions 24 March 1, 2015 08:16
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 06:24
Compressible epsilon blows up swahono OpenFOAM 10 November 26, 2010 06:38
Epsilon Convergence Trouble Carlos FLUENT 4 August 27, 2007 12:22
