DES with k-omega
Like Tree6Likes
  • 1 Post By Jane L
  • 4 Post By Jane L
  • 1 Post By Jane L
Old   June 25, 2012, 03:30
Default DES with k-omega
Jane L
Jane L is on a distinguished road
Hello!
For modeling an unsteady stall phenomenom, I'd like to use DES which uses k-omega in the near-wall region as RAS model. I just found the original DES with Spalart-Allmaras in OpenFOAM 2.1.0.
Before I start programming: Is there a method in OpenFOAM (maybe in .x or .dev) for DES with k-omega or did anyone of you implement this before?
Thanks in advance!
grossz likes this.
Jane L is offline   Reply With Quote
Old   November 1, 2012, 07:44
Jane L
Hi Foamers!
Finally I finished the programming of the turbulence models which you can find in the attached archive.
This file contains the source code for the tree turbulence models DES, DDES and IDDES with k-w as SGS model (instead od Spalart Allmaras).
The turbulence models where tested with OpenFOAM 2.1.1 and gave fair results for airfoils with very high angles of attack. Lift and drag was compared to experimental values given in the paper "Detached-Eddy Simulation of an airfoil at high angles of attack" by Garbaruk, Shur, Strelets and Travin. The averaged aberration in lift and drag for angles of attack of 45 and 60 degree was always below 10%.
All turbulence models include an extra function "RANSregion" which gives an indication of the RANS- and LES-content of each cell. This function can be visualized with paraview and has positive values in cells where the turbulence is fully modelled by the RANS model. The RANS model works in SGS mode in cells with values lower 0.
I hope that this will be helpful. In case you use it, I would be glad if you give some feedback.
best regards!
mrs206, Sunxing, auaries and 1 others like this.
Old   July 25, 2013, 12:27
Michael Sanderson
mrs206 is on a distinguished road
Hi Jane,
Thank you very much for writing these. They have been very useful in helping me to create a k-epsilon based DES model. I used the modifications proposed by Strelets for the turbulent length scale (i think this is the same method you have used?) but i have been unable to find a reference for the method you have used for the DDES model you have implemented.
Please could you point me in the right direction?
Many thanks,
Michael
mrs206 is offline   Reply With Quote
Old   July 26, 2013, 03:48
Jane L
Hi Michael.
The DDES model was developed and first described by: P. Spalart, S. Deck, M. Shur, K. Squires, M. Strelets, A. Travin.
in: A new version of detached-eddy simulation, resistant to ambiguous grid densities.
You can find the paper about IDDES via google:
M. Shur, P. Spalart, M. Strelets, A. Travin. A hybrid RANS-LES approach
with delayed-DES and wall-modelled LES capabilities
For might also have a look at:
http://www.sharcnet.ca/Software/Flue.../th/node91.htm
http://www.sharcnet.ca/Software/Flue...sec_iddes.html
I hope this helps! Kind regards
Sunxing likes this.
Old   May 7, 2014, 23:41
Zhiwei Zheng
killsecond is on a distinguished road
Hi Jane,
Have you tried to creat kOmegaSST based DES?
killsecond is offline   Reply With Quote
Old   December 4, 2018, 04:36
Sai Guruprasad Jakkala
saiguruprasad is on a distinguished road
I am trying to use k-Omega SST DES model in OpenFOAM 5.x. I am trying to simulate turbulent Couette Flow at Re_w=8600.
I have tried SA DES model and was able to get satisfactory results(used perturbUChannel to set initial condition). But when I use the kOmega SST DES model implemented in OF-5.x, there is no difference between the instantaneous and mean velcoity magnitude. They both become the same after few iterations. This results in the wrong calculation of Reynolds stress.
Am I doing something wrong in setting up the simulation?
saiguruprasad is offline   Reply With Quote
Old   November 8, 2021, 09:49
Sakun
Sakun is on a distinguished road
i am trying to run a simulation using SA-DES. i really really appreciate if you can guide me or the way you learnt.
Sakun is offline   Reply With Quote
Old   February 22, 2022, 11:47
Default kOmega-SST DDES
Boucetta Lahcene
B6_lacen is on a distinguished road
Hi
I'm really lost I'm looking for the implementation of the model kOmega-SST DDES in the versions of openFOAM V6.
Can you show me how you did it please
B6_lacen is offline   Reply With Quote
Boundary Conditions for k omega SST dancfd OpenFOAM Pre-Processing 0 June 10, 2011 00:25
Spanwise Length and Grid Refinement for SAS-SST, DES, and LES Josh CFX 5 October 14, 2010 20:47
How to use DES well? Daniel Main CFD Forum 0 October 26, 2008 06:59
DES ( SA+LES) vs DES ( kwSST+LES) for bluff body Phil Main CFD Forum 0 January 8, 2008 10:04
Problem with DES model mehul FLUENT 0 April 12, 2006 08:59
