trouble compiling an OF BC
Like Tree1Likes
  • 1 Post By mirko
Old   January 24, 2011, 18:06
Default trouble compiling an OF BC
Mirko Vukovic
mirko is on a distinguished road
I am building a boundary condition based on oscillatingFixedValue. I started off by copying oscillatingFixedValue in my local directory. Unfortunately, it does not compile. This is what I did so far:
  • Copied the files from .../src/finiteVolume/fields/fvPatchFields/derived/...
  • Removed oscillatingFixedValue.dep
  • Created Make/files & Make/options using the files in .../src/finiteVolume/Make/... as guides
wmake then gives the following error:
Making dependency list for source file oscillatingFixedValue/oscillatingFixedValueFvPatchFields.C
SOURCE=oscillatingFixedValue/oscillatingFixedValueFvPatchFields.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-40 -I/opt/OpenFOAM/OpenFOAM-1.7.1/src/finiteVolume/lnInclude     -I/opt/OpenFOAM/OpenFOAM-1.7.1/src/triSurface/lnInclude     -I/opt/OpenFOAM/OpenFOAM-1.7.1/src/meshTools/lnInclude -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-1.7.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/oscillatingFixedValueFvPatchFields.o
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-40 -I/opt/OpenFOAM/OpenFOAM-1.7.1/src/finiteVolume/lnInclude     -I/opt/OpenFOAM/OpenFOAM-1.7.1/src/triSurface/lnInclude     -I/opt/OpenFOAM/OpenFOAM-1.7.1/src/meshTools/lnInclude -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-1.7.1/src/OSspecific/POSIX/lnInclude   -fPIC Make/linux64GccDPOpt/oscillatingFixedValueFvPatchFields.o -L/opt/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt \
              -lOpenFOAM -liberty -ldl   -lm -o OpenFOAM.out
/usr/lib/../lib64/crt1.o: In function `_start':
(.text+0x20): undefined reference to `main'
Make/linux64GccDPOpt/oscillatingFixedValueFvPatchFields.o: In function `global constructors keyed to oscillatingFixedValueFvPatchFields.C':
oscillatingFixedValueFvPatchFields.C:(.text+0x1217): undefined reference to `Foam::fvPatchField<double>::constructpatchConstructorTables()'
oscillatingFixedValueFvPatchFields.C:(.text+0x1232): undefined reference to `Foam::fvPatchField<double>::patchConstructorTablePtr_'
oscillatingFixedValueFvPatchFields.C:(.text+0x1255): undefined reference to `Foam::fvPatchField<double>::constructpatchMapperConstructorTables()'
oscillatingFixedValueFvPatchFields.C:(.text+0x1270): undefined reference to `Foam::fvPatchField<double>::patchMapperConstructorTablePtr_'
oscillatingFixedValueFvPatchFields.C:(.text+0x1293): undefined reference to `Foam::fvPatchField<double>::constructdictionaryConstructorTables()'
oscillatingFixedValueFvPatchFields.C:(.text+0x12ae): undefined reference to `Foam::fvPatchField<double>::dictionaryConstructorTablePtr_'
oscillatingFixedValueFvPatchFields.C:(.text+0x130c): undefined reference to `Foam::fvPatchField<Foam::Vector<double> >::constructpatchConstructorTables()'
oscillatingFixedValueFvPatchFields.C:(.text+0x1327): undefined reference to `Foam::fvPatchField<Foam::Vector<double> >::patchConstructorTablePtr_'
oscillatingFixedValueFvPatchFields.C:(.text+0x134a): undefined reference to `Foam::fvPatchField<Foam::Vector<double> >::constructpatchMapperConstructorTables()'
oscillatingFixedValueFvPatchFields.C:(.text+0x1365): undefined reference to `Foam::fvPatchField<Foam::Vector<double> >::patchMapperConstructorTablePtr_'
oscillatingFixedValueFvPatchFields.C:(.text+0x1388): undefined reference to `Foam::fvPatchField<Foam::Vector<double> >::constructdictionaryConstructorTables()'
oscillatingFixedValueFvPatchFields.C:(.text+0x13a3): undefined reference to `Foam::fvPatchField<Foam::Vector<double> >::dictionaryConstructorTablePtr_'
oscillatingFixedValueFvPatchFields.C:(.text+0x1401): undefined reference to `Foam::fvPatchField<Foam::SphericalTensor<double> >::constructpatchConstructorTables()'
What else am I missing? I am attaching my files
Thanks,
Mirko
mirko is offline   Reply With Quote
Old   January 28, 2011, 19:02
Default Problem solved
Mirko Vukovic
I solved the problem by using the correct build tool. I was using
> wmake
Instead, as I am building a library, and not an executable, I should have used
> wmake libso
romant likes this.
Old   April 12, 2011, 10:36
xianghong wu
wendywu is on a distinguished road
> wmake
> wmake libso
hi,
I added a viscosity model into the viscosity model family, like other viscosity models, it is a folder " myViscosityModel" , in which there are "myViscosityModel.C" and "myViscosityModel.H". so I want to recompile the code, I used wmake, there are a lot of information, but there is one error, I can not find the problem.
I just read your message, Could you tell me if I could use " wmake libso " instead?
Thank you.
Wendy
wendywu is offline   Reply With Quote
Old   April 13, 2011, 11:23
Mirko Vukovic
Originally Posted by wendywu View Post
hi,
Thank you.
Wendy
Yes, you should compile it with `wmake libso' command.
Mirko
Old   April 14, 2011, 04:20
xianghong wu
Mirko
Thank you, I will try
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 08:43
compiling icoStructFoam error using OF1.7 mhassani OpenFOAM Installation 7 June 11, 2012 10:22
Help with KIVA4 source code compiling geothokar Main CFD Forum 0 September 3, 2010 06:40
OpenFOAM-1.5-dev compilation: OSspecific trouble gwierink OpenFOAM Installation 1 September 24, 2009 10:35
Trouble compiling on Debian Etch jkr OpenFOAM Installation 2 April 14, 2006 15:56
