A Modified Solver for Calculating LES Turbulence Budgets |
July 11, 2016, 21:24 |
Ehsan Asgari
Rep Power: 18 |
Hi Foamers,
Finally, I decided to modify a solver for calculating budgets of TKE transport. Currently, there is not any utility on the forum capable of calculating all the budgets, so I think it is a useful job to gather and put all the terms into action! I had help from some peoples, Alexey Matveichev who helped me understand LES classes, and a group of researchers at ETH who developped a useful utility, resLES, for LES post-processing. A modified version of their utility is developped for post-processing of averaged results. I have named the solver LESpimpleFoam, as its feature is to calculate LES TKE budgets. As the solver name screams, it has been developped from native solver pimpleFoam. Well, I will keep posting... |
July 12, 2016, 11:33 |
Ehsan Asgari
Rep Power: 18 |
All rights,
It is the solver plus an essential utility. I have added some comments to the main solver which should make it easy to understand the terms of TKE budgets. Both solver and utility have been compiled on OF 2.3.1. Only some important notes remain: 1-This implementation requires a well established averaged Velocity field (UMean) to exist in the time folder. The process of averaging of TKE budgets happens within the main solver and UMean is NOT updated within the code. So a reasonable averaged field must exist prior to beginning of simulation using LESpimpleFoam. To provide this averaged field, one can perform simulation for several flow-through time using the native pimpleFoam solver. 2-Three of TKE budgets are calculated afterwards the simulation through the postLES utilitiy provided. This utility requires averaged fields, including: UMean kMean UPrime2Mean turbDiffMean SGSDiffMean If any of the above fields would not exist, the utility will be terminated. So make sure to activate averaging process for them in the fieldAverage function object within controlDict. It is recommended to add all the defined variables in the main solver to the function object. Feel free to comment https://dl.dropboxusercontent.com/u/...pleFoam.tar.gz https://dl.dropboxusercontent.com/u/...postLES.tar.gz Enjoy. Syavash Last edited by syavash; August 7, 2016 at 12:38. |
July 12, 2017, 12:56 |
#3 | |
The links posted above do not contain any files. It would be very helpful if you could post the links again. Thank you, sidworks |
August 25, 2017, 12:04 |
Ehsan Asgari
Rep Power: 18 |
OK,
I would need more requests to reupdate the files since I have to dig out my old docs. Syavash |
August 26, 2017, 09:14 |
Jack
Rep Power: 11 |
I would also like to see the files! Many thanks.
September 5, 2018, 04:07 |
amigoo
Rep Power: 16 |
Hi Syavash,
Are the files available? It would be nice if you can find them and update the link[/QUOTE] |
September 5, 2018, 16:29 |
#8 | |
Ehsan Asgari
Rep Power: 18 |
Hi Joseee, I have started uploading my files on my github repository. I guess I will eventually upload that solver. You can remind me in a week or so if I would not already uploaded it. https://github.com/syavash20/TurbLab Kind Regards, Syavash Last edited by syavash; September 6, 2018 at 03:33. |
September 17, 2018, 22:57 |
#9 |
Rep Power: 12 |
Hi syavash,
A kind reminder to see if we could get access to the turbulent kinetic energy budget calculation method that you implemented. |
September 19, 2018, 05:14 |
#10 | |
Ehsan Asgari
Rep Power: 18 |
Hi Uyan, Thanks for the remind and sorry for the delay. I will upload the solver and the postLES utility by tomorrow. I already have the main .C files of both but intend to upload the whole directory. Regards, Syavash |
September 19, 2018, 13:12 |
#11 |
Ehsan Asgari
Rep Power: 18 |
Hi everyone,
I could finally upload both the LESpimpleFoam solver and the postLES utility on my github repository: https://github.com/syavash20/TurbLab Please read the provided ReadMe file before use. Regards, Syavash |
November 2, 2018, 00:44 |
#12 | |
adam oler
November 2, 2018, 04:25 |
#13 | |
Ehsan Asgari
Rep Power: 18 |
Dear Adam, Your welcome. It would be great if you share the version of the LESpimpleFoam solver you modified for ver. 6. Regards, Syavash |
September 30, 2019, 04:56 |
#14 |
Andrea
Rep Power: 16 |
Hello, this might be relevant to the topic:
I needed to calculate the resolved turbulent kinetic energy and its dissipation rate at runtime so I have modified pimpleFoam in order to do this. Since I was there, I also added a field representing the fraction of the resolved TKE to the total TKE, i.e.: LESResIndex = k_resolved/(k_resolved+k_sgs) The solver can be downloaded here I have tested the code on a channel flow at Re_t=395 and the results were ok, nevertheless any feedback is welcome Andrea |
November 29, 2019, 01:07 |
#15 | |
Maximus Arelius
Rep Power: 9 |
If you see Pope's Ten questions concerning LES, to calculate the LES index shouldn't the quantities Ksgs and Kres be averaged in time and them the ratio of them (averaged Ksgs and Kres) be used to calculate LESResIndex. Your code is calculating the instantaneous value, shouldn't it be doing that using averaged values? Please correct me if I am wrong!
-- 🃏Maximus🃏 |
November 29, 2019, 06:20 |
#16 |
Andrea
Rep Power: 16 |
indeed in Pope's paper it looks like it is using the time-averaged resolved and subgrid TKE to evaluate the index. In my solver I did not do that, so the index value refers to the instantaneous ratio of k_res to k_tot. If I am not mistaken (I did not have time to go through the paper properly) this is what Celik et al, Index of Resolution Quality for Large Eddy Simulations (2005) are doing (Equation 9 in the paper). You could then use fieldAverage to evaluate a time-averaged value of the index calculated by my code. I guess this would be equivalent to the definition in Pope's paper but for a term related to the covariance of k_res and k_sgs (don't quote me on this though, I did not do the math). On the other hand, this should not make a big difference since the entire definition of the index is based on assumptions and therefore is only going to provide a rough estimate of how good your resolution is. Andrea |
May 29, 2021, 16:02 |
#17 | |
Rep Power: 6 |
Hi Syavash or anyone else who has an answer! Where did you find the derivation for the TKE Budget equation you are using? I'm only aware of the equation in Pope's book page 125 (eq 5.132) which is a physical one. What I don't understand is how this equation is modified to become a resolved-TKE transport equation (that is the field U-UMean), therefore including the SGS tensor terms. Thanks Agave |
PEMFC model with FLUENT | brahimchoice | FLUENT | 22 | April 19, 2020 16:44 |
Floating Point Exception Error | nyox | FLUENT | 11 | November 30, 2018 13:31 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 17:08 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 01:01 |
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 10:52 |
