slip & noslip boundary condition for dynamic mesh, how to implement?
Like Tree2Likes
  • 2 Post By JNSN
Old   February 17, 2016, 04:24
Default slip & noslip boundary condition for dynamic mesh, how to implement?
Olaf Schiemann
oschi is on a distinguished road
how would I implement a slip and noslip boundary condition on a dynamic, deforming mesh?
I have a small test case, which models the water flow inside a "bouncing cube", a rectangular mesh growing/shrinking periodically in the horizontal/vertical direction.
The motion of the walls is not transferred to the water, whatever boundary condition I use (slip, no slip, fixedValue (0 0 0 )).
Is it possible to implement a boundary condition that takes the boundary velocity into account and lets me set the relative fluid velocity, so that (0 0 0) translates into a "real" noslip condition?
I am testing with rhoPimpleDyMFoam of OpenFOAM 2.4.0. You will definitely help me as well, if you know of a solution using another solver or OpenFOAM version.
Greetings
Olaf
oschi is offline   Reply With Quote
Old   February 18, 2016, 05:18
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
For dynamic mesh cases a no-slip wall is defined as movingWallVelocity, have a look here:
http://cfd.direct/openfoam/user-guide/boundaries/
Also have a look at the tutorials.
I would not know is there is a slip velocity for a moving wall.
Regards,
Tom
tomf is offline   Reply With Quote
Old   February 18, 2016, 13:47
Olaf Schiemann
Thank you Tom,
but movingWallVelocity does not work correctly. I think it is using only the wall motion at the first simulation time step and assumes that the wall motion doesn't change.
I have attached a tiny modification of the compressible/pimpleDyMFoam/movingCone tutorial. The only change I have made is a time-dependent table for the movingWall velocity in 0/pointMotionUx:
boundaryField
    movingWall
        //type            uniformFixedValue;
        //uniformValue    constant 1;
        uniformValue    table (
          (0. 1.)
          (0.00149 1.)
          (0.00151 -1.)
          (0.003 -1.)
If you run "blockMesh && pimpleDyMFoam" on this case, you will see, that the fluid attached to the movingWall is always flowing at (1 0 0) m/s, although it must change to (-1 0 0) m/s after 1.51ms.
Do you know, how to correct this bug in movingWallVelocity? Or is it a bug in the dynamicMotionSolver?
Greetings
Olaf
Old   February 19, 2016, 04:54
JNSN's Avatar
Jan
JNSN is on a distinguished road
Hi Olaf,
in the attached case you have set the boundary condition for U to fixedValue. This is wrong. If you change to movingWallVelocity, then the velocities at the wall are updated according to the mesh motion, i.e. changing from 1 to -1.
Best regards,
Jan
JNSN is offline   Reply With Quote
Old   February 19, 2016, 05:31
Olaf Schiemann
Hi Jan,
you are absolutely right.
I am sorry, I have tested so many settings that I got confused. movingWallVelocity works fine for both pimpleDyMFoam and rhoPimpleDyMFoam.
Another question:
My confusion started, because pointMotionUx translates only the boundary, not the internal points, if I use groovyBC to express arbitrary, time dependent motions:
// 0/pointMotionUx:
boundaryField
    movingWall
        type        groovyBC;
        valueExpression "toPoint(1)"; //"toPoint(cos(pi*time()/0.003))";
This problem is still around, independent from the (now solved) relative fluid velocity question.
Do you know, why a groovyBC does not allow to move the internal mesh points, whereas e.g. uniformFixedValue works correctly?
Greetings
Olaf
Old   February 19, 2016, 08:30
JNSN's Avatar
Jan
Hi Olaf,
I have no experience with groovyBC. Maybe codedFixedValue does what you want. I have used it once and it worked well. See the example code for a sinusodial motion in x-direction:
    movingWall
        type codedFixedValue;
        value uniform 0;
        redirectType rampedFixedValue;
        code
            scalar t = this->db().time().value();
            scalar om = 0.5;
            scalar a = -1.;
            //Info << "movingWall: " << a*sin(om*t) << endl;
            operator==(a*sin(om*t));
Best regards,
Jan
vsammartano and YUGU like this.
Old   May 21, 2019, 05:33
liliu
YUGU is on a distinguished road
Hi, Jan
Do you have any ideas about how to add a flowRate to moving boundary?
Best,
Yu
YUGU is offline   Reply With Quote
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
turbineSiting tutorial: slip condition at top boundary gives unexpected result letzel OpenFOAM 0 June 6, 2014 06:25
Implement constant heat flux boundary condition new_at_this Main CFD Forum 2 April 7, 2012 00:35
