Problem of calculating divergence due to wrong boundary vaule of finite area mesh
Like Tree1Likes
  • 1 Post By lzhou
Old   April 24, 2015, 09:25
Default Problem of calculating divergence due to wrong boundary vaule of finite area mesh
Lu ZHOU
lzhou is on a distinguished road
I am using Finite area method to simulate the scour on river bed.
When calculating the divergence of an "areaVectorField" Qsa (fac::div(Qsa)), I found out that the program suppose the Qsa value at the boundary of the finite area mesh is (0 0 0), even though I set the boundary condition of Qsa as zeroGradient in file 0/Qsa. So the divergence calculated is not correct at the boundary of finite area mesh.
I would like to ask how to solve this problem ? Or is there a way to get the label of the face cell at the boundary of the finite area mesh and correct it ? Thanks !
Lu ZHOU
scleakey likes this.
lzhou is offline   Reply With Quote
Old   June 17, 2015, 10:00
Tian Tang
tiat is on a distinguished road
HI LU,
I am having the same problem as you described and I wonder have you figured out a solution yet? Thanks!
tiat is offline   Reply With Quote
Old   June 18, 2015, 06:10
Lu ZHOU
I asked someone else and the answer I got was that the boundary of finite area method did obey the zeroGradient boundary condition. So I think the problem is when we use vsm.mapToSurface(), only the internal field is mapped but not the boundary values. So I set the boundary value by myself because in my case I just need to set the boundary value to zero.
I would like to find someway to modify the boundary values as a function in finite volume mesh like U.correctBoundaryCondition() but I couldn't find one. If you get some better ways to solve this please let me know.
Best regards !
Lu
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 11:58
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 09:52
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
