[TUTORIAL] Implementing porous zones to PisoFOAM
Like Tree5Likes
  • 5 Post By ssss
Old   September 1, 2014, 14:04
Default [TUTORIAL] Implementing porous zones to PisoFOAM
anonymous
ssss is on a distinguished road
  1. Run the following to make a copy of the original pisoFoam
cp -r $WM_PROJECT_DIR/applications/solvers/incompressible/pisoFoam/ $WM_PROJECT_USER_DIR/applications/solvers/my_pisoFoamPOROUS
  • Change names
cd $WM_PROJECT_USER_DIR/applications/solvers/my_pisoFoamPOROUS
mv pisoFoam.C my_pisoFoamPOROUS.C
  • Change link options so that we can compile
Change Make/files to
my_pisoFoamPOROUS.C
EXE = $(FOAM_USER_APPBIN)/my_pisoFoamPOROUS
First line says which is the main file for the compilation, second line tells the compiler where to save the new solver and the new of the new solver (the name you will use to call the new solver)
Change Make/options to:
EXE_INC = \
    -I$(LIB_SRC)/turbulenceModels/incompressible/turbulenceModel \
    -I$(LIB_SRC)/transportModels \
    -I$(LIB_SRC)/transportModels/incompressible/singlePhaseTransportModel \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/meshTools/lnInclude
EXE_LIBS = \
    -lincompressibleTurbulenceModel \
    -lincompressibleRASModels \
    -lincompressibleLESModels \
    -lincompressibleTransportModels \
    -lfiniteVolume \
    -lmeshTools
The \ tells the compiler there is a new line, and we added meshTools library in order to access the mesh object during runTime
  • Remove old compiled files
rm -rf Make/linux* pisoFoam.dep
  • Create new file createPorousZones.H
touch createPorousZones.H
This will create the file. Then add to it the following
    porousZones pZones(mesh); //creates the object porousZones from the mesh object
    Switch pressureImplicitPorosity(false);// Sets the pressure solver as explicit
  • Open my_pisoFoamPOROUS.C and add this before the main function
#include "porousZones.H" // object porousZone
int main(){
This is needed to have the porousZones constructor
  • Add the following after the main function
int main(){
    #include "CourantNo.H"
    #include "createPorousZones.H"
    // PISO LOOP
This will create the object porousZones as stated before
  • Inside the PISO corrector add the following
//PISO corrector
            fvVectorMatrix UEqn
                fvm::ddt(U)
              + fvm::div(phi, U)
              + turbulence->divDevReff(U)
           pZones.addResistance(UEqn);
  • Compile the solver
wmake
  • The solver is completed now you need to put inside your constant/ folder a file with name porousZones where you will write your porous properties. You can get one from
    $WM_PROJECT_DIR/tutorials/incompressible/porousSimpleFoam/angledDuctExplicit/constant/
  • To set a porous zone inside your mesh
Run
topoSet
with your topoSetDict, example setting a box:
|  \\    /   O peration     | Version:  2.1.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      topoSetDict;
actions
        name    porosity;
        type    cellSet;
        action  new;
        source  boxToCell;
        sourceInfo
           box (10 0 0) (35 2 0.5); //box (minVertex) (maxVertex)
After that run
setsToZones
because we have selected only Cells, but the solver needs zones.
At last call
my_pisoFoamPOROUS
inside your case folder, and it should hopefully run with porous zones.
Hope you found it helpful.
wyldckat, abhi22, Joe Wang and 2 others like this.
ssss is offline   Reply With Quote
Old   October 30, 2016, 22:58
Anirudh Kulkarni
Tempest is on a distinguished road
I get the error "fatal error: porousZones.H: No such file or directory
compilation terminated".
What can be the possible reasons?>
Tempest is offline   Reply With Quote
Old   November 2, 2016, 18:16
Wouter van der Meer
wouter is on a distinguished road
Hello
To make this work you either need to have the same version as OF that is used by ssss or get the right name of the include file for porousSimpleFoam.
#include "IOporosityModelList.H" in stead of
This change also needs to be made in the code exchange porousZones by IOporosityModelList.
( I tried this with OF-dev and I had to change the tutorial also quite a lot because there are links to files that I could not copy)
Hope this helps
Wouter
wouter is offline   Reply With Quote
Old   November 2, 2016, 22:00
Anirudh Kulkarni
Yeah I figured that out.
To add porous zones in any solver:
1. Create createPorousZones.H file.
Add
IOporosityModelList pZones(mesh); //creates the object porousZones from the mesh object
2. Add #include "IOporosityModelList.H" in header of .C
#include "createPorousZones.H" in main prog.
3. Add pZones.addResistance(UEqn); after the governing equations.
Peace!
Old   November 25, 2016, 22:44
Anirudh Kulkarni
Originally Posted by wouter View Post
Hello
Hope this helps
Wouter
Is it necessary to multiply porosity explicitly in the Ueqn as given in various articles on porous media or OF takes care of it when you define darcyForchheimer type fvOptions?
Old   September 26, 2017, 13:55
Ashish Magar
ashishmagar600 is on a distinguished road
Hello everyone.
Is there a similar method for including cellzones inside a solver, maybe icofoam or simplefoam??
ashishmagar600 is offline   Reply With Quote
Old   July 31, 2018, 15:23
naufal
mnaufalazwar is on a distinguished road
what is the different if i want to implement porous zones to icoFoam? thanks
mnaufalazwar is offline   Reply With Quote
piso, pisofoam, porous
Direction vectors and adsorption in porous zones Toplaa FLUENT 0 August 16, 2013 15:22
Wall between porous zones roupcik FLUENT 0 April 15, 2013 08:10
Wall between porous zones roupcik FLUENT 1 April 15, 2013 08:06
Wall between porous zones roupcik Main CFD Forum 1 April 15, 2013 08:05
Help:What's wrong with my porous zones setting!!? jjw FLUENT 2 August 26, 2005 06:16
