writing radiation source term in fireFoam
Like Tree1Likes
  • 1 Post By jherb
Old   January 9, 2014, 09:00
Default writing radiation source term in fireFoam
Marshak is on a distinguished road
In fireFoam solver, the radiation source term is included in hs equation ..file YhsEqn.H as follows:
fvScalarMatrix hsEqn
fvm::ddt(rho, hs)
+ mvConvection->fvmDiv(phi, hs)
- fvm::laplacian(turbulence->alphaEff(), hs)
DpDt
+ dQ
+ radiation->Shs(thermo)
+ parcels.Sh(hs)
+ surfaceFilm.Sh()
I want to write out the radiation source term 'radiation->Shs(thermo)'. Can someone tell what changes should I make in the fireFoam solver to write the radiation source term.
Marshak is offline   Reply With Quote
Old   January 9, 2014, 19:03
Joachim Herb
jherb is on a distinguished road
You have to add a new field (probably in createFields.H) which is written every timestep. Then copy radiotion-Shs(thermo) to this field before the timestep is finished.
atulkjoy likes this.
jherb is offline   Reply With Quote
Old   January 13, 2014, 18:49
赵庆良
zqlhzx is on a distinguished road
Hi Marshak,
I have the some problem with you!I also want to write out the radiation source term 'radiation->Shs(thermo)'.Have you solved it?If it is solved,could tell how to do it?Thanks in advance!
zqlhzx is offline   Reply With Quote
Old   January 13, 2014, 19:49
'jhreb' I tried with createfields.H but it is not working...
Old   January 14, 2014, 05:39
Joachim Herb
Here is what I did in a comparable case:
Add a new field to createFields.H
    volScalarField Shs(
        IOobject
            "Shs",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::AUTO_WRITE // this tells OpenFOAM to store the field after each timestep
        dimensionedScalar("zero", dimensionSet(0, 0, 1, 0, 0), 0.0) // here you have to set the correct dimensions of your field
Then in YhsEqn.H, either after hsEqn.solve() or thermo.correct() add the following:
if (pimple.finalIter())
            Shs = radiation->Shs(thermo);
The whole code is not tested. But it should be a starting point.
Old   January 16, 2014, 07:19
Default related question in another thread
dzi
dzi is on a distinguished road
fyi I put a related radiation question to another thread
http://www.cfd-online.com/Forums/ope...blem-5.html#99
thanks dirk
dzi is offline   Reply With Quote
Old   January 16, 2014, 10:51
Shs() in radiation::radiationModel is defined as fvScalarMatrix. How can a fvScalarmatrix be written as a volScalarField?
Old   January 17, 2014, 12:03
Joachim Herb
You are right. I my case what I really used was something like
rHS1 = fvc::reconstruct
                  - ghf*fvc::snGrad(rho)
                ) * mesh.magSf()
But here there is a quite simple solution (OpenFOAM version 2.2.2):
        Info<< radiation->Sh(thermo);
I guess in your version its ->Shs(thermo). This will output the coefficients of the matrix. If there are only diagonal elements (as it looks like), then you can add ->D() to the command.
I didn't test it, but it is probably possible to assign these diagonal elements to an volume scalar field, which could be written to disk and then loaded into Paraview.
Old   March 13, 2018, 07:02
David Barreiro
davidbarreiro is on a distinguished road
Hi everyone!
I've got a similar problem with a modification of the kinematicSingleLayer model for reactingParcelFilFoam. I added a pressure term to model the surface tension and it's working quite well. The problem is that I want to visualize this term and I'm not being able to save it. I've tried to modify the original NO_WRITE for AUTO_WRITE but it doesn't work. Any idea??
tmp<volScalarField> myKinematicSingleLayer::pu()
    return tmp<volScalarField>
        new volScalarField
            IOobject
                typeName + ":pu",
                time_.timeName(),
                regionMesh(),
                IOobject::NO_READ,
            pPrimary_                  // pressure (mapped from primary region)
          - pSp_                           // accumulated particle impingement
          - fvc::laplacian(sigma_, delta_) // surface tension
          - sigma_/hDisj_*(cos(theta_/180*3.141593)-1)*exp(-delta_/hDisj_) //Disjoining pressure
Thank you in advance,
David
davidbarreiro is offline   Reply With Quote
Old   March 23, 2019, 07:23
Madeleine Combrinck
Madeleine C is on a distinguished road
Originally Posted by davidbarreiro View Post
Hi everyone!
        new volScalarField
            IOobject
                typeName + ":pu",
                time_.timeName(),
                regionMesh(),
                IOobject::NO_READ,
David
Dear David,
Did you find a solution to this?
I am attempting to write out a source term and got stuck.
Madeleine C is offline   Reply With Quote
Problem of SOURCE term gradient in UDS wind Fluent UDF and Scheme Programming 6 December 1, 2022 15:21
[Other] OpenFOAM Installation for navalFoam sachinlb OpenFOAM Community Contributions 22 July 28, 2017 06:26
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 02:41
[swak4Foam] funkySetFields compilation error tayo OpenFOAM Community Contributions 39 December 3, 2012 06:18
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
