Coupling OpenFOAM with Abaqus
Like Tree2Likes
  • 1 Post By elvis
  • 1 Post By chriss85
Old   November 25, 2013, 16:56
Default Coupling OpenFOAM with Abaqus
Sergey
skuznet is on a distinguished road
I just found a OpenFOAM tutorial about coupling OpenFOAM and an external application through externalCoupled boundary conditions
/OpenFOAM/tutorials/heatTransfer/buoyantSimpleFoam/externalCoupledCavity
In this example OpenFOAM is coupled with a dummy external solver.
I wonder if someone did such coupling with Abaqus?
skuznet is offline   Reply With Quote
Old   November 27, 2013, 04:15
Elvis
elvis will become famous soon enough
there is a commercial tool "MpCCI" by Fraunhofer SCAI
that supports the coupling of OpenFOAM and many other CAE Software
http://www.mpcci.de/mpcci-descriptio...e-adapter.html
It is a save bet to use MpCCI for many problems, but it is a expensive one.
Sorry that I can not answer your specific question about externalCoupled boundary conditions.
http://sourceforge.net/projects/open...ningSlides.tgz =>Fluid Structure Interaction Simulations with OpenFOAM; M. Lombardi
http://sourceforge.net/projects/open...ngMaterial.tgz
Multi-Zonal Multi-Physics Modeling: FSI and Congjugate Heat/Mass Transfer,
R. Campbell and B. Craven, PSU http://sourceforge.net/projects/open...ell_slides.pdf http://sourceforge.net/projects/open...ven_slides.pdf
mm.abdollahzadeh likes this.
elvis is offline   Reply With Quote
Old   November 27, 2013, 15:35
Sergey
Elvis,
Thank you for the information!
Old   January 21, 2014, 10:08
chriss85 will become famous soon enough
In which version did you find this tutorial?
I have not been able to find it in 2.2, 2.1 and ext-3.0.
I am also interested in using this BC. If needed, I might look into it myself, but this would lower its priority quite a bit for me as I already have a working, albeit suboptimal solution for the coupling.
Edit: Nevermind, found it in 2.2.2, I was looking in 2.2.1.
skuznet likes this.
chriss85 is offline   Reply With Quote
Old   January 21, 2014, 11:56
@skuznet: Just as a clarification, I'm not using Abaqus, I want to couple to an external python script that evaluates some differential equations.
OpenFOAM Foundation releases OpenFOAM 2.2.2 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 October 14, 2013 08:18
CCM+ Abaqus FSI coupling stumpy STAR-CCM+ 3 March 1, 2012 14:28
Coupling of DEM with Openfoam mali28 OpenFOAM 2 July 8, 2011 02:19
OpenFOAM 1.6.x, 1.7.0 and 1.7.x are not fully prepared to work with gcc-4.5.x wyldckat OpenFOAM Bugs 18 October 21, 2010 06:51
coupling OpenFOAM with other programs Martin123 OpenFOAM Running, Solving & CFD 3 June 3, 2009 19:13
