difference between U().boundaryField()[patchI] and U().boundaryField()[patchI].patchI
Like Tree5Likes
  • 5 Post By jherb
Old   September 7, 2013, 08:02
Default difference between U().boundaryField()[patchI] and U().boundaryField()[patchI].patchI
Yu CAO
cctv is on a distinguished road
Hi:
I am wondering if any one know the difference between U().boundaryField()[patchI] and U().boundaryField()[patchI].patchInternalField()? and the difference between aMesh().faceAreaNormals() and aMesh().faceAreaNormals().internalField() in openfoam-1.6-ext.Thanks
cctv is offline   Reply With Quote
Old   September 9, 2013, 08:27
Joachim Herb
jherb is on a distinguished road
your first version gives you the values on the patch surface whereas the second version returns the values in the cells next to the surface.
jherb is offline   Reply With Quote
Old   September 10, 2013, 07:43
Yu CAO
Thank you for your reply. I have made a comparison with the internalfield and cell centre field. and I found though these two value are very close, they are not the same. So I think there must be something differences between them. In addition, for famesh, do they have cells next to them?
Old   September 10, 2013, 16:06
Joachim Herb
What values/fields have you compared? What happens if you compare the cell center coordinates (.C(), http://www.cfd-online.com/Forums/ope...l-centers.html )?
Old   September 10, 2013, 16:16
Yu CAO
I compared the U().boundaryField()[patchI].patchInternalField and U file in corresponding time output folder, and find they are not exactly the same.
Old   September 10, 2013, 17:44
Joachim Herb
When do you print out the values of the patchInternalField. Are you sure there is no call to the solver or some boundary.correct()? Otherwise the internal values would be modified before stored in the output files.
Old   September 10, 2013, 19:22
Yu CAO
Yes, I think you are right. Thank you very much.
high-order difference in OpenFOAM rxgrch OpenFOAM Programming & Development 6 August 28, 2017 15:11
Periodic Boundary Condition for upwind difference yohey44 Main CFD Forum 0 October 27, 2010 14:10
[General] paraview - plotting difference to reference data joewe ParaView 0 August 30, 2010 19:01
the effect of upwind difference hades Main CFD Forum 8 March 15, 2009 00:43
Fininte difference and Finite element Technique Mahendra Singh Mehra FLUENT 3 December 23, 2005 00:49
