how to share a scalar between processors in parallel Run
Like Tree5Likes
  • 1 Post By kmooney
  • 4 Post By l_r_mcglashan
Old   July 19, 2013, 06:27
Default how to share a scalar between processors in parallel Run
mechy is on a distinguished road
Hi all
I want to solve the single DOF forced and damped vibration equation for displacement of tip point of a plate(m*d2x/dt2+c*dx/dt+k*x=F)
and displacement of other points of plate are explicitly obtained from the first mode of the plate
the code in serial run give correct results
when I run this code in parallel for calculating displacement of other points of plate only the first processor is used correct x and others processors is used zero instead of x
how can I share the x value between all processors ?
mechy is offline   Reply With Quote
Old   July 19, 2013, 14:35
kmooney's Avatar
Kyle Mooney
kmooney is on a distinguished road
Hi Mechy,
This might not be the perfect way to do it but if you're certain that your value is correct on one processor and zero on the others, you could so a sum and reduce so that your value is identical on all processors.
//Assuming this is the x you mentioned, and it is a scalar
scalar x;
reduce(x, sumOp<scalar>());
This code will take x from each processor, sum them all up, and set x on each processor to this sum.
In other words,
With i being the processor number,
x[i] = sum(x[i])
Again, this will work assuming that x is non-zero and correct on one processor and zero on all others. There is surely a way to handle other situations but this is all I can come up with off the top of my head.
You might have to put the Pstream name space on reduce like this: Pstream::reduce(...)
Let me know if this doesn't work!
Cheers,
Kyle
edit: change returnReduce to reduce.
hua1015 likes this.
kmooney is offline   Reply With Quote
Old   July 19, 2013, 17:25
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
If this is not the case then you could use something like MPI_Scatter to send a value everywhere. This is not currently implemented in Pstreams...so you would either implement this yourself or stick with some MPI-specific functions.
chegdan is offline   Reply With Quote
Old   July 19, 2013, 17:33
Default Hi Mooney
Hi Mooney
thanks so much for your reply
yes, in this case it works well
what shoul I do if the value of x is not equal to zero on non master procesors ?
in other words how we can use the value of objects on master processor ?
Best Regards
Old   July 19, 2013, 17:36
Hi Daniel
can you give me more information
Best Regards
Old   July 19, 2013, 17:48
Daniel P. Combest
Mechy,
This is where it gets a little more difficult, but you can find information here.
I used another function called MPI_Bcast and you can see my example in my GPU library cufflink. MPI_Bcast sends out the value from the master node to all other nodes and you can see some instructions here. The rest...the internet knows .
Good Luck!
Old   July 20, 2013, 10:57
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
This works for me;
label x = 0;
if (Pstream::master())
    x = 1;
Pout<< x << endl;
Pstream::scatter(x);
Pout<< x << endl;
D.R., hua1015, kaanm and 1 others like this.
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   July 21, 2013, 23:54
Daniel P. Combest
Well that's easy enough!
Old   July 22, 2013, 07:32
Is it possible to reconstruct pressure or velocity on a boundary in a parallel run and obtain the
pressure on that boundary
for example: if during a run the pressure at processor N is shown by PN and they are as follow
how we can reconstruct them
P0=
20
-55.8428
-57.6691
-61.1336
-65.5385
-70.2184
-74.7188
-78.6798
-81.829
-83.9898
-85.0677
123.47
125.28
128.745
133.15
137.831
142.333
146.297
149.452
151.617
152.696
P1=
25
-85.0475
-83.8217
-81.4402
-77.9027
-73.199
-67.2925
-60.0901
-51.3958
-40.7595
-28.5443
13.0599
23.4403
33.5093
43.5004
53.6818
152.681
151.464
149.081
145.536
140.815
134.877
127.62
118.849
108.006
95.2818
P2=0()
P3=0()
Old   July 25, 2013, 03:18
P0=
20
-55.8428
-57.6691
-61.1336
-65.5385
-70.2184
-74.7188
-78.6798
-81.829
-83.9898
-85.0677
123.47
125.28
128.745
133.15
137.831
142.333
146.297
149.452
151.617
152.696
P1=
25
-85.0475
-83.8217
-81.4402
-77.9027
-73.199
-67.2925
-60.0901
-51.3958
-40.7595
-28.5443
13.0599
23.4403
33.5093
43.5004
53.6818
152.681
151.464
149.081
145.536
140.815
134.877
127.62
118.849
108.006
95.2818
P2=0()
P3=0()
Old   July 25, 2013, 09:52
Daniel P. Combest
Mechy,
You posted this question on another thread already
http://www.cfd-online.com/Forums/ope...allel-run.html
This will probably not get answered any faster doing this, in fact it might have the opposite effect. You might want to refer to the Forum rules, particularly number 6. And for some general guidelines for posts, see http://www.cfd-online.com/Forums/ope...-get-help.html. I would focus this discussion on your other thread. You can then reply to yourself with more information on what you are trying to achieve or what you have tried already and I'm sure people will answer .
Good Luck!
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
dieselFoam problem!! trying to introduce a new heat transfer model vivek070176 OpenFOAM Programming & Development 10 December 24, 2014 00:48
Parallel run - number of processors danvica OpenFOAM Running, Solving & CFD 4 April 5, 2012 12:57
Can't run in parallel JulytoNovember OpenFOAM Running, Solving & CFD 2 March 31, 2012 10:28
SnappyHexMesh OF-1.6-ext crashes on a parallel run norman1981 OpenFOAM Bugs 5 December 7, 2011 13:48
