Ueqn.A() extract the diag. term from the Ueqn??
Like Tree4Likes
  • 1 Post By sharonyue
  • 2 Post By Martin80
Old   July 3, 2013, 00:19
Default Ueqn.A() extract the diag. term from the Ueqn??
Dongyue Li
sharonyue is on a distinguished road
I just made a testify, add this code into icoFoam:
fvVectorMatrix UEqn
            fvm::ddt(U)
          + fvm::div(phi, U)
          - fvm::laplacian(nu, U)
Info<<"UEqn:" << UEqn << endl;
Info<<"UEqn.A():" << UEqn.A()<< endl;
Info<<"UEqn.H():" << UEqn.H()<< endl;
        //solve(UEqn == -fvc::grad(p));
        // --- PISO loop
Then I run a 9 nodes cavity case. It output this in the first timestep:
Create time
Create mesh for time = 0
Reading transportProperties
Reading field p
Reading field U
Starting time loop
Time = 0.005
Courant Number mean: 0 max: 0
UEqn:Lower triangle =
12
-3e-05
-3e-05
-3e-05
-3e-05
-3e-05
-3e-05
-3e-05
-3e-05
-3e-05
-3e-05
-3e-05
-3e-05
diagonal = 9(0.00012 0.00015 0.00012 0.00015 0.00018 0.00015 0.00012 0.00015 0.00012)
Upper triangle =
12
-3e-05
-3e-05
-3e-05
-3e-05
-3e-05
-3e-05
-3e-05
-3e-05
-3e-05
-3e-05
-3e-05
-3e-05
[0 4 -2 0 0 0 0]
9{(0 0 0)}
3
3((6e-05 6e-05 6e-05) (6e-05 6e-05 6e-05) (6e-05 6e-05 6e-05))
9((6e-05 6e-05 6e-05) (6e-05 6e-05 6e-05) (6e-05 6e-05 6e-05) (6e-05 6e-05 6e-05) (6e-05 6e-05 6e-05) (6e-05 6e-05 6e-05) (6e-05 6e-05 6e-05) (6e-05 6e-05 6e-05) (6e-05 6e-05 6e-05))
0()
3
3((6e-05 0 0) (6e-05 0 0) (6e-05 0 0))
9{(0 0 0)}
0()
UEqn.A():dimensions      [0 0 -1 0 0 0 0];
internalField   nonuniform List<scalar> 9(800 700 800 700 600 700 800 700 800);
boundaryField
    movingWall
        type            zeroGradient;
    fixedWalls
        type            zeroGradient;
    frontAndBack
        type            empty;
UEqn.H():dimensions      [0 1 -2 0 0 0 0];
internalField   nonuniform List<vector> 9((0 0 0) (0 0 0) (0 0 0) (0 0 0) (0 0 0) (0 0 0) (200 0 0) (200 0 0) (200 0 0));
boundaryField
    movingWall
        type            zeroGradient;
    fixedWalls
        type            zeroGradient;
    frontAndBack
        type            empty;
So in this log, Why Ueqn.A()'s internal field is not equal to the Ueqn's diag. term? I mark this two in the red.
Thanks in advance,
utkunun likes this.
sharonyue is offline   Reply With Quote
Old   July 4, 2013, 06:40
Dongyue Li
If A()=diag()/mesh.V(),
this is my mesh:
convertToMeters 0.03;
vertices
    (0 0 0)
    (1 0 0)
    (1 1 0)
    (0 1 0)
    (0 0 0.1)
    (1 0 0.1)
    (1 1 0.1)
    (0 1 0.1)
blocks
    hex (0 1 2 3 4 5 6 7) (3 3 1) simpleGrading (1 1 1)
So V is 0.003*0.01*0.01=0.000003.
but 0.00012/0.000003 does not equal to 800.
utkunun likes this.
Old   July 24, 2013, 12:08
Martin80 is on a distinguished road
Ueqn.A()=diag()/mesh.V() holds true only for cells, which do not contact the boundary. E.g. in your example:
600=0.00018/(0.01*0.01*0.003)
[and be careful mesh.V()=3e-7 (not 3e-6)].
At the moment I'm also trying to clarify details about the "Ueqn.A()".
B.r. Martin.
sharonyue and utkunun like this.
Martin80 is offline   Reply With Quote
Old   July 24, 2013, 12:12
Dongyue Li
Originally Posted by Martin80 View Post
B.r. Martin.
So this is only true for inner cells, not boundary cells. Thats clear! Thx very much!
adding dispersion force term in UEqn leads to oscillations of velocity field sr_tenedor OpenFOAM Programming & Development 2 June 6, 2014 07:59
Adding an explicit source term in the UEqn() Anne Lincke OpenFOAM Running, Solving & CFD 0 June 25, 2013 13:19
Source term problem in UEqn of simpleFoam fisch OpenFOAM Programming & Development 1 June 17, 2011 11:57
Extract momentum source term Rickard.Solsjo OpenFOAM 0 January 14, 2011 10:44
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
