.boundary() in parallel
Like Tree1Likes
  • 1 Post By MartinB
Old   January 8, 2013, 08:50
Default .boundary() in parallel
Nicklas Linder
nlinder is on a distinguished road
in my solver I have a loop through all my boundaries to extract those of type wall. This is realised by
forAll (mesh.boundary(), patchI)
    if (mesh.boundary()[patchI].type() == "wall")
        wallPatchID = patchI;
        Info << "U.boundaryField()[wallPatchID].size(): " << U.boundaryField()[wallPatchID].size() << endl;
The output of the Info statement on a single core is correct:
U.boundaryField()[wallPatchID].size(): 2500
If I run it in parallel with two domains the output is
U.boundaryField()[wallPatchID].size(): 0
How can I make that work in parallel? What changes when I run this in parallel concerning the numbering of the boundary-patches?
Thanks in advance!
Nicklas
nlinder is offline   Reply With Quote
Old   January 11, 2013, 09:18
Nicklas Linder
After playing around with the decomposition methods, I looks as if the code only "runs" on the processor0. Anyone knows what to do?
Thanks
Old   January 11, 2013, 09:26
Martin
MartinB will become famous soon enough
Hi Nicklas,
use "Pout<< " instead of "Info<< ", then each processor will output its local size.
With "Info<< " only processor0 will print its value, and you must use a gSum command to gather the information from all processors to processor0 first.
Martin
Loki Kerry likes this.
MartinB is offline   Reply With Quote
Old   January 11, 2013, 09:33
Nicklas Linder
Hi Martin,
thanks for the hint.. Ok, for the output it is clear. But if i e.g. want to set U as U^2 on a boundary I first have to "gSum" the velocity fields, then square them, and redistribute?
Nicklas
Old   January 11, 2013, 09:36
Martin
Since every processor calls the gSum, too, the sum is distributed already, I think. So every processor can calculate the U^2 value and set it locally.
You can check it with the Pout command again.
Martin
Old   January 11, 2013, 09:37
Nicklas Linder
Allright, I'll try that, thanks for your help!
Old   January 11, 2013, 09:59
Nicklas Linder
Sorry to bother again, but...
gSum returns only the sum.. I actually want a vector(or scalar)Field of a patch which is split to several processors. That seems to be sth different?!
Greetings
Nicklas
Old   January 11, 2013, 10:25
Martin
May be you can find the answer in this code snippet, where slave processors are sending data to the master processor with Pstream:
http://www.cfd-online.com/Forums/ope...tml#post282446
Martin
Old   January 11, 2013, 11:00
Nicklas Linder
Hi Martin,
I think I now understood what was going wrong. I just added a condition, that the operations on the boundary are only performed, if it's size is greater than 0. No all warnings and Errors disappeared and it seems to work!
Thanks for your help!
Nicklas
Script to Run Parallel Jobs in Rocks Cluster asaha OpenFOAM Running, Solving & CFD 12 July 4, 2012 23:51
CFX parallel multi-node jobs fail w/ SLURM on Ubuntu 10.04 danieru CFX 0 February 17, 2012 07:20
parallel performance on BX900 uzawa OpenFOAM Installation 3 September 5, 2011 16:52
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 13:00
