Map fields every time step
Like Tree3Likes
  • 3 Post By sebas
Old   August 27, 2012, 05:58
Default Map fields every time step
Sebastian Bomberg
sebas is on a distinguished road
Dear all,
I would like to solve different equations on different domains. The equations couple through their RHSs wherever the domains overlap. I therefore need to interpolate/map fields from one domain to the other at every time step.
For a single CPU this is quite easy to implement:
#include meshToMesh.H
meshToMesh mapper(meshSource, meshTarget, patchMap, cuttingPatches);
mapper.interpolate(fieldTarget, fieldSource);
However, when this is to be run in parallel things start to get tricky. The way in which the mapFields utility does it is not really efficient as it creates copies of meshes and fields, and spends most of its time reading/writing IOobjects.
So I create a list of pointers to my meshes/fields:
List< fvMesh* > sourceMeshes(Pstream::nProcs());
sourceMeshes[Pstream::myProcNo()] = &meshSource;
I then try to gather data from all processors and perform the interpolation on the master processor:
Pstream::gatherList(sourceMeshes);
And this is where I get the following error message:
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/gatherScatterList.C: In static member function ‘static void Foam::Pstream::gatherList(const Foam::List<Foam::UPstream::commsStruct>&, Foam::List<T>&, int) [with T = Foam::fvMesh*]’:
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/gatherScatterList.C:187:9:   instantiated from ‘static void Foam::Pstream::gatherList(Foam::List<T>&, int) [with T = Foam::fvMesh*]’
myLaplacianFoam.C:58:37:   instantiated from here
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/gatherScatterList.C:101:17: error: no match for ‘operator>>’ in ‘fromBelow >> ((Foam::List<Foam::fvMesh*>*)Values)->Foam::List<Foam::fvMesh*>::<anonymous>.Foam::UList<T>::operator[] [with T = Foam::fvMesh*, Foam::label = int](belowID)’
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/scalarRange.H:135:25: note: candidates are: Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::scalarRange&)
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/septernion.H:146:25: note:                 Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::septernion&)
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/quaternion.H:174:25: note:                 Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::quaternion&)
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/vectorTensorTransform.H:167:25: note:                 Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::vectorTensorTransform&)
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/wordRe.H:231:25: note:                 Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::wordRe&)
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/boundBox.H:230:25: note:                 Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::boundBox&)
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/nil.H:77:25: note:                 Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::nil&)
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/cellShape.H:162:25: note:                 Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::cellShape&)
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/faceI.H:151:23: note:                 Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::face&)
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/SHA1Digest.H:137:25: note:                 Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::SHA1Digest&)
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/instant.H:145:25: note:                 Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::instant&)
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/Switch.H:207:25: note:                 Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::Switch&)
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/dimensionSet.H:302:25: note:                 Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::dimensionSet&)
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/dictionary.H:507:25: note:                 Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::dictionary&)
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/long.H:56:10: note:                 Foam::Istream& Foam::operator>>(Foam::Istream&, long int&)
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/Istream.H:170:17: note:                 Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::IOstream& (*)(Foam::IOstream&))
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/Istream.H:164:17: note:                 Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::Istream& (*)(Foam::Istream&))
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/token.H:421:25: note:                 Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::token&)
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/fileName.H:188:25: note:                 Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::fileName&)
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/Scalar.H:306:10: note:                 Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::doubleScalar&)
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/Scalar.H:306:10: note:                 Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::floatScalar&)
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/uint.H:56:10: note:                 Foam::Istream& Foam::operator>>(Foam::Istream&, unsigned int&)
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/bool.H:48:10: note:                 Foam::Istream& Foam::operator>>(Foam::Istream&, bool&)
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/int.H:57:10: note:                 Foam::Istream& Foam::operator>>(Foam::Istream&, int&)
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/word.H:133:25: note:                 Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::word&)
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/string.H:219:25: note:                 Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::string&)
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/char.H:49:10: note:                 Foam::Istream& Foam::operator>>(Foam::Istream&, char&)
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/gatherScatterList.C:114:21: error: no match for ‘operator>>’ in ‘fromBelow >> ((Foam::List<Foam::fvMesh*>*)Values)->Foam::List<Foam::fvMesh*>::<anonymous>.Foam::UList<T>::operator[] [with T = Foam::fvMesh*, Foam::label = int](leafID)’
Does anybody know how to fix this? I would really appreciate your help.
Sebastian
sebas is offline   Reply With Quote
Old   August 27, 2012, 06:36
Arne Stahlmann
Arnoldinho is on a distinguished road
could you give the line(s) of code where the error occurs, i.e somewhere around myLaplacianFoam.C:58:37?
Arnoldinho is offline   Reply With Quote
Old   August 27, 2012, 06:43
Sebastian Bomberg
Dear Arnoldinho,
it is exactly the call to
Old   August 27, 2012, 06:55
Arne Stahlmann
Hmm, then I have no clue. Have you tried it with a "standard" list first instead of pointers, like given in http://www.cfd-online.com/Forums/openfoam/77465-combining-lists-distributed-amongst-processors.html?
Arne
Old   August 27, 2012, 07:19
Sebastian Bomberg
If I use
List<fvMesh> sourceMeshes(Pstream::nProcs());
and
sourceMeshes[Pstream:myProcNo()] = sourceMesh;
instead of pointers, I get an error when trying to populate the list (not when gathering as before):
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/finiteVolume/lnInclude/fvMesh.H: In function ‘int main(int, char**)’:
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/finiteVolume/lnInclude/fvMesh.H:160:14: error: ‘void Foam::fvMesh::operator=(const Foam::fvMesh&)’ is private
myLaplacianFoam.C:58:41: error: within this context
In file included from /nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/List.H:259:0,
                 from /nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/labelList.H:48,
                 from /nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/UPstream.H:43,
                 from /nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/Pstream.H:42,
                 from /nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/parRun.H:35,
                 from /nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/finiteVolume/lnInclude/fvCFD.H:4,
                 from myLaplacianFoam.C:32:
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/List.C: In constructor ‘Foam::List<T>::List(Foam::label) [with T = Foam::fvMesh, Foam::label = int]’:
myLaplacianFoam.C:57:48:   instantiated from here
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/List.C:56:9: error: no matching function for call to ‘Foam::fvMesh::fvMesh()’
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/finiteVolume/lnInclude/fvMesh.H:194:9: note: candidates are: Foam::fvMesh::fvMesh(const Foam::IOobject&, const Foam::Xfer<Foam::Field<Foam::Vector<double> > >&, const Foam::Xfer<Foam::List<Foam::face> >&, const Foam::Xfer<Foam::List<Foam::cell> >&, bool)
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/finiteVolume/lnInclude/fvMesh.H:182:9: note:                 Foam::fvMesh::fvMesh(const Foam::IOobject&, const Foam::Xfer<Foam::Field<Foam::Vector<double> > >&, const Foam::Xfer<Foam::List<Foam::face> >&, const Foam::Xfer<Foam::List<int> >&, const Foam::Xfer<Foam::List<int> >&, bool)
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/finiteVolume/lnInclude/fvMesh.H:178:18: note:                 Foam::fvMesh::fvMesh(const Foam::IOobject&)
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/finiteVolume/lnInclude/fvMesh.H:157:9: note:                 Foam::fvMesh::fvMesh(const Foam::fvMesh&)
In file included from /nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/Pstream.H:309:0,
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/finiteVolume/lnInclude/fvMesh.H: In static member function ‘static void Foam::Pstream::gatherList(const Foam::List<Foam::UPstream::commsStruct>&, Foam::List<T>&, int) [with T = Foam::fvMesh]’:
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/gatherScatterList.C:187:9:   instantiated from ‘static void Foam::Pstream::gatherList(Foam::List<T>&, int) [with T = Foam::fvMesh]’
myLaplacianFoam.C:59:37:   instantiated from here
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/gatherScatterList.C:91:17: error: within this context
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/gatherScatterList.C:95:21: error: within this context
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/gatherScatterList.C:101:17: error: ‘Foam::dictionary’ is an ambiguous base of ‘Foam::fvMesh’
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/gatherScatterList.C:105:21: error: ‘Foam::dictionary’ is an ambiguous base of ‘Foam::fvMesh’
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/gatherScatterList.C:114:21: error: ‘Foam::dictionary’ is an ambiguous base of ‘Foam::fvMesh’
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/gatherScatterList.C:118:25: error: ‘Foam::dictionary’ is an ambiguous base of ‘Foam::fvMesh’
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/gatherScatterList.C:135:17: error: ‘Foam::dictionary’ is an ambiguous base of ‘Foam::fvMesh’
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/gatherScatterList.C:143:17: error: within this context
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/gatherScatterList.C:147:21: error: within this context
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/gatherScatterList.C:162:17: error: ‘Foam::dictionary’ is an ambiguous base of ‘Foam::fvMesh’
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/gatherScatterList.C:170:25: error: ‘Foam::dictionary’ is an ambiguous base of ‘Foam::fvMesh’
/nfs/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/gatherScatterList.C:174:21: error: ‘Foam::dictionary’ is an ambiguous base of ‘Foam::fvMesh’
Old   August 27, 2012, 07:47
Arne Stahlmann
Where and how did you define your "sourceMesh"?
Further, you have an error in "sourceMeshes[Pstream:myProcNo()] = sourceMesh;" as you are missing a ":" in Pstream::myProcNo().
But the problem is your "void Foam::fvMesh:perator=(const Foam::fvMesh&)’ is private" error.
With my hint of using a normal scalar list, I meant just a scalar list with fictitious values, in order to check whether you overall implementation is right or if there is a problem with sharing meshes. As a second step, I would try to populate your real mesh values.
Arne
Old   August 27, 2012, 08:20
Sebastian Bomberg
Sorry, sourceMeshes[Pstream:myProcNo()] is just a typo in the posting. It is correct in the code.
The meshes are different regions registered at the same runTime object. E.g.
FOAM::fvMesh meshSource
    Foam::IOobject
        "regionSource",
        runTime.timeName(),
        runTime,
        Foam::IOobject::MUST_READ
The fields are "living"on the respective meshes, e.g.
volScalarField TSource
    IOobject
        "T",
        runTime.timeName(),
        meshSource,
        IOobject::MUST_READ,
        IOobject::AUTO_WRITE,
    meshSource
By the way, without the mapping the case runs perfectly also in parallel.
Old   August 27, 2012, 10:02
Sebastian Bomberg
It works with an integer list where I store e.g. the processor IDs.
Old   August 27, 2012, 10:16
Arne Stahlmann
Hmm. Then I can only guess or presume that the gather function has been written for particular types only - and that your mesh structure there is not supported. But this is just a guess...
Arne
Old   September 3, 2012, 05:34
Sebastian Bomberg
Apparently fvMesh (and hence the fields that live on the mesh) lack the constructor from IStream and the OStream << operator.
Any idea how to sove this without reimplementing the fvMesh class?
Old   September 12, 2012, 11:32
Sebastian Bomberg
OK. I have an idea for a not-so-quick but dirty work-around.
If I use manual decomposition and make sure that the bits of the two meshes on each processor overlap, I side-step the whole problem of inter-processor communication.
However, this requires some compromise regarding mesh quality and decomposition optimality.
Let's see how this works...
Old   September 24, 2012, 04:01
Sebastian Bomberg
It works. And with the use of funkySetfields (and a small script) the pre-processing is not too tedious either.
However, I want to perform a volume averaging when mapping from the fine grid to the coarse one. Therefore, I need to write my on meshToMesh anyway. From what I've seen from the code it looks like it can be easiliy parallellized by means of reduce options. I have no idea how fast or slow this will be due to the additional inter-processor communication...
Old   October 26, 2012, 19:31
mahdi abdollahzadeh
mm.abdollahzadeh is on a distinguished road
Dear All
I want to use the command below
    meshToMesh  meshToMeshInterpb(newMesh, mesh);
   const fvMesh& meshSource = meshToMeshInterpb.fromMesh();
    const fvMesh& meshTarget = meshToMeshInterpb.toMesh();
   meshToMeshInterp.interpolate(p,pn,meshToMesh::INTERPOLATE);
   meshToMeshInterp.interpolate(U,Un,meshToMesh::INTERPOLATE);
I have to meshs , mesh and newMesh which are the same size at the beginning ....In each iteration solution is done by the fields defined on mesh. t then meshNew will be refined according to Errorfield. then I want to map the results of fields on mesh to corrosponding fields on newMesh. then mesh will be refined to be similar to meshnew and then I want to map the newMesh on mesh.
I have both volscalar and volvector and surfacescalar.
but when I am trying to run my case even on the first iteration.
the argument field does not correspond to the right mesh. Field size: 400 mesh size: 1600
From function meshToMesh::interpolateInternalField(Field<Type>& toF, const GeometricField<Type, fvPatchField, volMesh>& fromVf, meshToMesh:rder ord) const
in file /home/mahdi/OpenFOAM/OpenFOAM-1.7.1/src/sampling/lnInclude/meshToMeshInterpolate.C at line 147.
I will be thankful for help
best
mahdi
mm.abdollahzadeh is offline   Reply With Quote
Old   October 27, 2012, 10:48
Sebastian Bomberg
Dear Mahdi,
is p defined on mesh and pn on newMesh, respectively?
The order of source and target field in the interpolate function is different from the order of source and target mesh in the constructor... which is somewhat counter intuitive.
Old   October 27, 2012, 12:23
mahdi abdollahzadeh
Dear sebas
Thanks for your reply.
Yes p and pn are defined on the mesh and meshnew receptively. and I have checked the order of source and target.
But its giving the same error.
Best
Mahdi
Old   November 2, 2012, 08:08
mahdi abdollahzadeh
Originally Posted by sebas View Post
Dear Mahdi,
Dear Sebas
I have solved that problem ... but no data in maped FROM my first mesh to meshNew!!!!.
best
mahdi
Old   December 5, 2012, 14:13
Ganesh Vijayakumar
ganeshv is on a distinguished road
Hey Sebas,
Did you manage to figure this out? I need a similar capability now. Essentially it all seems to boil down to creating a parallel implementation of the mapFields utility.
ganesh
ganeshv is offline   Reply With Quote
Ganesh Vijayakumar
Hey Sebas,
ganesh
map fields, multiple meshes, parallel, pstream
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 22:51
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 05:13
plot over time fferroni OpenFOAM Post-Processing 7 June 8, 2012 08:56
