Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
LES - meaning of volScalarField k in time folders
Like Tree1Likes
  • 1 Post By Sylv
Old   May 22, 2014, 08:12
Default LES - meaning of volScalarField k in time folders
aylalisa is on a distinguished road
Dear Foamers,
which information provides the volScalarField k in the time folders of an converged LES?
In case of a RANS computation afak k provides the turbulent kinetic energy according to k^{'2} = \frac{1}{2} * (u^{'2} + v^{'2} +w^{'2}).
Aylalisa
aylalisa is offline   Reply With Quote
Old   May 28, 2014, 07:08
Marcel Vonlanthen
Sylv is on a distinguished road
Hello Aylalisa,
the volScalarField k in a LES stands for the subgrid-scale turbulent kinectic energy k_{sgs}. Pope (2006) names it "residual kinetic energy" k_{r} (see p.581).
Marcel
aylalisa likes this.
Sylv is offline   Reply With Quote
Old   May 28, 2014, 12:13
Hello Marcel,
do I receive the same result for k_\tau if I extract the isotropic part of volSymmTensorField UPrime2Mean (produced by utility postChannel) --> sum of the tensor's trace components multiplied by factor \frac{1}{2}?
Does this mean that UPrime2Mean \equiv \tau^R_{ij} \equiv \tau^r_{ij} + \frac{2}{3}k_r \delta_{ij} ?
\bar{p} \equiv \bar{p} + \frac{2}{3} \rho k_\tau --> trace elements of the tensor (isotropic residual stress) will finally be included in the modified filtered pressure? (S.Pope (13.94), page 581)
Sorry for my question invasion, I brood for a while about this point, maybe u could help...
Aylalisa
Old   December 23, 2014, 18:43
Uyan is on a distinguished road
Hi aylalisa,
What is the utility you used to extract isotropic part of volSymmTensorField UPrime2Mean separately from UPrime2Mean ?
Uyan is offline   Reply With Quote
Old   December 29, 2014, 15:12
Hi Uyan,
I would use trace().
tensor B(1, 1, 1, 2, 2, 2, 3, 3, 3);
G = tr(B)*1/3;
That probably works for the field as well.
Old   February 29, 2016, 18:40
Default How to calculate U+ and y+
Christopher Yaw Bansah
chrissbans is on a distinguished road
Hi All,
I run the case for channel flow(channel395) in openFoam and I am getting values for Umean magnitude ,UPrime2mean etc. Please how do I compute for U+ and Y+. Thank you
chrissbans is offline   Reply With Quote
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 07:55
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
writing execFlowFunctionObjects immortality OpenFOAM Post-Processing 30 September 15, 2013 07:16
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 05:35
