August 23, 2012, 04:38 |
WallHeatFlux and chtMultiregion
M
Rep Power: 14 |
Someone can explain me how we can calculate a heatflux on bondary (solid or fluid) with WallHeatFlux utility ? I use chtMultiRegion solver. I already read some post in this forum, but there is no clear answer. I saw that someone (NicolasB) succeed in calculating with "wallHeatFluxRho" nevertheless, I don't know how compile this new utility....(cf. here). My error nowadays : Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.1-221db2718bbb Exec : wallHeatFlux Date : Aug 23 2012 Time : 09:29:51 Host : "S00079122" PID : 3983 Case : /home/Public/test nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Time = 0 Selecting thermodynamics package hRhoThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>> #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/libc.so.6" #3 Foam::hRhoThermo<Foam::pureMixture<Foam::constTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > > >::calculate() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so" #4 Foam::hRhoThermo<Foam::pureMixture<Foam::constTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > > >::hRhoThermo(Foam::fvMesh const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so" #5 Foam::basicThermo::addfvMeshConstructorToTable<Foam::hRhoThermo<Foam::pureMixture<Foam::constTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > > > >::New(Foam::fvMesh const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so" #6 Foam::basicThermo::New(Foam::fvMesh const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so" #7 in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/wallHeatFlux" #8 __libc_start_main in "/lib/libc.so.6" #9 in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/wallHeatFlux" Exception en point flottant Thanks for any hint, Best regards, m_f |
August 30, 2012, 06:15 |
Tobias Holzmann
Rep Power: 52 |
Hi all,
I wrote private messages with m_f and thought that it will be good to publish these things. How can I calculate the wallHeatFlux in chtMultiRegion To calculate the wall heatFlux you have to manage your chtMultiRegions like single regions. For example. If you have a chtMultiCase with fluid1 solid1 fluid2, you have 3 regions which can be separated. For wallHeatFlux do the following: Make a new directory like "wallHeatFluxFluid1". And copy the following things in it. Code:
0/fluid1/ wallHeatFluxFluid1/0 constant/fluid1/ wallHeatFluxFluid1/constant system/fluid1/ wallHeatFluxFluid1/system Different wallHeatFlux utilities there are different utilities like - wallHeatFlux (default) - wallHeatFluxRho - wallHeatFluxLaminar The differences are given now: wallHeatFlux Code: Code:
surfaceScalarField heatFlux ( fvc::interpolate(RASModel->alphaEff())*fvc::snGrad(h) ); wallHeatFluxRho Code: Code:
surfaceScalarField heatFlux = fvc::interpolate(RASModel->alphaEff())*fvc::snGrad(h); and you can derivate T from h. I am not exactly sure of that but it should be right. wallHeatFluxLaminar Code: Code:
surfaceScalarField heatFlux = k*fvc::snGrad(T); the multiplication with the faceArea follows after that calculation but is always the same. snGrad is the gradient normal to the face (I am wrong, please correct me). wallHeatFlux and wallHeatFluxRho should be the same. Download these tools? I rebuild the wallHeatFluxRho utility and uploaded that one and the wallHeatFluxLaminar utility to my server (github). Link follows! Hope that will help other guys. Have a nice day. Tobi |
September 3, 2012, 12:43 |
M
Rep Power: 14 |
Thanks dude.
September 6, 2013, 07:08 |
wallHeatFlux and chtMultiRegionFoam
Rep Power: 13 |
I am trying to get out the wallHeatFlux of my model. I read already threads but still i cant find out how to do: http://www.cfd-online.com/Forums/ope...ltiregion.html I am using the chtMultiRegionFoam. I have two region in my model: solid and air. I am running the simulation in parallel. At the moment I execute the following lines to get my VTK's and do the post processing. Code:
reconstructPar -latestTime -region air yPlusRAS -compressible -latestTime -region air foamToVTK -latestTime -poly -region air reconstructPar -latestTime -region solid foamToVTK -latestTime -poly -region solid I tried to execute Code:
reconstructPar -latest Time -region solid wallHeatFlux -latestTime -case wall wallheatfluxsolid foamToVTK -latestTime -poly -region solid Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.0-1680a452835e Exec : wallHeatFlux -latestTime -case wallHeatFluxSolid Date : Sep 06 2013 Time : 12:05:18 Host : "atibkwcfd04" PID : 18392 Case : ./wallHeatFluxSolid nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM Warning : From function dlOpen(const fileName&, const bool) in file POSIX.C at line 1175 dlopen error : libcompressibleExtraRASModels.so: cannot open shared object file: No such file or directory --> FOAM Warning : From function dlLibraryTable::open(const fileName&, const bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 96 could not load "libcompressibleExtraRASModels.so" Create mesh for time = 0 Time = 0 Selecting thermodynamics package constSolidThermo --> FOAM FATAL ERROR: Unknown basicPsiThermo type constSolidThermo Regards Last edited by wyldckat; September 7, 2013 at 15:25. Reason: Added [CODE][/CODE] |
September 7, 2013, 15:28 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Sausi and welcome to the forum!
I've moved your post to this thread, because it wasn't so long ago Besides, I was going to post on this thread anyway, because Tobi forgot to post the links to his repositories: Try using the wallHeatFluxRho version as Tobi wrote about above. If you still have problems, let us know Best regards, Bruno PS: I've also added the "[CODE]" markers to your post, as explained on my second signature link.
September 9, 2013, 10:56 |
Rep Power: 13 |
Thanks for your answer. I tried to compile wallHeatFluxRho but the following message occurs.
Making dependency list for source file wallHeatFluxRho.C SOURCE=wallHeatFluxRho.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/opt/OpenFOAM-2.1.0/src/turbulenceModels -I/opt/OpenFOAM-2.1.0/src/turbulenceModels/compressible/RAS/RASModel -I/opt/OpenFOAM-2.1.0/src/thermophysicalModels/specie/lnInclude -I/opt/OpenFOAM-2.1.0/src/thermophysicalModels/reactionThermo/lnInclude -I/opt/OpenFOAM-2.1.0/src/thermophysicalModels/basic/lnInclude -I/opt/OpenFOAM-2.1.0/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude -I/opt/OpenFOAM-2.1.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/wallHeatFluxRho.o g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/opt/OpenFOAM-2.1.0/src/turbulenceModels -I/opt/OpenFOAM-2.1.0/src/turbulenceModels/compressible/RAS/RASModel -I/opt/OpenFOAM-2.1.0/src/thermophysicalModels/specie/lnInclude -I/opt/OpenFOAM-2.1.0/src/thermophysicalModels/reactionThermo/lnInclude -I/opt/OpenFOAM-2.1.0/src/thermophysicalModels/basic/lnInclude -I/opt/OpenFOAM-2.1.0/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude -I/opt/OpenFOAM-2.1.0/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/wallHeatFluxRho.o -L/opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib \ -lcompressibleRASModels -lreactionThermophysicalModels -lfiniteVolume -lgenericPatchFields -lspecie -lbasicThermophysicalModels -lOpenFOAM -ldl -lm -o /data1/OpenFOAM/2.1.0/platforms/linux64GccDPOpt/bin/wallHeatFluxRho /usr/lib64/gcc/x86_64-suse-linux/4.5/../../../../x86_64-suse-linux/bin/ld: warning: libcompressibleTurbulenceModel.so, needed by /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so, not found (try using -rpath or -rpath-link) /usr/lib64/gcc/x86_64-suse-linux/4.5/../../../../x86_64-suse-linux/bin/ld: warning: libmeshTools.so, needed by /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so, not found (try using -rpath or -rpath-link) /usr/lib64/gcc/x86_64-suse-linux/4.5/../../../../x86_64-suse-linux/bin/ld: warning: libtriSurface.so, needed by /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so, not found (try using -rpath or -rpath-link) /usr/lib64/gcc/x86_64-suse-linux/4.5/../../../../x86_64-suse-linux/bin/ld: warning: libPstream.so, needed by /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so, not found (try using -rpath or -rpath-link) Make/linux64GccDPOpt/wallHeatFluxRho.o: In function `main': wallHeatFluxRho.C:(.text+0x2398): undefined reference to `Foam::compressible::turbulenceModel::typeName' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::NamedEnum<Foam::mappedPatchBase::sampleMode, 4>::names' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so: undefined reference to `Foam::compressible::turbulenceModel::constructturbulenceModelConstructorTables()' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::coordinateSystem::~coordinateSystem()' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so: undefined reference to `Foam::reduce(double&, Foam::sumOp<double> const&, int)' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so: undefined reference to `Foam::UIPstream::read(Foam::UPstream::commsTypes, int, char*, long, int)' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::cellSet::~cellSet()' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::cellDistFuncs::cellDistFuncs(Foam::polyMesh const&)' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so: undefined reference to `Foam::cellDistFuncs::correctBoundaryFaceCells(Foam::HashSet<int, Foam::Hash<int> > const&, Foam::Field<double>&, Foam::Map<int>&) const' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so: undefined reference to `Foam::UIPstream::UIPstream(Foam::UPstream::commsTypes, int, Foam::DynamicList<char, 0u, 2u, 1u>&, int&, int, bool, Foam::IOstream::streamFormat, Foam::IOstream::versionNumber)' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `vtable for Foam::cyclicAMILduInterfaceField' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so: undefined reference to `vtable for Foam::compressible::turbulenceModel' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so: undefined reference to `typeinfo for Foam::compressible::turbulenceModel' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::mappedPatchBase::calcMapping() const' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `typeinfo for Foam::mappedPatchBase' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `typeinfo for Foam::cyclicAMILduInterfaceField' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::faceSet::~faceSet()' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::mappedPatchBase::calcAMI() const' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::faceSet::faceSet(Foam::polyMesh const&, Foam::word const&, int, Foam::IOobject::writeOption)' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::cyclicAMILduInterfaceField::~cyclicAMILduInterfaceField()' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so: undefined reference to `Foam::UPstream::waitRequests(int)' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::mappedPatchBase::samplePoints() const' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so: undefined reference to `Foam::UPstream::abort()' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so: undefined reference to `Foam::compressible::turbulenceModel::rhoEpsilonEff() const' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::faceSet::faceSet(Foam::polyMesh const&, Foam::word const&, Foam::HashSet<int, Foam::Hash<int> > const&, Foam::IOobject::writeOption)' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::cellSet::cellSet(Foam::polyMesh const&, Foam::word const&, Foam::IOobject::readOption, Foam::IOobject::writeOption)' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::triSurfaceTools::calcInterpolationWeights(Foam::triSurface const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<Foam::FixedList<int, 3u> >&, Foam::List<Foam::FixedList<double, 3u> >&)' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::patchWave::patchWave(Foam::polyMesh const&, Foam::HashSet<int, Foam::Hash<int> > const&, bool)' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::cellDistFuncs::getPointNeighbours(Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, int, Foam::List<int>&) const' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `typeinfo for Foam::cyclicAMILduInterface' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so: undefined reference to `Foam::cyclicAMIPolyPatch::AMI() const' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so: undefined reference to `Foam::operator<<(Foam::Ostream&, Foam::wallPoint const&)' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so: undefined reference to `Foam::compressible::turbulenceModel::destroyturbulenceModelConstructorTables()' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so: undefined reference to `Foam::UPstream::init(int&, char**&)' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::mappedPatchBase::sampleMesh() const' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so: undefined reference to `Foam::UIPstream::UIPstream(int, Foam::PstreamBuffers&)' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so: undefined reference to `Foam::cyclicAMIPolyPatch::typeName' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::coordinateSystem::coordinateSystem(Foam::word const&, Foam::Vector<double> const&, Foam::Vector<double> const&, Foam::Vector<double> const&)' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::triSurface::~triSurface()' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::mappedPatchBase::~mappedPatchBase()' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so: undefined reference to `Foam::UPstream::nRequests()' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::mappedPatchBase::mappedPatchBase(Foam::polyPatch const&, Foam::dictionary const&)' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::triSurfaceTools::delaunay2D(Foam::List<Foam::Vector2D<double> > const&)' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::mappedPatchBase::mappedPatchBase(Foam::polyPatch const&, Foam::mappedPatchBase const&)' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::mappedPatchBase::samplePolyPatch() const' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::cellDistFuncs::maxPatchSize(Foam::HashSet<int, Foam::Hash<int> > const&) const' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so: undefined reference to `Foam::cellDistFuncs::correctBoundaryPointCells(Foam::HashSet<int, Foam::Hash<int> > const&, Foam::Field<double>&, Foam::Map<int>&) const' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::mappedPatchBase::typeName' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so: undefined reference to `typeinfo for Foam::cyclicAMIPolyPatch' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so: undefined reference to `Foam::cellDistFuncs::sumPatchSize(Foam::HashSet<int, Foam::Hash<int> > const&) const' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::cyclicAMILduInterface::~cyclicAMILduInterface()' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so: undefined reference to `Foam::UPstream::addValidParOptions(Foam::HashTable<Foam::string, Foam::word, Foam::string::hash>&)' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so: undefined reference to `Foam::UPstream::exit(int)' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::cellDistFuncs::smallestDist(Foam::Vector<double> const&, Foam::polyPatch const&, int, Foam::List<int> const&, int&) const' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::coordinateSystem::writeDict(Foam::Ostream&, bool) const' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::mappedPatchBase::mappedPatchBase(Foam::polyPatch const&)' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::patchWave::~patchWave()' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::triSurface::write(Foam::fileName const&, bool) const' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so: undefined reference to `Foam::operator>>(Foam::Istream&, Foam::wallPoint&)' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so: undefined reference to `Foam::compressible::turbulenceModel::turbulenceModel(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&, Foam::word const&)' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::mappedPatchBase::write(Foam::Ostream&) const' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so: undefined reference to `Foam::UOPstream::write(Foam::UPstream::commsTypes, int, char const*, long, int)' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so: undefined reference to `Foam::compressible::turbulenceModel::turbulenceModelConstructorTablePtr_' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so: undefined reference to `Foam::cellDistFuncs::cellDistFuncs(Foam::polyMesh const&)' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::coordinateSystem::coordinateSystem(Foam::dictionary const&, Foam::objectRegistry const&)' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::cyclicAMILduInterfaceField::transformCoupleField(Foam::Field<double>&, unsigned char) const' /opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so: undefined reference to `Foam::FaceCellWaveName::debug' collect2: ld returned 1 exit status make: *** [/data1/OpenFOAM/2.1.0/platforms/linux64GccDPOpt/bin/wallHeatFluxRho] Fehler 1 What am I doing wrong? The created folder is called wallheatfluxsolid Code:
reconstructPar -latest Time -region solid wallHeatFlux -latestTime -case wallheatfluxsolid foamToVTK -latestTime -poly -region solid |
September 9, 2013, 16:03 |
#7 | |
Bruno Santos
Rep Power: 128 |
Hi Sausi,
I forgot to comment on the error output you had gotten in the first post. More specifically, this problem: Quote:
As to why it doesn't load, I don't know. But it seems to indicate that it since it did not load successfully, it is therefore not able to load up the "constSolidThermo" type. As for the latest problem, it looks like your OpenFOAM installation is not ready for compiling additional source code that is based on OpenFOAM source code. Both of these issues seem to be related. Can you detail:
Best regards, Bruno
September 11, 2013, 04:18 |
Rep Power: 13 |
Thanks for your answer. I am running OpenFOam 2.1.0 on a Suse 11.4 distribution.
Usually everything works fine but I think the way how I try to use the function wallHeatFlux is wrong. For example for using yPlusRAS utitlity I can select a region. [CODE] yPlusRAS -compressible -latestTime -region air [\CODE] But for using the wallHeatFlux utility I can't select a region. Therefore I tried to use the utitlity like explained but still I get an error. So maybe I just use it wrong. Could you please explan it again what steps I should do. Do I have to copy the folders before running the simulation or after? How should I reconstructPar my case? Should I select a region or no region? |
September 12, 2013, 06:56 |
#9 |
Rep Power: 13 |
I solved the problem. Thanks for your help!
First reconstructPar your region. Copy all the files you need in a dummy case as described before. Now you can use all the utitlitys you like. Do you know is there still a bug in the wallHeatFlux or is it working properly now? |
September 14, 2013, 12:04 |
#10 |
Bruno Santos
Rep Power: 128 |
Hi Sausi,
Are you able to reproduce this same problem with one of the OpenFOAM tutorials? Because if you are, I can test with the latest OpenFOAM 2.2.1 and 2.2.x versions. Best regards, Bruno
September 21, 2013, 07:47 |
#11 |
ali
Rep Power: 14 |
i wanted to compile the wallHeatFluxRho, but accidentally forgot to change the Make/file to wallHeatFluxRho.C. So it compiled as wallHeatFlux instead of wallHeatFluxRho. I tried to reverse the proses and compile my previous wallHeatFlux utilities. but i got this error message. Can somebody help me. (Im using OF 2.1.0) Code:
In file included from wallHeatFlux.C:56:0: createFields.H: In function ‘int main(int, char**)’: createFields.H:3:26: error: no matching function for call to ‘Foam::basicThermo::New(Foam::fvMesh&)’ createFields.H:3:26: note: candidate is: /home/azura/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/dictionary.H:238:36: note: static Foam::autoPtr<Foam::dictionary> Foam::dictionary::New(Foam::Istream&) /home/azura/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/dictionary.H:238:36: note: no known conversion for argument 1 from ‘Foam::fvMesh’ to ‘Foam::Istream&’ make: *** [Make/linuxGccDPOpt/wallHeatFlux.o] Error 1 Last edited by wyldckat; September 21, 2013 at 14:36. Reason: Added [CODE][/CODE] |
September 21, 2013, 14:39 |
#12 |
Bruno Santos
Rep Power: 128 |
Greetings abigail158,
If you get the version from here: https://github.com/shor-ty/wallHeatFluxRho - it will work without any problems. As for the problem you have got, it looks like you did not copy/edited the "Make/options" file, as exemplified here: https://github.com/shor-ty/wallHeatF...r/Make/options Best regards, Bruno
November 5, 2013, 15:00 |
#13 | |
Rep Power: 14 |
Dear All,
About how to calculate the heat flux, we can use Fourier's Law: q=-k*dT/dx There is a minus sign in this expression. But in openfoam, when the wall flux is caluclated, it seems that the minus sign is omitted like: fvc::interpolate(kappaEff*rho*Cp)*fvc::snGrad(T) So in this sense, openfoam actually returns k*dT/dx. Is this understanding correct? Thank you very much. Quote:
March 16, 2015, 11:16 |
#14 |
Rep Power: 11 |
Does anybody have a copy of wallHeatFluxLaminar ? Toby's link is broken and I am too unexperienced to create one on my own. I am working on a chtMultiRegionFoam case, but it has been just my first month on OF .
Thanks in advance |
chtmultiregion: pipe in a wall | NicolasB | OpenFOAM Running, Solving & CFD | 5 | March 23, 2012 19:22 |
