[mesh manipulation] Splitting the mesh for AMI |
Wouter
Rep Power: 12 ![]() |
Hey Everybody!
I am working for a while now with OpenFoam and like the solver a lot. There is however a problem which keeps repeating it self, and I can't figure out what I am doing wrong. I try to simulate a rotating wing using the AMI interface (I deliberately did not choose for SRF or MRF for now). I make my mesh as shown in the propellor case using this as my snappyHexMeshDict: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Which of the steps to run castellatedMesh true; snap true; addLayers false; // Geometry. Definition of all surfaces. All surfaces are of class // searchableSurface. // Surfaces are used // - to specify refinement for any mesh cell intersecting it // - to specify refinement for any mesh cell inside/outside/near // - to 'snap' the mesh boundary to the surface geometry { sphere.stl { type triSurfaceMesh; name sphere; } wing.stl { type triSurfaceMesh; name wing; } }; // Settings for the castellatedMesh generation. castellatedMeshControls { // Refinement parameters // ~~~~~~~~~~~~~~~~~~~~~ // If local number of cells is >= maxLocalCells on any processor // switches from from refinement followed by balancing // (current method) to (weighted) balancing before refinement. maxLocalCells 100000; // Overall cell limit (approximately). Refinement will stop immediately // upon reaching this number so a refinement level might not complete. // Note that this is the number of cells before removing the part which // is not 'visible' from the keepPoint. The final number of cells might // actually be a lot less. maxGlobalCells 2000000; // The surface refinement loop might spend lots of iterations refining just a // few cells. This setting will cause refinement to stop if <= minimumRefine // are selected for refinement. Note: it will at least do one iteration // (unless the number of cells to refine is 0) minRefinementCells 0; // Allow a certain level of imbalance during refining // (since balancing is quite expensive) // Expressed as fraction of perfect balance (= overall number of cells / // nProcs). 0=balance always. maxLoadUnbalance 0.10; // Number of buffer layers between different levels. // 1 means normal 2:1 refinement restriction, larger means slower // refinement. nCellsBetweenLevels 2; // Explicit feature edge refinement // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies a level for any cell intersected by its edges. // This is a featureEdgeMesh, read from constant/triSurface for now. features ( { file "sphere.eMesh"; level 4; } { file "wing.eMesh"; level 5; } ); // Surface based refinement // ~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies two levels for every surface. The first is the minimum level, // every cell intersecting a surface gets refined up to the minimum level. // The second level is the maximum level. Cells that 'see' multiple // intersections where the intersections make an // angle > resolveFeatureAngle get refined up to the maximum level. refinementSurfaces { sphere { level (4 4); faceType boundary; cellZone cylinder; faceZone cylinder; cellZoneInside inside; } wing { level (6 7); } } // Resolve sharp angles resolveFeatureAngle 30; // Region-wise refinement // ~~~~~~~~~~~~~~~~~~~~~~ // Specifies refinement level for cells in relation to a surface. One of // three modes // - distance. 'levels' specifies per distance to the surface the // wanted refinement level. The distances need to be specified in // descending order. // - inside. 'levels' is only one entry and only the level is used. All // cells inside the surface get refined up to the level. The surface // needs to be closed for this to be possible. // - outside. Same but cells outside. refinementRegions { //sphere //{ // mode inside; // levels ((1E15 3)); //} } // Mesh selection // ~~~~~~~~~~~~~~ // After refinement patches get added for all refinementSurfaces and // all cells intersecting the surfaces get put into these patches. The // section reachable from the locationInMesh is kept. // NOTE: This point should never be on a face, always inside a cell, even // after refinement. locationInMesh (0.0001 -0.005 0.0001); // Whether any faceZones (as specified in the refinementSurfaces) // are only on the boundary of corresponding cellZones or also allow // free-standing zone faces. Not used if there are no faceZones. allowFreeStandingZoneFaces false; } // Settings for the snapping. snapControls { //- Number of patch smoothing iterations before finding correspondence // to surface nSmoothPatch 3; //- Relative distance for points to be attracted by surface feature point // or edge. True distance is this factor times local // maximum edge length. tolerance 1.0; // 1.0; //- Number of mesh displacement relaxation iterations. nSolveIter 300; //- Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 5; // Feature snapping // Number of feature edge snapping iterations. // Leave out altogether to disable. nFeatureSnapIter 20; // Detect (geometric only) features by sampling the surface // (default=false). implicitFeatureSnap false; // Use castellatedMeshControls::features (default = true) explicitFeatureSnap true; // Detect features between multiple surfaces // (only for explicitFeatureSnap, default = false) multiRegionFeatureSnap false; } // Settings for the layer addition. addLayersControls { // Are the thickness parameters below relative to the undistorted // size of the refined cell outside layer (true) or absolute sizes (false). relativeSizes true; // Per final patch (so not geometry!) the layer information layers { } // Expansion factor for layer mesh expansionRatio 1.0; // Wanted thickness of final added cell layer. If multiple layers // is the thickness of the layer furthest away from the wall. // Relative to undistorted size of cell outside layer. // See relativeSizes parameter. finalLayerThickness 0.3; // Minimum thickness of cell layer. If for any reason layer // cannot be above minThickness do not add layer. // Relative to undistorted size of cell outside layer. minThickness 0.1; // If points get not extruded do nGrow layers of connected faces that are // also not grown. This helps convergence of the layer addition process // close to features. // Note: changed(corrected) w.r.t 17x! (didn't do anything in 17x) nGrow 0; // Advanced settings // When not to extrude surface. 0 is flat surface, 90 is when two faces // are perpendicular featureAngle 30; // Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 3; // Number of smoothing iterations of surface normals nSmoothSurfaceNormals 1; // Number of smoothing iterations of interior mesh movement direction nSmoothNormals 3; // Smooth layer thickness over surface patches nSmoothThickness 10; // Stop layer growth on highly warped cells maxFaceThicknessRatio 0.5; // Reduce layer growth where ratio thickness to medial // distance is large maxThicknessToMedialRatio 0.3; // Angle used to pick up medial axis points // Note: changed(corrected) w.r.t 17x! 90 degrees corresponds to 130 in 17x. minMedianAxisAngle 90; // Create buffer region for new layer terminations nBufferCellsNoExtrude 0; // Overall max number of layer addition iterations. The mesher will exit // if it reaches this number of iterations; possibly with an illegal // mesh. nLayerIter 50; } // Generic mesh quality settings. At any undoable phase these determine // where to undo. meshQualityControls { //- Maximum non-orthogonality allowed. Set to 180 to disable. maxNonOrtho 65; //- Max skewness allowed. Set to <0 to disable. maxBoundarySkewness 20; maxInternalSkewness 4; //- Max concaveness allowed. Is angle (in degrees) below which concavity // is allowed. 0 is straight face, <0 would be convex face. // Set to 180 to disable. maxConcave 80; //- Minimum pyramid volume. Is absolute volume of cell pyramid. // Set to a sensible fraction of the smallest cell volume expected. // Set to very negative number (e.g. -1E30) to disable. minVol 1e-16; //- Minimum quality of the tet formed by the face-centre // and variable base point minimum decomposition triangles and // the cell centre. This has to be a positive number for tracking // to work. Set to very negative number (e.g. -1E30) to // disable. // <0 = inside out tet, // 0 = flat tet // 1 = regular tet minTetQuality -1; // 1e-30; //- Minimum face area. Set to <0 to disable. minArea -1; //- Minimum face twist. Set to <-1 to disable. dot product of face normal // and face centre triangles normal minTwist 0.01; //- Minimum normalised cell determinant // 1 = hex, <= 0 = folded or flattened illegal cell minDeterminant 0.001; //- minFaceWeight (0 -> 0.5) minFaceWeight 0.05; //- minVolRatio (0 -> 1) minVolRatio 0.01; //must be >0 for Fluent compatibility minTriangleTwist -1; // Advanced //- Number of error distribution iterations nSmoothScale 4; //- Amount to scale back displacement at error points errorReduction 0.75; // Optional : some meshing phases allow usage of relaxed rules. // See e.g. addLayersControls::nRelaxedIter. relaxed { //- Maximum non-orthogonality allowed. Set to 180 to disable. maxNonOrtho 75; } } // Merge tolerance. Is fraction of overall bounding box of initial mesh. // Note: the write tolerance needs to be higher than this. mergeTolerance 1e-6; // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object createPatchDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Do a synchronisation of coupled points after creation of any patches. // Note: this does not work with points that are on multiple coupled patches // with transformations (i.e. cyclics). pointSync false; // Patches to create. patches ( { //- Master side patch name AMI1; patchInfo { type cyclicAMI; matchTolerance 0.0001; neighbourPatch AMI2; transform noOrdering; } constructFrom patches; patches (sphere); } { //- Slave side patch name AMI2; patchInfo { type cyclicAMI; matchTolerance 0.0001; neighbourPatch AMI1; transform noOrdering; } constructFrom patches; patches (sphere_slave); } ); // ************************************************************************* // The problem is now that when I rotate my mesh the inner AMI (AMI2) has points in the outer AMI creating stretched cells (as shown in the attached image). Does anybody know where I went wrong? I am using OpenFoam 3.0x by the way. Thank you in advance! |
Retired Super Moderator
Bruno Santos
Rep Power: 128 ![]() ![]() ![]() ![]() ![]() ![]() |
Greetings Wouter,
I've got the feeling that this is a bug in OpenFOAM or that something went wrong in the mesh generation step. Can you please share the case you have, but without the wing inside it, so that I or anyone else can test it more easily? Best regards, Bruno
Wouter
Hey wyldckat
I have solved the problem by meshing the inner and the outer part separate and using mergmesh to merge both meshes. So I think the problem lies complete in the meshing part. I have added my case files to this post. I hope it helps! I have used a cylinder in this case since the sphere is to big for the upload! Wouter |
Bruno Santos
Hi Wouter,
Many thanks for the test case! Can you please tell me which commit you're using from 3.0.x? To see which one it is, run the following commands: Code:
foam git log -1 Best regards, Bruno |
Wouter
Hey Bruno,
I have not installed it using git, so I don't get a response from git. I have followed the instructions listed here : http://www.openfoam.org/download/ubuntu.php I have installed it at least 3 weeks ago. So no recent update. Wouter PS Thank you for implementing this in the code! It is really an awsome feature. |
#6 | ||
Bruno Santos
Hi Wouter,
![]() The bad commit is related to this comment and respective patch: http://www.openfoam.org/mantisbt/view.php?id=1479#c5493 - namely the patch was integrated in this commit: https://github.com/OpenFOAM/OpenFOAM...33942e88f3a855 It was reverted a few days later and recently I managed to figure out the proper fix (or at least I hope so), which is already in the latest 3.0.x. If you only get the problem with the sphere, please provide the case without the wing and sphere geometries and let me know the centre and radius of the sphere, so that I will create a new one with ParaView. Best regards, Bruno |
Wouter
Hey Bruno,
I am indeed using 3.0.0. If I use the command: Code:
moveDynamicMesh -checkAMI Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Selecting dynamicFvMesh solidBodyMotionFvMesh Selecting solid-body motion function rotatingMotion Applying solid body motion to cellZone cylinder Writing VTK files with weights of AMI patches. Time = 0.001 solidBodyMotionFunctions::rotatingMotion::transformation(): Time = 0.001 transformation: ((0 0 0) (0.955336 (0 0.29552 0))) --> FOAM Warning : From function solidBodyMotionFvMesh::update() in file solidBodyMotionFvMesh/solidBodyMotionFvMesh.C at line 237 Did not find volVectorField U Not updating Uboundary conditions. solidBodyMotionFunctions::rotatingMotion::transformation(): Time = 0.001 transformation: ((0 0 0) (0.955336 (0 0.29552 0))) Point usage OK. Upper triangular ordering OK. Topological cell zip-up check OK. Face vertices OK. Face-face connectivity OK. Mesh topology OK. Boundary openness (-1.71547e-16 5.89183e-17 3.35615e-17) OK. ***High aspect ratio cells found, Max aspect ratio: 1.11519e+93, number of cells 1 Minimum face area = 2.14152e-09. Maximum face area = 8.42446e-07. Face area magnitudes OK. ***Zero or negative cell volume detected. Minimum negative volume: -4.27564e-12, Number of negative volume cells: 1 Mesh non-orthogonality Max: 129.19 average: 9.75379 *Number of severely non-orthogonal (> 70 degrees) faces: 2. ***Number of non-orthogonality errors: 3. ***Error in face pyramids: 6 faces are incorrectly oriented. ***Max skewness = 4.22197, 1 highly skew faces detected which may impair the quality of the results Failed 5 mesh geometry checks. Failed 1 mesh checks. Calculating AMI weights between owner patch: AMI1 and neighbour patch: AMI2 AMI: Creating addressing and weights between 19272 source faces and 19273 target faces AMI: Patch source sum(weights) min/max/average = 0.653138, 1.27705, 0.998826 AMI: Patch target sum(weights) min/max/average = 0, 1.48334, 1.00933 ExecutionTime = 6.51 s ClockTime = 6 s Wouter |
Bruno Santos
Hi Wouter,
OK, now I'm really worried. I got this instead: Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Selecting dynamicFvMesh solidBodyMotionFvMesh Selecting solid-body motion function rotatingMotion Applying solid body motion to cellZone cylinder Writing VTK files with weights of AMI patches. Time = 0.001 solidBodyMotionFunctions::rotatingMotion::transformation(): Time = 0.001 transformation: ((0 0 0) (0.955336 (0 0.29552 0))) --> FOAM Warning : From function solidBodyMotionFvMesh::update() in file solidBodyMotionFvMesh/solidBodyMotionFvMesh.C at line 237 Did not find volVectorField U Not updating Uboundary conditions. solidBodyMotionFunctions::rotatingMotion::transformation(): Time = 0.001 transformation: ((0 0 0) (0.955336 (0 0.29552 0))) Point usage OK. Upper triangular ordering OK. Topological cell zip-up check OK. Face vertices OK. Face-face connectivity OK. Mesh topology OK. Boundary openness (-6.61809e-16 -4.23473e-17 6.62949e-16) OK. Max cell openness = 3.05605e-16 OK. Max aspect ratio = 7.56945 OK. Minimum face area = 2.14152e-09. Maximum face area = 8.42241e-07. Face area magnitudes OK. Min volume = 1.48721e-13. Max volume = 7.01262e-10. Total volume = 1.59999e-05. Cell volumes OK. Mesh non-orthogonality Max: 58.5724 average: 9.75085 Non-orthogonality check OK. Face pyramids OK. Max skewness = 2.74585 OK. Mesh geometry OK. Mesh OK. Calculating AMI weights between owner patch: AMI1 and neighbour patch: AMI2 AMI: Creating addressing and weights between 19272 source faces and 19272 target faces AMI: Patch source sum(weights) min/max/average = 0.735122, 1.07488, 0.998849 AMI: Patch target sum(weights) min/max/average = 0.999911, 1.48334, 1.00955 ExecutionTime = 5.5 s ClockTime = 5 s I ran the case with the following commands: Code:
blockMesh foamJob snappyHexMesh -overwrite createPatch -overwrite moveDynamicMesh -checkAMI Code:
stopAt nextWrite; Because my suspicion is regarding a possible problem with a specific build... which once in a while happens due to a compiler flaw/bug. Best regards, Bruno |
#9 |
Wouter
Hey Bruno,
Where do I find the exact build number? I am running it on Ubuntu 15.10. I have tested it on two different computers both running Ubuntu 15.10, both giving the exact same problems. I am running the same commands as your are running, except I am running: Code:
decomposePar mpirun -np 2 snappyHexMesh -parallel reconstructParMesh createPatch -overwrite moveDynamicMesh -checkAMI Thank you for all your help! Wouter |
#10 | ||
Bruno Santos
Hi Wouter,
The exact version is given by any application that is executed from OpenFOAM. For example: Code:
blockMesh -help Code:
Using: OpenFOAM-3.0.0 (see www.OpenFOAM.org) Build: 3.0.0-6abec57f5449 Quote:
![]() Oh, definitely... Wow! OK, I managed to reproduce the error with the steps you've pointed out! Now, let me see if OpenFOAM-3.0.x does it better... nope. Same problem. OK, I've ran with the latest OpenFOAM-history - https://github.com/OpenCFD/OpenFOAM-history - and it didn't give me any problems for the same situations that would break when using 3.0.0 and 3.0.x. So my question to you now is this: Can we use this test case for reporting this issue on the bug tracker? Because this means that the missing code has to be ported from OpenFOAM-history to OpenFOAM-dev/3.0.x and I/we can use this case for testing if things work as intended. Best regards, Bruno |
#11 |
Wouter
Hey Bruno,
I am sort of happy that you've gotten the same error. Are the steps wrong that I took? My build number is: Code:
Using: OpenFOAM-3.0.0 (see www.OpenFOAM.org) Build: 3.0.0-8b097f6d8dd9 Wouter |
#12 | ||
Bruno Santos
Hi Wouter,
Well, they are not wrong, it's a flaw in snappyHexMesh. The workaround until the bug is fixed is for you to mesh in serial mode instead of parallel mode. In other words, to use the same commands I did. Quote:
Please provide as much information as possible (related to reproducing the bug), along with the test case. Add a link to this thread only as a fallback, in case you feel like you might have missed some details. I'll come by the bug tracker as soon as I can, in case you miss any details and to add more details as I find more about this issue. Best regards, Bruno |
#13 |
Wouter
hey Bruno,
I will add this bug to the bug tracker. The problem is also found when meshing in serial (not in this case, but in other cases it was irrelevant if I used serial or parallel compuation). Thank you for your help! Wouter |
#14 |
Bruno Santos
Hi Wouter,
Many thanks for reporting this! I see you reported it here: http://www.openfoam.org/mantisbt/view.php?id=1936 I'll try to take a look into this starting today and in the next couple of days. Nonetheless, in the meantime, can you please also provide the test case that fails when running in serial mode? Best regards, Bruno |
#15 |
Wouter
Hey Bruno,
This week is very busy at work, I hope to give you a case which fails this weekend! I will share it through dropbox, since the forum upload is to small. Wouter |
#16 | |
Bruno Santos
Hi Wouter,
The forum has a limit of 200kB. If the package is 2MB or less, I believe the bug tracker can handle it. Best regards, Bruno |
#17 |
Smrutimaya Pattanaik
Rep Power: 0 ![]() |
Thank you both, nice discussion. It helped me to settle the case.
#18 |
Meshing with snappy one one processor solved my problem of AMI weight going to zero.
This bug has to be reported |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[ICEM] 2D hybrid mesh (unstructured mesh highly dependent on structured mesh parameters) | shubham jain | ANSYS Meshing & Geometry | 1 | April 10, 2017 05:03 |
[snappyHexMesh] Snappyhex mesh: poor inlet mesh | Swagga5aur | OpenFOAM Meshing & Mesh Conversion | 1 | December 3, 2016 16:59 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
