[Other] Trying to understand checkMesh errors
Like Tree45Likes
  • 3 Post By derekm
  • 32 Post By franjo_j
  • 2 Post By Astrodan
  • 4 Post By Astrodan
  • 4 Post By franjo_j
Old   March 9, 2015, 13:50
Question Trying to understand checkMesh errors
Alex
zfaraday will become famous soon enough
Hi all,
I'm doing some tests with a geometry that is giving me some troubles according to what checkMesh says. This are the errors that the utility finds (using -allTopology -allGeometry options):
 ***Cells with small determinant (< 0.001) found, number of cells: 570
  <<Writing 570 under-determined cells to set underdeterminedCells
 ***Concave cells (using face planes) found, number of cells: 424
  <<Writing 424 concave cells to set concaveCells
    Face interpolation weight : minimum: 0.007427217 average: 0.4584105
 ***Faces with small interpolation weight (< 0.05) found, number of faces: 608
  <<Writing 608 faces with low interpolation weights to set lowWeightFaces
    Face volume ratio : minimum: 0.005415454 average: 0.8586378
 ***Faces with small volume ratio (< 0.01) found, number of faces: 304
  <<Writing 304 faces with low volume ratio cells to set lowVolRatioFaces
I would like to know what these errors exactly mean and how can they affect to the final result. I think that the concave cells are not a problem in my case taking into account all the information I've found out in the forum, but the other errors I have no clue what they mean nor how to solve them if its impact on the result is really significant.
Any hint about it will be much appreciated!
Regards,
Alex
Web site where I present my Master's Thesis: foamingtime.wordpress.com
The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in!
zfaraday is offline   Reply With Quote
Old   March 10, 2015, 06:19
Alexander Bartel
alexB is on a distinguished road
Hi Alex,
can you look at your mesh with paraFoam?
Perhaps you can upload a picture here somehow (Dropbox etc. desribed here http://www.cfd-online.com/Forums/ope...-get-help.html ).
I am also just at the beginning of learning OF, so the errors dont mean much to me.
Greetings
Alex
alexB is offline   Reply With Quote
Old   March 10, 2015, 07:49
Alex
Hi Alex,
The reason why I didn't upload any picture of my geometry is that the only think I want is to have a better understanding of this errors, I mean the theoretical background behind them so that I can detect more easily the cells/faces and how to proceed to correct the mesh on my own.
Greetings,
Alex
Old   March 19, 2015, 11:30
Timm Severin
Astrodan is on a distinguished road
I can't help there either, but I have quite similar problems and would be interested.
However, maybe given images might help identify the "physical" problem, so I attached images for four different errors that occur in
checkMesh -allGeometry -allTopology
Result (excerpt):
    Face-face connectivity OK.
  <<Writing 117 cells with two non-boundary faces to set twoInternalFacesCells
    Number of regions: 1 (OK).
    Cell determinant (wellposedness) : minimum: 0 average: 109.741
 ***Cells with small determinant (< 0.001) found, number of cells: 117
  <<Writing 117 under-determined cells to set underdeterminedCells
 ***Concave cells (using face planes) found, number of cells: 4498
  <<Writing 4498 concave cells to set concaveCells
    Face interpolation weight : minimum: 0.0733659 average: 0.447134
    Face interpolation weight check OK.
    Face volume ratio : minimum: 0.0011126 average: 0.821268
 ***Faces with small volume ratio (< 0.01) found, number of faces: 3884
  <<Writing 3884 faces with low volume ratio cells to set lowVolRatioFaces
Failed 3 mesh checks.
What seems to be the case is that, the twoInternalFacesCell and underdeterminedCells are identical.
I also attached the concave cells, since I have a lot of them.
To have a better overview:
I also have 10 non-orthogonal cells, but I think they are not that bad, and I have a pretty good idea how to remove them.
Furthermore, for the mesh generation process, which I'm sure is quite important:
  1. I Created the geometry with four regions (different mesh structures in screenshots) in ANSYS Meshing
    1. The left and both right parts are structured meshes, with some refinement done towards the walls
    2. the center part contains some ugly geometry, and the hex mesh tended to be messy, so I but a tet-mesh here.
  2. Export the mesh as ACSII-msh
  3. Import in OpenFOAM using fluent3DMeshToFoam
  4. Merge all boundaries that are the same (e.g. walls) for different regions using createPatch utility
  5. Stitch the regions using the stitchMesh utitiliy
  6. Remove empty patches with the createPatch utility
So, if anyone has ideas what is going on there, I'd (we'd) appreciate help. And I hope you don't mind me using you thread, Alex .
PhD Student at the Institute of Biochemical Engineering at TU München
Modelling of fluid dynamics in open photobioreactors.
System:
OpenFOAM 2.3.x, 64bit, 8 Core Xeon Workstation
Astrodan is offline   Reply With Quote
Old   March 23, 2015, 13:00
Derek Mitchell
derekm is on a distinguished road
Originally Posted by zfaraday View Post
Hi Alex,
Greetings,
Alex
have you read
ALGEBRAIC MESH QUALITY METRICS∗
PATRICK M. KNUPP SIAM J. SCI. COMPUT. Vol. 23, No. 1, pp. 193–218.
Derek
zfaraday, seuchsy and jadidi.cfd like this.
A CHEERING BAND OF FRIENDLY ELVES CARRY THE CONQUERING ADVENTURER OFF INTO THE SUNSET
derekm is offline   Reply With Quote
Old   March 23, 2015, 13:35
Alex
Hi Derek,
Many many many thanks for your information! I totally ignored the existence of this paper and I think it is exactly what I needed!
Again, thanks for sharing so useful information!
Best regards,
Alex
Old   March 24, 2015, 04:05
Franjo Juretic
franjo_j is on a distinguished road
Send a message via Skype™ to franjo_j
These errors do not mean that you mesh is invalid, it just tells that it may cause problems to the numerics in the following ways:
1. Small determinants - generally this mean that the volume of some cells is very small compared to their area and that they are nearly planar or collinear. I would not expect convergence problems if these cells were in the right locations (and aligned with the gradient of the solution).
2. Concave cells - are a consequence of non-flat faces, and in general it does not cause convergence problems. It does affect accuracy, but it is not too worrying when it is difficult to generate any mesh in the first place.
3. Interpolation weights - are important for the convection term and implicitly for the diffusion term. Low weights mean that one of cell at a face dominates over the other. This is not a problem when the solution is uniform, and severely reduces accuracy and convergence is case of non-uniform fields.
4. Volume ratio - is important for the source terms and the pressure equation. Again, it might be a problem if the solution is not uniform at that location.
I hope this adds some value so that you can understand these quality metrics better. These are my experiences when dealing with adaptive refinement with high aspect ratio cells.
Regards,
Franjo
jhoepken, akidess, Tobi and 29 others like this.
franjo_j is offline   Reply With Quote
Old   March 24, 2015, 09:30
Alex
Hello Franjo,
Regards,
Franjo
Wow! Thanks for this detailed and complete explanation! That was exactly what I needed!
However, I thought that the small determinant issue was an important point to take into account as Bruno Santos "wyldcat" suggested here in the forum in some other thread...
Again, thanks for taking your time with this very good answer!
Best regards,
Alex
Old   March 24, 2015, 09:35
Timm Severin
As marango say here underdetermined cells apparently can also occur when they have multiple boundary faces, so maybe that is your problem, too.
Apart from that, thanks Franjo for the explanation. As helpful as the Paper might be, it is far too complex for me to understand any time soon..
kyushusamurai and hogsonik like this.
System:
Old   May 4, 2015, 13:02
Smile
Howar
Howard is on a distinguished road
Result (excerpt):
Hi, friend. Could I ask how to see the bad cells or points in paraview? I also have these problem. Thank you!
Howard is offline   Reply With Quote
Old   May 6, 2015, 05:31
Timm Severin
If you execute checkMesh it writes you cellSets with the erroneous cells in your polyMesh directory.
If you then view your case with paraFoam you can mark the checkbox "include sets" and choose the generated sets in the same list where you find the boundary conditions etc..
If you open the case twice in the same paraFoam window, you can use one instance to display the internal mesh (wired) and one to display the bad cells in surface rendering with a colour of your choice.
System:
Old   February 10, 2016, 03:00
Default checkMesh error!!
  #12
ravi
ark704 is on a distinguished road
Hi all,
I have converted a fluent mesh (made in ICEM) to Openfoam format. I am facing 2 errors :
1. I am getting twoInernalfacecells problem at the edges of the geometry which is resulting in small determinant problem too.
2. underdetermined cells (<0.001).
The above problems were not shown in ICEM Quality patterns. How do I resolve this problem while meshing in ICEM?
How does the openfoam solver behaves if small determinant (< 0.001) and twoInternalfacecells are present in the mesh?
ark704 is offline   Reply With Quote
Old   February 10, 2016, 08:04
Franjo Juretic
Originally Posted by ark704 View Post
Hi all,
There are some cells in the mesh that have mostly boundary faces and only two or one internal face. Do you maybe have columns of stacked hexes somewhere in the mesh?
By all means this is not an error.
As was already mentioned, cells in oneInternalFaceCells and twoInternalFaceCells are also in the set of underdetermined cells. These cells may be problematic for evaluating gradients, and it depends on the boundary conditions applied there. Solution: refine the mesh or generate a boundary layer to reduce the number of boundary faces for each cells. Once again, this does not mean that you cannot run on this mesh.
With underDetermined cells I would only expect problems with Von Neumann type of boundary conditions, otherwise it should not cause problems.
Regarding the concave cells, all arbitrary polyhedra with a few faces in the same plane are classified are concave cells. These cells are the the boundary of becoming concave, and they are still not. Therefore, this is not a problem and I would not worry much about it.
ark704, hogsonik, vivek05 and 1 others like this.
Principal Developer of cfMesh and CF-MESH+
www.cfmesh.com
Social media: LinkedIn, Twitter, YouTube, Facebook, Pinterest, Instagram
Old   November 10, 2020, 14:09
Jan Majcher
MaySea is on a distinguished road
My mesh has many faces with low interpolation weights.
Faces with small interpolation weight (< 0.05) found, number of faces: 141
Is there a way to reduce this with snappyHexMeshDict?
I confirm that these faces cause convergence (convection) problems... my simulations keep blowing up with this mesh.
Thanks,
Jan
MaySea is offline   Reply With Quote
Old   November 11, 2020, 09:52
Jan Majcher
I fixed the problem by simply adding more layers.
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 14:21
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 06:28
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
