October 12, 2011, 08:07 |
System OpenMPI on RHEL Cluster
Rep Power: 16 |
Hi all,
I am trying to get OF 2.0.1 to run on our RHEL cluster. However, I am facing issues when trying to compile OF with the SYSTEMOPENMPI setting. I have changed to SYSTEMOPENMPI in the bashrc. However, when I source it I get: Code:
/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64/crt1.o: In function `_start': (.text+0x20): undefined reference to `main' collect2: ld returned 1 exit status /usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64/crt1.o: In function `_start': (.text+0x20): undefined reference to `main' collect2: ld returned 1 exit status export MPI_HOME=/opt/platform_mpi/ export MPI_ARCH_PATH=/opt/platform_mpi/ But I am getting the following error when compiling: Code:
======================================== Done ThirdParty Allwmake ======================================== + wmakePrintBuild -check no git description found + /bin/rm -f OpenFOAM/Make/linux64Gcc44DPOpt/global.C OpenFOAM/Make/linux64Gcc44DPOpt/global.o + wmakeLnInclude OpenFOAM + wmakeLnInclude OSspecific/POSIX + Pstream/Allwmake + wmake libso dummy '/opt/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64Gcc44DPOpt/lib/dummy/libPstream.so' is up to date. + case "$WM_MPLIB" in + set +x Note: ignore spurious warnings about missing mpicxx.h headers wmake libso mpi /usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64/crt1.o: In function `_start': (.text+0x20): undefined reference to `main' collect2: ld returned 1 exit status /usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64/crt1.o: In function `_start': (.text+0x20): undefined reference to `main' collect2: ld returned 1 exit status Thanks |
October 12, 2011, 17:34 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi pizzaice,
I don't know any better way to say this, but that doesn't look good... not good at all. According to your description and the error messages, it would seem that you have incompatible binaries running in your environment. My first guess would be the MPI binaries, namely mpirun that isn't built properly for your system. What happens when you run mpirun in a terminal? Does it give out the same error you've gotten? Another big problem is that Gcc 4.1.2 does not work with OpenFOAM! At least not without some serious tinkering... You'll have to request your system administrator to install another Gcc version more recent than 4.3.2. Another possibility, since you are using RHEL, is the CentFOAM project: http://sourceforge.net/apps/mediawik...itle=Main_Page Best regards and good luck! Bruno
November 16, 2011, 12:57 |
Rep Power: 16 |
Hi Bruno,
Thanks very much for the advice. Yes, you were right, it was an issue with openmpi.. I have now used gcc45 to build the sources and a newly compiled openmpi .. This seems to have fixed the issue! Thanks again and happy foaming :-) Chris |
October 26, 2012, 11:25 |
compile 2.1.x with SYSTEMOPENMPI
Kevin Maki
Rep Power: 17 |
I have a similar problem compiling openfoam 2.1.x on a cluster using the SYSTEMOPENMPI. Everything compiles except for the Pstream. Here is the output from the Allwmake in the src/Pstream directory:
login2$ ./Allwmake + wmake libso dummy '/work/02220/kjmaki/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/dummy/libPstream.so' is up to date. + case "$WM_MPLIB" in + set +x Note: ignore spurious warnings about missing mpicxx.h headers wmake libso mpi /usr/lib/../lib64/crt1.o: In function `_start': (.text+0x20): undefined reference to `main' collect2: ld returned 1 exit status /usr/lib/../lib64/crt1.o: In function `_start': (.text+0x20): undefined reference to `main' collect2: ld returned 1 exit status /usr/lib/../lib64/crt1.o: In function `_start': (.text+0x20): undefined reference to `main' collect2: ld returned 1 exit status SOURCE=UOPwrite.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -DOMPI_SKIP_MPICXX -IlnInclude -I. -I/work/02220/kjmaki/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude -I/work/02220/kjmaki/OpenFOAM/OpenFOAM-2.1.x/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOptSYSTEMOPENMPI/UOPwrite.o UOPwrite.C:29:17: error: mpi.h: No such file or directory In file included from UOPwrite.C:32: PstreamGlobals.H:55: error: ‘MPI_Request’ was not declared in this scope PstreamGlobals.H:55: error: template argument 1 is invalid PstreamGlobals.H:55: error: invalid type in declaration before ‘;’ token UOPwrite.C: In static member function ‘static bool Foam::UOPstream::write(Foam::UPstream::commsTypes, int, const char*, std::streamsize, int)’: UOPwrite.C:61: error: ‘MPI_PACKED’ was not declared in this scope UOPwrite.C:64: error: ‘MPI_COMM_WORLD’ was not declared in this scope UOPwrite.C:65: error: ‘MPI_Bsend’ was not declared in this scope UOPwrite.C:81: error: ‘MPI_PACKED’ was not declared in this scope UOPwrite.C:84: error: ‘MPI_COMM_WORLD’ was not declared in this scope UOPwrite.C:85: error: ‘MPI_Send’ was not declared in this scope UOPwrite.C:97: error: ‘MPI_Request’ was not declared in this scope UOPwrite.C:97: error: expected ‘;’ before ‘request’ UOPwrite.C:103: error: ‘MPI_PACKED’ was not declared in this scope UOPwrite.C:106: error: ‘MPI_COMM_WORLD’ was not declared in this scope UOPwrite.C:107: error: ‘request’ was not declared in this scope UOPwrite.C:108: error: ‘MPI_Isend’ was not declared in this scope UOPwrite.C:115: error: request for member ‘size’ in ‘Foam::PstreamGlobals:utstandingRequests_’, which is of non-class type ‘int’ UOPwrite.C:119: error: request for member ‘append’ in ‘Foam::PstreamGlobals:utstandingRequests_’, which is of non-class type ‘int’ make: *** [Make/linux64GccDPOptSYSTEMOPENMPI/UOPwrite.o] Error 1 I have tried to customize the settings.sh file to properly set the PLIBS and PINC variables. My system-version of mpicc does not have --showme:compile and --showme:link options, so I have used the mpicc -compile-info to generate the paths to include and library directories and compiler flags. This is how my settings.sh file appears: export FOAM_MPI=openmpi-system # Set compilation flags here instead of in wmake/rules/../mplibSYSTEMOPENMPI #kjm export PINC="`mpicc --showme:compile`" #kjm export PLIBS="`mpicc --showme:link`" export PINC=-I/opt/apps/gcc4_4/mvapich2/1.6/include export PLIBS='-L/opt/apps/gcc4_4/mvapich2/1.6/lib -L/opt/apps/limic2/0.5.4//lib -L/opt/ofed/lib64/ -lmpich -lopa -llimic2 -lpthread -lrdmacm -libverbs -libumad -ldl -lrt' #kjm libDir=`echo "$PLIBS" | sed -e 's/.*-L\([^ ]*\).*/\1/'` libDir=/opt/apps/gcc4_4/mvapich2/1.6/lib # Bit of a hack: strip off 'lib' and hope this is the path to openmpi # include files and libraries. export MPI_ARCH_PATH="${libDir%/*}" export MPI_HOME=MPI_ARCH_PATH Any help is greatly appreciated! Thanks! Kevin |
October 26, 2012, 19:43 |
#5 | |
Bruno Santos
Rep Power: 128 |
Greetings Kevin,
From the output you've provided, it looks like you didn't update the shell environment for it to reflect the changes you've made to "settings.sh". I say this because the following line of output does not show your custom settings: Quote:
echo $PINC echo $PLIBS Bruno
October 27, 2012, 09:29 |
Kevin Maki
Rep Power: 17 |
Thanks for your interest Bruno,
I have checked that the values of the shell env variables are as I set them in the settings.sh file. It still doesnt work. When I look in the Pstream/mpi/Make/options file, I see that I need a PFLAGS variable. When I echo $PFLAGS, it is empty. I grep for PFLAGS in the etc directory, and I don't see where it is set. Do you think this is what is causing my problem? |
October 27, 2012, 12:57 |
Bruno Santos
Rep Power: 128 |
Hi Kevin,
"PFLAGS" is loaded via these two lines on the "Make/options" file: Code:
sinclude $(GENERAL_RULES)/mplib$(WM_MPLIB) sinclude $(RULES)/mplib$(WM_MPLIB) Code:
# use the system installed openmpi - mpicc must be installed PFLAGS = -DOMPI_SKIP_MPICXX PINC = $(shell mpicc --showme:compile) PLIBS = $(shell mpicc --showme:link) Best regards, Bruno
October 28, 2012, 09:13 |
Kevin Maki
Rep Power: 17 |
Thanks for the hand Bruno,
Your suggestion was necessary for me to get it to work. I also had the issue that the -showme:compile option is not available for the mpicc on this cluster. The -compile-info option is a close alternative, although the output with this flag includes extra info. Also, the 'mpicc -compile-info' and 'mpicc -link-info' commands produce the exact same output. Is this normal? I was able to test a parallel case, and it ran, although it has error messages on exit that I suspect may be due to me incorrectly specifying the PINC and PLIBS variables. End Finalising parallel run interFoam: /home1/0000/build/admin/rpms/lonestar42/BUILD/mvapich2-1.6/src/mpid/ch3/channels/common/src/memory/mem_hooks.c:160: mvapich2_mfin: Assertion `1 == mem_hook_init' failed. interFoam: /home1/0000/build/admin/rpms/lonestar42/BUILD/mvapich2-1.6/src/mpid/ch3/channels/common/src/memory/mem_hooks.c:160: mvapich2_mfin: Assertion `1 == mem_hook_init' failed. interFoam: /home1/0000/build/admin/rpms/lonestar42/BUILD/mvapich2-1.6/src/mpid/ch3/channels/common/src/memory/mem_hooks.c:160: mvapich2_mfin: Assertion `1 == mem_hook_init' failed. interFoam: /home1/0000/build/admin/rpms/lonestar42/BUILD/mvapich2-1.6/src/mpid/ch3/channels/common/src/memory/mem_hooks.c:160: mvapich2_mfin: Assertion `1 == mem_hook_init' failed. ================================================== =================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = EXIT CODE: 6 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES ================================================== =================================== APPLICATION TERMINATED WITH THE EXIT STRING: Aborted (signal 6) |
October 28, 2012, 13:57 |
#9 |
Bruno Santos
Rep Power: 128 |
Hi Kevin,
I suggest that you check the other files for ideas on how to configure "PINC" and "PLIBS": Code:
ls -l $WM_PROJECT_DIR/wmake/rules/General/mplib* Said fix is this one: https://github.com/OpenFOAM/OpenFOAM...10f50d61d5793e Best regards, Bruno
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 19:56 |
What is the best cluster file system to go with OF | sampaio | OpenFOAM Installation | 4 | March 17, 2011 05:10 |
How to install OpenFOAM15dev on RHEL AS3 cluster | waynezw0618 | OpenFOAM Installation | 0 | February 26, 2009 11:10 |
How to install OpenFOAM15dev on RHEL AS3 cluster | waynezw0618 | OpenFOAM Installation | 0 | February 26, 2009 11:04 |
Installation on a cluster running a queueing system PBS | sampaio | OpenFOAM Installation | 12 | June 20, 2005 18:16 |
