ParaFoam error could not find a decent visual
Like Tree5Likes
  • 5 Post By preichl
Old   March 1, 2009, 01:51
Default I have compiled Qt 4.3.5 and t
David Lee
davidlee is on a distinguished road
I have compiled Qt 4.3.5 and therefore, paraview 3.3 and PV3FoamReader modules.
when running the paraFoam or paraview, for that matter, It shows the paraview window but in less than 3 seconds, it disappears. On the terminal window it displays the following:
[Yusuf@f9 cavity]$ paraFoam
ERROR: In /home/Yusuf/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXOpenGLRenderWi ndow.cxx, line 398
vtkXOpenGLRenderWindow (0x7f8270db95f0): Could not find a decent visual
X Error: BadValue (integer parameter out of range for operation) 2
Extension: 143 (Uknown extension)
Minor opcode: 3 (Unknown request)
Resource id: 0x21
ERROR: In /home/Yusuf/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXOpenGLRenderWi ndow.cxx, line 623
vtkXOpenGLRenderWindow (0x7f8270db95f0): Cannot create GLX context. Aborting.
/home/Yusuf/OpenFOAM/OpenFOAM-1.5/bin/paraFoam: line 83: 5491 Aborted paraview --data=$caseFile
Any clue?
Thanks in advance.
davidlee is offline   Reply With Quote
Old   March 1, 2009, 04:42
Default Dear David, I have exactly
stephane sanchi
openfoam_user is on a distinguished road
Dear David,
I have exactly the same problem. And I don't know how to solve it !
So for the moment I don't use no more the ParaView3.3-cvs version but ParaView3.4. After having solved a problem (with icoFoam for example) I use the command 'foamToVTK'. Then I launch paraview and open VTK files.
Let me know if you find how to solve the paraFoam problem. Thanks in advance.
Stephane
openfoam_user is offline   Reply With Quote
Old   April 3, 2010, 04:13
Wink Cannot run paraview
Afiq Mohd Laziz
afiq is on a distinguished road
Dear All,
I also have exact problem as you guys, but unfortunately, everytime when I try to search in the forum, there are not actually solved.
But this time, I think I have solved the problem (for myself). The problem is with the display. Before I solved the problem, I didn't realize that my display device was not activated/installed (in my uBuntu) which I use nVidia. After I activated or install the device, the problem is solved. Not more warning, and I can use the paraview as usual now.
Good luck!
afiq is offline   Reply With Quote
Old   October 14, 2010, 02:12
Paul Reichl
preichl is on a distinguished road
I had similar errors when connecting via ssh to the machine running paraview (even with paraview 3.8.1).
Setting the environment variable via the command below worked for me.
export LIBGL_ALWAYS_INDIRECT=y
I tried this after reading http://ubuntuforums.org/showthread.php?t=1098568
Hope this helps anyone else in the same boat.
preichl is offline   Reply With Quote
ParaFoam error with raw chegdan OpenFOAM Bugs 2 July 18, 2009 15:47
[OpenFOAM] Error in paraFoam mattlee ParaView 2 June 29, 2009 16:36
Error in paraFoam mattlee OpenFOAM Installation 0 March 1, 2009 22:34
[OpenFOAM] ParaFoam Error navaladi ParaView 13 April 22, 2008 17:01
[OpenFOAM] ParaFoam Error jblucca ParaView 1 June 28, 2007 03:37
