[foam-extend.org] core dumped for foam extended 3.2 on Ubuntu 16.04
Like Tree4Likes
  • 1 Post By wyldckat
  • 1 Post By qjh888
Old   September 15, 2016, 09:26
Default core dumped for foam extended 3.2 on Ubuntu 16.04
Janry
qjh888 is on a distinguished road
Hi Foamers,
Recently I've install the foam -extended 3.2 on Ubuntu 16.04.
However, when I run the cases and tutorials, all of them crashed with no reason core dumped.
For example:
uqjqi@uqjqi:~/Desktop/work/11_09_2016_Stage$ icoFoam
| \\      /  F ield         | foam-extend: Open Source CFD                    |
|  \\    /   O peration     | Version:     3.2                                |
|   \\  /    A nd           | Web:         http://www.foam-extend.org         |
|    \\/     M anipulation  | For copyright notice see file Copyright         |
Build    : 3.2-334ba0562a2c
Exec     : icoFoam
Date     : Sep 15 2016
Time     : 22:13:06
Host     : uqjqi
PID      : 12610
CtrlDict : "/home/uqjqi/Desktop/work/11_09_2016_Stage/system/controlDict"
Case     : /home/uqjqi/Desktop/work/11_09_2016_Stage
nProcs   : 1
SigFpe   : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 1.653947e-06
Floating point exception (core dumped)
and
uqjqi@uqjqi:~/Desktop/work/11_09_2016_Stage$ steadyCompressibleMRFFoam
Exec     : steadyCompressibleMRFFoam
Date     : Sep 15 2016
Time     : 22:12:55
Host     : uqjqi
PID      : 12606
nProcs   : 1
Create time
can anybody help me out?
Thanks!
Janry
qjh888 is offline   Reply With Quote
Old   September 17, 2016, 09:39
Retired Super Moderator
Bruno Santos
Quick answer: Your description is a bit inconsistent, because you mentioned that the tutorial cases crash, but then you provide the output for a case that is not part of the tutorials.
Please provide the output you get when you run one of the foam-extend 3.2 tutorials cases.
And/or please provide the file "system/controlDict", in which I'm guessing that you have a "libs" entry there that is forcing to load libraries that were last built for another version of foam-extend or OpenFOAM.
qjh888 likes this.
Old   September 17, 2016, 09:49
Janry
Hi Bruno,
Thanks for your reply!
The following is the tutorial for the axialTurbin_mixingPlane:
uqjqi@uqjqi:~/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_mixingPlane$ ./Allrun
Running blockMesh on /home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_mixingPlane
Exec     : transformPoints -scale (1 20 1)
Date     : Sep 17 2016
Time     : 22:44:15
Host     : uqjqi
PID      : 7592
CtrlDict : "/home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_mixingPlane/system/controlDict"
Case     : /home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_mixingPlane
nProcs   : 1
Create time
Scaling points by (1 20 1)
Writing points into directory "/home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_mixingPlane/constant/polyMesh"
Exec     : transformPoints -cylToCart ((0 0 0) (0 0 1) (1 0 0))
Date     : Sep 17 2016
Time     : 22:44:15
Host     : uqjqi
PID      : 7593
nProcs   : 1
Create time
Running setSet on /home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_mixingPlane
Running setsToZones on /home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_mixingPlane
Running MRFSimpleFoam on /home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_mixingPlane
And the log for the solvers:
Exec     : MRFSimpleFoam
Date     : Sep 17 2016
Time     : 22:44:16
Host     : uqjqi
PID      : 7599
nProcs   : 1
Create time
Create mesh for time = 0
Same conditions occuring everywhere...
Another is the axialTurbin_ggi:
uqjqi@uqjqi:~/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_ggi$ ./Allrun
Running blockMesh on /home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_ggi
Date     : Sep 17 2016
Time     : 22:48:16
Host     : uqjqi
PID      : 7811
CtrlDict : "/home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_ggi/system/controlDict"
Case     : /home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_ggi
nProcs   : 1
Create time
Writing points into directory "/home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_ggi/constant/polyMesh"
Date     : Sep 17 2016
Time     : 22:48:16
Host     : uqjqi
PID      : 7812
nProcs   : 1
Create time
Running setSet on /home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_ggi
Running setsToZones on /home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_ggi
Running MRFSimpleFoam on /home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_ggi
Thanks!
Janry
Old   September 17, 2016, 10:28
Bruno Santos
Quick answer: Please run this command:
ldd $(which MRFSimpleFoam)
and let me know of what it outputs.
In addition, the output of the following command is also useful:
export
Old   September 17, 2016, 23:26
Janry
export
Hi Bruno,
Thanks for your reply.
The following is the output when running the ldd $(which MRFSimpleFoam):
uqjqi@uqjqi:~/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_ggi$ ldd $(which MRFSimpleFoam)        linux-vdso.so.1 =>  (0x00007f0f492e1000)
    libincompressibleRASModels.so => /home/uqjqi/foam/foam-extend-3.2/lib/linux64GccDPOpt/libincompressibleRASModels.so (0x00007f0f48d85000)
    libincompressibleTransportModels.so => /home/uqjqi/foam/foam-extend-3.2/lib/linux64GccDPOpt/libincompressibleTransportModels.so (0x00007f0f48b03000)
    libfiniteVolume.so => /home/uqjqi/foam/foam-extend-3.2/lib/linux64GccDPOpt/libfiniteVolume.so (0x00007f0f46c03000)
    liblduSolvers.so => /home/uqjqi/foam/foam-extend-3.2/lib/linux64GccDPOpt/liblduSolvers.so (0x00007f0f4699e000)
    libfoam.so => /home/uqjqi/foam/foam-extend-3.2/lib/linux64GccDPOpt/libfoam.so (0x00007f0f45c58000)
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f0f45a29000)
    librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f0f45820000)
    libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f0f4549e000)
    libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f0f45195000)
    libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f0f44f7e000)
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f0f44bb5000)
    libincompressibleTurbulenceModel.so => /home/uqjqi/foam/foam-extend-3.2/lib/linux64GccDPOpt/libincompressibleTurbulenceModel.so (0x00007f0f4495a000)
    libmeshTools.so => /home/uqjqi/foam/foam-extend-3.2/lib/linux64GccDPOpt/libmeshTools.so (0x00007f0f444ff000)
    libmpi.so.1 => /home/uqjqi/foam/foam-extend-3.2/ThirdParty/packages/openmpi-1.6.5/platforms/linux64GccDPOpt/lib/libmpi.so.1 (0x00007f0f4415f000)
    libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f0f43f44000)
    libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f0f43d27000)
    /lib64/ld-linux-x86-64.so.2 (0x000055c53f341000)
    libdecompositionMethods.so => /home/uqjqi/foam/foam-extend-3.2/lib/linux64GccDPOpt/libdecompositionMethods.so (0x00007f0f43afb000)
    liblagrangian.so => /home/uqjqi/foam/foam-extend-3.2/lib/linux64GccDPOpt/liblagrangian.so (0x00007f0f438da000)
    libnuma.so.1 => /usr/lib/x86_64-linux-gnu/libnuma.so.1 (0x00007f0f436cf000)
    libutil.so.1 => /lib/x86_64-linux-gnu/libutil.so.1 (0x00007f0f434cb000)
Thanks again!
Janry
Old   September 18, 2016, 17:17
Bruno Santos
Quick answer: ldd did not show anything out of the ordinary. It's linking to "libnuma.so", which I wasn't familiar with, but I guess it's due to the machine you have, namely if you have a multi-socket workstation/server.
Nonetheless, you forgot to also post the output from the export command that I asked for. If the output is too long, you can run:
export > log.export
gzip < log.export > log.export.gz
and then attach the file "log.export.gz" to your next post.
Old   September 18, 2016, 20:53
Janry
export > log.export
Hi Bruno,
The export output is attached, please see the attachment.
log.export.gz
Thanks!
Janry
Old   September 26, 2016, 19:34
Bruno Santos
Quick answer: I took a look into this during this past weekend and I wasn't able to figure out a reason for this problem that you're getting.
My best guess right now is that there is something installed in the user folders.
Try the following commands, to see if they list any suspicious libraries of applications:
ls -l $FOAM_USER_LIBBIN
ls -l $FOAM_USER_APPBIN
Because beyond this, the only other thing that comes to mind is that the compiler messed up somehow...
Although, now that I think about it, what exact installation instructions did you follow?
And did you make any changes besides what the instructions indicated?
qjh888 likes this.
Old   September 26, 2016, 22:19
Janry
Hi Bruno,
Yes I think I use multiple gcc version when I installed it.
Because the default gcc version for 16.04 is 5.4, but the SIG density based solver requires gcc 4.6 to compile it.
So, after I install foam extend 3.1, I shifted to gcc 4.6 to compile the SIG density based solver, then, failed.
I think all the foam extend or the third party solvers should be installed within constant version of gcc and g++...
Thanks very much!
Janry
wyldckat likes this.
Old   September 27, 2016, 17:39
Bruno Santos
Quick answer: Yes, it's strongly advisable to use the same GCC version for building everything... I had no way to diagnose that this was a possible reason, unless I had done some wild guessing ... out of a few more dozen possible reasons...
Anyway, it's excellent that you've managed to pick up the origin of the problem!
qjh888 likes this.
[foam-extend.org] Foam Extend 3.2 in ubuntu 16.04 LTS JMosiezny OpenFOAM Installation 15 December 9, 2017 09:20
[foam-extend.org] paraview not runing? (foam extended 3.2 and ubuntu 15.04) Milan2013 OpenFOAM Installation 23 April 20, 2017 06:49
[foam-extend.org] foam-extend 3.2 on Ubuntu 12.04, Floating point exception for tutorials arsalan.dryi OpenFOAM Installation 7 November 14, 2016 18:33
solving a conduction problem in FLUENT using UDF Avin2407 Fluent UDF and Scheme Programming 1 March 13, 2015 03:02
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
