[OpenFOAM.org] [SOLVED] Some packages could not be installed in OpenFOAM 2.3.1 in Ubuntu 14.04 LTS |
April 20, 2015, 12:50 |
Rep Power: 12 |
Following the instructions for installing OpenFOAM 2.3.1 Deb pack installation: http://www.openfoam.org/download/ubuntu.php At step 3 Install OpenFOAM (231 in the name refers to version 2.3.1): sudo apt-get install openfoam231 I get the following installation problem: Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: openfoam231 : Depends: libcgal-dev but it is not going to be installed E: Unable to correct problems, you have held broken packages. Any ideas how to resolve this installation issue? Update - Followed the steps here to fix broken packages: http://www.upubuntu.com/2013/05/how-...ges-using.html Installed OK after this. Last edited by yardsail; April 20, 2015 at 13:40. Reason: Found solution |
broken, dependencies, installation, packages, unmet |
[OpenFOAM.org] Paraview not found when installing OpenFoam to Ubuntu 14.04 | tabsquare | OpenFOAM Installation | 75 | December 30, 2017 12:21 |
[OpenFOAM.org] Using OpenFOAM 2.3.0 from Deb pack in Ubuntu 14.04 + ParaView 5 from OpenFOAM 4.1 | ad2eb | OpenFOAM Installation | 12 | May 28, 2017 15:30 |
Problems with OpenFOAM 2.3.0 on Ubuntu 14.04 | smallzilla | OpenFOAM Installation | 15 | September 14, 2014 13:11 |
How to Install OpenFOAM on 64 Ubuntu 9.04 | hansel | OpenFOAM Installation | 62 | March 19, 2010 15:43 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 15:25 |
