Paraview 4.1.0 cmake compiling error CUDA Convolution Driver
Like Tree2Likes
  • 1 Post By wyldckat
  • 1 Post By Juan Carlos
Old   March 24, 2014, 21:06
Default Paraview 4.1.0 cmake compiling error CUDA Convolution Driver
Juan Carlos
Juan Carlos is on a distinguished road
Hi, All
I'm trying to build ParaView 4.1.0 from source on debian 7.0 64 bits
I'm currently using the makeParaview script that is included in OpenFOAM 2.3
When running ccmake, I get this error:
error: #error -- unsupported GNU version! gcc 4.7 and up are not supported!
CMake Error at cuda compile generated CUDA ConvolutionDriver.cu.o.cmake: 206
Thanks for reading
Juan C.
Code
In file included from /usr/lib/nvidia-cuda-toolkit/include/cuda_runtime.h:59:0,
from <command-line>:0:
/usr/include/host_config.h:82:2: error: #error -- unsupported GNU version! gcc 4.7 and up are not supported!
CMake Error at cuda_compile_generated_CUDAConvolutionDriver.cu.o. cmake:206 (message):
Error generating
/home/juan/OpenFOAM/ThirdParty-2.3.0/build/linux64Gcc/ParaView-4.1.0/Plugins/SciberQuestToolKit/SciberQuest/CMakeFiles/cuda_compile.dir//./cuda_compile_generated_CUDAConvolutionDriver.cu.o
make[2]: *** [Plugins/SciberQuestToolKit/SciberQuest/CMakeFiles/cuda_compile.dir/./cuda_compile_generated_CUDAConvolutionDriver.cu.o] Error 1
make[1]: *** [Plugins/SciberQuestToolKit/SciberQuest/CMakeFiles/vtkSciberQuest.dir/all] Error 2
make: *** [all] Error 2
Juan Carlos is offline   Reply With Quote
Old   March 30, 2014, 15:39
Retired Super Moderator
Bruno Santos
Greetings Juan,
I hope you're referring to the script makeParaView4, as the script makeParaView is meant for ParaView 3.12.0.
Well, this is a tricky situation. It depends on a few details:
  1. Do you want to build ParaView with CUDA support?
  2. If #1 is yes, then can you update the CUDA version you have installed?
  3. If #1 is yes and #2 is no, are you using a custom GCC 4.7 build or are you using Debian's GCC?
    • If you're using Debian's GCC, then you should upgrade CUDA as well.
If #1 is no... then try editing the file "ParaView-4.1.0/Plugins/SciberQuestToolKit/SciberQuest/CMakeLists.txt" and find these two lines:
if (CUDA_FOUND AND SQTK_CUDA)
if (SQTK_CUDA AND CUDA_FOUND)
And replace them with:
if (OFF AND SQTK_CUDA)
if (SQTK_CUDA AND OFF)
And then run makeParaView4 once again.
Best regards,
Bruno
waku2005 likes this.
Old   April 11, 2014, 19:04
Juan Carlos
Greetings Bruno,
I’m apologize for my delay to answer your comments about installation of
Paraview 4.1
I will try to implement your recommendations as soon as possible.
Best regards,
Juan C.
Old   April 17, 2014, 14:37
Juan Carlos
Hi, Bruno
I followed your statements about installation of Paraview 4.1.
In my particular case. I decided to build ParaView without CUDA support, to do that I modified the file “CmakeLists.txt” as you comment.
Fortunately these changes made that Paraview works properly.
Thanks for your help.
Best regards,
Juan C.
wyldckat likes this.
Compiling Paraview 3.12.0 and the PV3FoamReader Module smpark OpenFOAM Installation 2 January 9, 2012 08:16
Cmake cannot recognize gcc to compile ParaView CAVT OpenFOAM 3 July 27, 2010 21:38
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 22:41
OpenFOAM15 paraFoam bug koen OpenFOAM Bugs 19 June 30, 2009 11:46
