Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
MRFSimpleFoam: wrong boundary conditions on rotating walls
Like Tree1Likes
  • 1 Post By cves
Old   April 15, 2010, 12:37
Default MRFSimpleFoam: wrong boundary conditions on rotating walls
Christian
cves is on a distinguished road
I am using OpenFoam1.5-dev, svn version 1677, with SIG Turbomachinery add-ons in order to perform the ERCOFTAC centrifugal pump case-study. I have found that the two faceSet made for the setup of MRFSimpleFoam lead to a wrong velocity value on the rotating walls. Indeed the velocity at the wall is set to zero instead of Omega x Radius.
I have followed the instructions and setups given in the openFoam Wiki :
http://openfoamwiki.net/index.php/Si...vaned_diffuser
However, I had to decrease the k and epsilon relaxation factor value from 0.7 in the original system/fvSolution file to 0.5 in order to achieved 5000 time steps. I give you the images (U.png and linear.png) of the velocity and the convergence that I get after the 5000 time steps.
I have compared these figures with the ones given by :
http://www.tfd.chalmers.se/~hani/pdf_files/OFW4_2009_Petit_slides.pdf
which has the same setups except that the svn version is 1240. I saw that the problem comes from the wrong velocity imposed on the rotating blades as you can see the small blue lines around the rotating blades which means a zero velocity value is imposed (U_zoom.png).
I found that the mixerVessel2D has not this problem and the only difference between these two tutorials was the two faceSet for system/faceSetDict_rotorFaces and system/faceSetDict_noBoundaryFaces, which are not done in the mixerVessel2D tutorial. So I remove this two faceSet for the ERCOFTAC centrifugal pump tutorial and run 5000 times steps (see the convergence and velocity profile after 5000 time steps U_noFaceSet.png and linear_noFaceSet.png).
In this case the velocity is correct on the rotating blade but the computation converge into a non-physical result.
If someone has the solution to correct the boundary value on the rotating blades and get a well physical converged solution, please let me know.
Best regards
Christian
cves is offline   Reply With Quote
Old   April 20, 2010, 04:47
Default Correction of the ercoftacCentrifugalPump tutorial
Christian
After a few days of research, I have found a way which corrects the ercoftacCentrifugalPump tutorials and can be used as first setup for a MRFSimpleFoam case study for OpenFOAM-1.5-dev svn version greater than 1242. Indeed the faceSet are useless in these versions, OpenFOAM is able to found the faces for MRFSimpleFoam by itself.
This correction leads to a good convergence without any tuning of the relaxation factors. I have attached some pictures of my results. Moreover the converged result is physical and close to the result of:
You just have to replace the makeMesh and constant/MRFZones files of your tutorials by the ones that I have attached to this post. My files are for the stiched mesh but you can also use it for the ggi mesh by adding the ggi boundaries in the nonRotatingPatches of the MRFZones file.
Best regards
Christian
Old   April 20, 2010, 08:13
wayne.zhang
waynezw0618 is on a distinguished road
Send a message via MSN to waynezw0618 Send a message via Skype™ to waynezw0618
Also in 1.6
waynezw0618 is offline   Reply With Quote
Old   May 3, 2010, 04:38
Default GGI case
Christian
Here are the modified files to run the GGI case correctly.
Christian
File Type: txt makeMesh.txt (1,015 Bytes, 143 views)
marcelgt87 likes this.
boundary condition, centrifugal pump, mrfsimplefoam, velocity
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
inlet velocity boundary condition murali CFX 5 August 3, 2012 09:56
Boundary conditions for rotating fan rohit CFX 2 July 22, 2008 10:20
Rotating interpolated boundary condition hani OpenFOAM Running, Solving & CFD 0 July 4, 2006 08:09
Boundary Conditions Jan Ramboer Main CFD Forum 11 August 16, 1999 09:59
