k-omega and k-epsilon turbulence model. Why different? |
April 20, 2011, 03:24 |
Casey
Rep Power: 17 |
Hi all,
I am confused about the difference between the k-epsilon and k-omega turbulence models. If [math]\omega[\math] = k/, then how are the two equations so different? Can someone explain the models for me term by term and show why the k-[math]\omega[\math] model is better suited for compressible flows and modeling shear flow spreading. Why is the k-[math]\omega[\math] model less sensitive to rapid changes in mean shear rates? Thanks, Casey |
April 20, 2011, 04:44 |
Raashid Baig
Rep Power: 16 |
Thanks a lot for asking this question. I was planning to put this very question in the forum this morning since it was asked to me in an interview and I had no clue about it. I understand that an explanation to this must be given in one of those turbulence modelling books, but if some of the enlightened users can tell the answer to this question it will be great. Raashid |
April 21, 2011, 05:53 |
Raashid Baig
Rep Power: 16 |
Can some of the enlightened users give answer to this question ?
It will be very helpful. Thanks in advance, Raashid |
April 21, 2011, 23:55 |
mohammad
Rep Power: 16 |
Hi Casey, Hi Raashid,
From application point of view you can find short but good info in the following references...I remember once I tried to understand the mathematical formulation and I did it somewhat ..but it was hard....I used some online notes and articles . [About the Raashid I'm sure that he knows all of the following materials....much better than me... ] 1-search for "turbulent" keyword in CFX help manual. 2- this link also covers general info about this matter http://www.cfd-online.com/Forums/mai...ga-models.html Anyway....If you find good information I also will be happy.... |
April 25, 2011, 16:25 |
Casey
Rep Power: 17 |
Hey guys,
I wrote a paper that gives a pretty in depth analysis and was able to learn about a lot of the differences. Basically the two-equation models are empirical and contain different terms in the dissipation equation to account for high (mean velocity) strain areas. Where can I post the description in PDF format? Thanks, Casey |
April 25, 2011, 21:03 |
#6 | |
mohammad
Rep Power: 16 |
If the paper is online, simply give the web address... Otherwise I think you can upload it here as an attachement to your post. The other way is that if it's a big file, and you cant upload it here, you can upload it on such websites that are free file hosts and then share the web address ( and username and password if needed) here. Thanks and Be Happy |
April 25, 2011, 22:00 |
#7 | |
Raashid Baig
Rep Power: 16 |
As mohammad has said there are many ways of sharing the paper. If you do not want your paper to be that open you can mail your paper to selected users. Please do it as it will be very helpful in our understanding of CFD. Raashid |
April 27, 2011, 13:30 |
paper
behzad
Rep Power: 16 |
I have read the book by Wilcox who popularized the model, "Turbulence modelling in CFD".
In his book, all over, he shows how much k-omega model results are superior to the k-epsilon model in many different types of flows(near wall flows, seperated flows, ...).There is a chapter for compressible flows if you want to read. But even in that book I don't remember a term by term explanations of the differences of the modeled omega & epsilon equations. If MEANGREEN has wrote a paper about it I would very much, like to read that. |
May 4, 2011, 16:54 |
#9 |
Casey
Rep Power: 17 |
Hi everyone,
I am going to try and post the latex of the Background and theory section of my paper. I may publish some of the data. Please let me know if you want to cite any part of the paper. We can work out a "private communcation" or I can tell you the citation if I got the info from somewhere else. |
May 4, 2011, 16:55 |
#10 |
Casey
Rep Power: 17 |
I also want to point out that the Wilcox book is very good. After doing this project I would say that the k-omega model is better than the standard k-epsilon model, but that the RNG k-epsilon model is better than the Wilcox k-omega model.
May 5, 2011, 14:29 |
#11 |
Rep Power: 16 |
http://personalpages.manchester.ac.u...hydr/index.htm
Try this... there are a couple of lectures on turbulence modeling. |
July 7, 2012, 17:40 |
#12 |
Casey
Rep Power: 17 |
If anyone uses the information that I wrote in that paper, please cite me.
Thanks, Casey |
July 9, 2012, 06:25 |
#13 |
It is also strange that omega is inverse to epsilon (rate/scale of turbulence) and which means they are directly related. Still there is huge difference in results for the practice flows with both models. |
July 9, 2012, 14:43 |
#14 |
Casey
Rep Power: 17 |
The simplist explination is this: both the k-omega and k-epsilon models have many emperical terms. The k-omega model has terms that have been updated over the years. The k-omega model also has a different form of the turbulent viscosity equation. Page 5 of LaMarcheBackgroundandTheory.pdf above explains how the terms in the k-omega model make it more robust model.
Casey |
Wrong calculation of nut in the kOmegaSST turbulence model | FelixL | OpenFOAM Bugs | 27 | March 27, 2012 10:02 |
KOmega Turbulence model from wwwopenFOAMWikinet | philippose | OpenFOAM Running, Solving & CFD | 30 | August 4, 2010 11:26 |
Transition kappa omega turbulence model | mannobot | FLUENT | 0 | June 9, 2010 05:11 |
Centrifugal Pump and Turbulence Model | Michiel | CFX | 12 | January 25, 2010 04:20 |
Use of k omega turbulence model | john_w | OpenFOAM Running, Solving & CFD | 2 | September 22, 2009 06:15 |
