periodic shadow faces
Like Tree2Likes
  • 1 Post By -mAx-
  • 1 Post By -mAx-
Old   June 7, 2011, 06:31
Default periodic shadow faces
truffaldino's Avatar
truffaldino is on a distinguished road
I will be grateful if someone could explain me how to deal with periodic grids in FLUENT. I have created periodic grid in GAMBIT, where everything was going without problems, but mesh check failes in FLUENT. Could someone advice me what is the problem. I was asking people on GAMBIT sub-forum
http://www.cfd-online.com/Forums/ans...riodic-bc.html
but it seems that they cannot help.
The fluent mesh check shows non-existant (x,y)-periodic translations:
Mesh Check
Domain Extents:
x-coordinate: min (m) = 0.000000e+000, max (m) = 1.000000e+000
y-coordinate: min (m) = 0.000000e+000, max (m) = 1.000000e+000
z-coordinate: min (m) = 0.000000e+000, max (m) = 1.000000e+000
Volume statistics:
minimum volume (m3): 3.333333e-004
maximum volume (m3): 5.684532e-003
total volume (m3): 1.000000e+000
Face area statistics:
minimum face area (m2): 1.000000e-003
maximum face area (m2): 6.757963e-002
Checking number of nodes per cell.
Checking number of faces per cell.
Checking thread pointers.
Checking number of cells per face.
Checking face cells.
Checking cell connectivity.
Checking bridge faces.
Checking right-handed cells.
Checking face handedness.
Checking face node order.
Checking closed cells.
Checking contact points.
Checking element type consistency.
Checking boundary types:
Checking face pairs.
Checking wall distance.
Checking node count.
Checking nosolve cell count.
Checking nosolve face count.
Checking face children.
Checking cell children.
Checking storage.
Checking periodic boundaries.
Periodic zone 3: x-translation: min (m) = -1.284619e-001, max (m) = 2.012138e-001
y-translation: min (m) = -1.674896e-001, max (m) = 1.632244e-001
z-translation: min (m) = 1.000000e+000, max (m) = 1.000000e+000
Done.
WARNING: Mesh check failed.
Thanks in advance
Truffaldino
truffaldino is offline   Reply With Quote
Old   June 7, 2011, 08:27
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
if it can help....
Fluent side:
http://my.fit.edu/itresources/manual...ug/node262.htm
http://my.fit.edu/itresources/manual...ug/node179.htm
http://my.fit.edu/itresources/manual...ug/node180.htm
and one tutorial
http://my.fit.edu/itresources/manual.../tg/node23.htm
Gambit side:
http://my.fit.edu/itresources/manual...e/mg04.htm#777
truffaldino likes this.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   June 7, 2011, 11:20
skullCFD is on a distinguished road
There should be no problem in Fluent if periodicity is correctly defined in Gambit. I wonder if you connected the faces periodically in Gambit i.e., if you select/mesh one face, the other one should get selected/meshed automatically. Also, the order (arrow direction) of edge selection when connecting the periodic faces should be the same for both the faces. If you took care of these things already, then I am not sure if this is some other problem. As you mentioned, the extents for X and Y seem strange.
skullCFD is offline   Reply With Quote
Old   June 8, 2011, 07:09
Thanks guys, Thanks a lot mAx,
The problem is fixed and eliminated shadow faces are reordered with the help of the manual given by mAx in the link: http://my.fit.edu/itresources/manual...ug/node180.htm
Fluent command
grid modify-zones repair-periodic
eliminates unexistent translations! :
/mesh/modify-zones> repair-periodic
Periodic zone [()] periodic
Repair translational periodic zone? [yes] y
computed translation deltas: 0.000000 0.000000 1.000000
reordered 163 periodic shadow faces
I am still wandering what was wrong with GAMBIT?
Thanks again
Truffaldino
Old   July 8, 2017, 19:05
Default I can't acces to the links attached.
Luis Roa
Luis Roa is on a distinguished road
Hello everybody,
I'm having a similar problem when linking face meshes and I'm trying to acces to mAx's links but it says that I'm not allowed to acces the server. Can anyone refresh the links or upload the documents please.
Regards.
Luis Roa is offline   Reply With Quote
Old   July 10, 2017, 02:40
-mAx-'s Avatar
Maxime Perelli
https://www.sharcnet.ca/Software/Flu...ug/node262.htm
etc...
Luis Roa likes this.
Old   July 11, 2017, 00:16
Default Thanks
Luis Roa
Thank you very much mAx.
I was having problems with linking the periodic mesh faces, but I figured out that I had to uncheck the option of reverse orientation and select the correct vertex.
Regards,
Luis Carlos Roa
Old   December 14, 2019, 11:18
Default Change in repair-periodic location
Tencho
supvato is on a distinguished road
This solution worked for me.
There was a change in the location of repair-periodic, it can now be found in:
/mesh/repair-improve/repair-periodic
supvato is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 10:01
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 02:08
