☆Variable at Solid-Fluid Coupled faces
Like Tree1Likes
  • 1 Post By Conan
Old   March 23, 2009, 09:00
Default ☆Variable at Solid-Fluid Coupled faces
gnxie
Conan is on a distinguished road
Send a message via MSN to Conan
For solid-fluid coupling problem. there are two faces generated by Fluent: say, WALL and WALL-Shadow. Now, I wanna know which face does refer to fluid? WALL-Shadow?
And, the absolute value of heat-flux through these two should be the same? But I found a very small difference, NOT extractly identical. Why?
Other Variable should be identical?
vivek05 likes this.
Conan is offline   Reply With Quote
Old   April 28, 2009, 17:41
Ralf Schmidt
Ralf Schmidt is on a distinguished road
Hi!
for me, it seems to be, that fluent sets WALL and
WALL-Shadow more or less random to the fluid and the solid.
I am sure, there is a system, but I don't get it.
I see, that there is no heat flow on the surface related to the solid. Also, the yplus value is zero at that face.
Best wishes
Ralf
CFD - nothing but Colourful Fluid Dynamics
Ralf Schmidt is offline   Reply With Quote
Old   April 28, 2009, 17:52
tengra is on a distinguished road
Under boundary condition, click any of those 2 walls to define boundary conditions, and you will see it will tell you on the new pop up panel which zone (solid or fluid) it belongs to.
tengra is offline   Reply With Quote
Old   June 26, 2019, 17:03
Igor Vidic
igor_vidic is on a distinguished road
Can somebody please explain me how Fluent solve heat trsnsfer problem on coupled wall. For example I am modeling fluid flow around cylinder with energy source in it. I don understand how fluent calculate heat transfer coefficient between fluid and solid. I read that coupling wall means that heat flux is the same on boundary and its shadow zone.
igor_vidic is offline   Reply With Quote
fluid enclosed in solid domain Nishan CFX 0 November 6, 2008 10:05
modeling heat transfer betwwen fluid and solid Al Mazdeh CFX 0 March 13, 2008 11:35
fluid mass in coupled FSI system Dr. V. Kumar CFX 10 July 16, 2007 11:23
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 14, 2000 00:03
