Hershel-Bulkley viscosity
Like Tree1Likes
  • 1 Post By Anthony Wachs
Old   October 4, 2001, 06:57
Default Hershel-Bulkley viscosity
Atholl
Can anyone tell me how to go about modifying the non-Newtonian Power-Law viscosity in Fluent to include a true yield stress, which would make it a Herschel Bulkley viscosity? I know this would be via a UDF, but is there any way I can get access to the existing code for Power-Law viscosity and then modify it as a UDF? Or do I have to start a UDF from scratch myself, and if so, how? Thanks in advance
Old   October 4, 2001, 11:06
Default Re: Hershel-Bulkley viscosity
Anthony Wachs
Hi Atholl,
I have been working for a long time in the area of viscoplastic fluids and have already experienced to include this kind of models (Bingham or Helschel-Bulkley) in Fluent. Concerning that point, I have two news for you : a good one and a bad one
1. good new : implementing visoplastic fluids in Fluent works very well !! and besides is very easy to handle. You only have to write an UDF for the viscosity.
2. bad new : for confidentiality reasons (I am currently working for a private company), I cannot forward you the UDF.
Nevertheless, I encourage you to try too because you are now absolutely sure that it will work (if you trust me of course). And I can show you how to consider the model in Fluent because obviously, after a deep look in the literature, you would probably find it by yourself, so I expect that the following tips will enable you to save some time.
Consider the Bingham constitutive equation in 3D (the generalization to HB model is straightforward) :
tau=2*mu*D+(2*D/gamma)*tau_0
tau=stress tensor
mu=shear viscosity
D=rate-of-strain tensor
gamma=(second invariant of D)=sqrt(2*tr(D**2))
tau_0=yield stress
If you write this relation in terms of apparent viscosity mu_a, it yields :
mu_a=mu+tau_0/gamma
An other thing to keep in mind is that the relation tau=f(D) or tau=f(gamma) in 1D (in that case, gamma is the shear rate) is discontinuous in gamma=0 and tau cannot be evaluated (for gamma=0, tau in [0,tau_0]). A popular solution consists in using any of the following regularization models :
1. bi-viscosity model
2. exponential model
3. model with a parameter epsilon
I chose to use the exponential model which can be written as :
mu_a=mu+(1-exp(-m*gamma))*tau_0/gamma
with m=numerical parameter
If m is great enough (typical values verify m>100), the regularized law fits well the real consitutive equation. Thus, your regularized law exhibit now good properties : continuous (stress can be computed everywhere e.g. tau in [0,infinity]) and is differentiable everywhere too e.g. is C^infinity.
This method to tackle viscoplastic problems is well known and works very well with Fluent too either in 1D or in 2D-3D problems.
Have a look to those papers : 1. T.C. Papnastasiou "Flow of materials with yield", Journal of Rheology, 31, 385-404, (1987).
2. E. Mitsoulis, S.S. Abdali, N.C. Markatos, "Flow simulation of Herschel-Bulkley fluids through extrusion dies, Canadian Journal of Chemical Engineering, 71, 147-160, 1993.
3. M. Beaulne, E. Mitsoulis, "Creeping motion of a sphere in tubes filled with Herschel-Bulkley fluids", Journal of Non Newtonian Fluid Mechanics, 72, 55-71, 1997.
4. J. Blackery, E. Mitsoulis, "Creeping motion of a sphere in tubes filled with a Bingham plastic material", Journal of Non Newtonian Fluid Mechanics, 70, 59-77, (1997).
5. I.C. Walton, S.H. Bittleston, "The axial flow of a Bongham plastic in a narrow eccentric annulus", Journal of Fluid Mechanics", 222, 39-60, (1991).
With all those informations, I am quite sure you will succeed !! The only remaining thing to do by yourself is to write the UDF for the apparent viscosity (forget about the non-newtonian power law that is not suited to handle yield stress), that is an easy and quick duty.
Hope it might help you...
Anthony
Upyoung likes this.
Old   April 3, 2013, 12:51
lei
djb13110 is on a distinguished road
hi, Do you know whether liquefied iron ore powder is the viscoplastic fluid\?
I think I should do some steps:
1: do some experiments about the material
2: build the constitutive equation using the UDF
djb13110 is offline   Reply With Quote
Old   February 4, 2014, 02:41
Satish Gupta
Rahul123 is on a distinguished road
I am also trying to solve a similar problem. where should I attach the udf in fluent because if I attach it to viscosity, I don't find any place to enter the value of power n and consistency index K
Rahul123 is offline   Reply With Quote
Old   September 11, 2018, 18:00
Liliana de Luca Xavier Augusto
liliana is on a distinguished road
Hi!
Anyone could validate the UDF of HB fluid? I am simulating a flow between two paralell plates and comparing the results with analytical solution. Although, the results are not in good agreement...
Also I had some problemas when initializing the simulation. If I initialize by hybrid initialization and then run the simulation, I got a divergente on first iteration... Then I started the simulation by running a newtonian fluid and than changed to the viscosity calculate by UDF. It converges, but did not match with the analytical solution...
Did anyone had the same problem?
liliana is offline   Reply With Quote
Eulerian Modeling: Frictional Viscosity Help meangreen FLUENT 1 January 25, 2018 16:13
Yielding viscosity for Herschel Bulkley model Godwin FLUENT 1 December 12, 2011 06:42
Power - Law Viscosity Model for Polymers NickolasPl OpenFOAM 2 August 12, 2011 09:26
Regarding Implementation of Hershel Bulkley Model in Viscosity correlation Pathak FLOW-3D 0 August 24, 2009 07:34
kinematic viscosity at diff temperatures,pressures Mecobio Main CFD Forum 0 November 7, 2005 13:55
