NEW TUTORIAL: setting 2-node cluster with infiniband (WIN7)
Like Tree11Likes
  • 8 Post By ghost82
  • 1 Post By freuenwwt
  • 1 Post By ghost82
  • 1 Post By mpoit
Old   June 14, 2014, 15:32
Default NEW TUTORIAL: setting 2-node cluster with infiniband (WIN7)
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Hi all my friends,
in addition to the post I created here:
http://www.cfd-online.com/Forums/flu...-machines.html
I'm attaching a complete tutorial to setup a 2-nodes cluster with Infiniband.
Download pdf file here:
https://dl.dropboxusercontent.com/u/...INFINIBAND.pdf
Introduction
This tutorial shows how to setup a 2-nodes cluster to run Ansys Fluent 15.0 with distributed memory.
This tutorial applies for two Windows 7 Professional machines, connected by 20 Gb/s Infiniband adapters.
Step by step instructions are provided along with detailed pictures.
I hope it will be interesting and usefull to someone!
Daniele
ghost82 is offline   Reply With Quote
Old   August 12, 2014, 11:41
ghost82's Avatar
Rick
SLES Tutorial can be found here:
http://www.cfd-online.com/Forums/flu...tml#post505595
Old   December 12, 2014, 11:20
huey1080's Avatar
Quentin Lux
huey1080 is on a distinguished road
Nice work, great tutorials.
huey1080 is offline   Reply With Quote
Old   September 14, 2015, 04:58
Anwar
4asino is on a distinguished road
You can easily do it;
Firstly,what is the number of your cores i5 / i7 /2
You should know that increasing no0 of processors , decreases solution time but makes your machine heavy for doing other work.
Follow picture steps then press,Ok
4asino is offline   Reply With Quote
Old   February 17, 2016, 20:52
Alan Wang
freuenwwt is on a distinguished road
Send a message via MSN to freuenwwt
Hi ghost82,
I am trying to following your tutorial on windows 7. Would you share the infiniband driver used in your tutorial. I have the same infiniband adaptor.
freuenwwt is offline   Reply With Quote
Old   February 19, 2016, 11:27
ghost82's Avatar
Rick
you need WinOF 2.1.2 no later version, otherwise drivers will not load.
I cannot find them on mellanox website...you can download them from here (win7):
ftp://ftp.supermicro.com/driver/Infi...2_win7_x64.msi
Google is your friend and the same for the search button!
Old   February 19, 2016, 13:25
Alan Wang
Thanks for your help. I was able to repeat you work. The performance is very good.
It's about 1.36 time faster than normal 1G Ethernet connection.
ghost82 likes this.
Old   April 26, 2017, 10:25
ghost82's Avatar
Rick
Hello, updated links, after notifications by some users of expired links:
For windows 7:
https://www.dropbox.com/s/dpab43kiuc...IBAND.pdf?dl=0
For SLES 11 sp2:
https://www.dropbox.com/s/2owziokznp...11SP2.pdf?dl=0
AhmedSaad likes this.
Old   November 30, 2017, 13:22
SLC
SLC is on a distinguished road
For windows 7:
For SLES 11 sp2:
Is the setup process the same on Windows if you want to use RDMA instead of IPoIB? I thought IPoIB was a poor choice over the native IB protocol.
SLC is offline   Reply With Quote
Old   April 9, 2018, 17:46
mpoit is on a distinguished road
For windows 7:
For SLES 11 sp2:
Good tutorial thanks for sharing !
What would you change in your tutorial for running on other OS like windows 10 or centOS ?
Tahnks
Mathieu
power.pwoer123 likes this.
mpoit is offline   Reply With Quote
Old   December 12, 2021, 03:25
power
power.pwoer123 is on a distinguished road
Hi all my friends,
I hope it will be interesting and useful to someone!
Daniele
Hi
Thanks a lot for this tutorial that will help lots of people. but I could not download the pdf file and I would be very thankful if anyone had time to send it to me using mail?
my mail is "power.pwoer123@gmail.com"
Also, I have a question about this tutorial. Does it work for further editions of windows and Ansys fluent; like windows 10 and Ansys 19.0?
power.pwoer123 is offline   Reply With Quote
Old   December 12, 2021, 03:27
power
Tahnks
Mathieu
Hi
Did you get your answer?
If yes, I will be very appreciative if you share it with us?
How to setup a simple OpenFOAM cluster? TommiPLaiho OpenFOAM Installation 3 October 27, 2013 16:15
Cluster OpenFOAM [Solved] falcao OpenFOAM Running, Solving & CFD 24 June 17, 2013 21:57
Problem on Fluent Tutorial: Horizontal Film Boilig Feng FLUENT 2 April 13, 2013 06:34
[Virtualization] OpenFOAM oriented tutorial on using VMware Player - support thread wyldckat OpenFOAM Installation 2 July 11, 2012 17:01
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
