Writing mesh in FORTRAN or C
Like Tree1Likes
  • 1 Post By sbaffini
Old   June 28, 2012, 01:30
Default Writing mesh in FORTRAN or C
James Hetfield is on a distinguished road
can anybody please tell me how to generate my own mesh with FORTRAN or C and then import into Fluent?
Ive read UDF manuals but couldnt find anything useful
I wanna know the structure and order of the code that fluent can work with
James Hetfield is offline   Reply With Quote
Old   June 28, 2012, 03:48
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Are you talking about the script for automating the process or your own grid generation code?
Far is offline   Reply With Quote
Old   June 28, 2012, 05:25
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
The information you need is present in the User's guide manual.
However, if you are in need of a free mesh generator for Fluent i think you can use the ones present in the OpenFOAM suite (blockmesh and snappyhexmesh) and convert the mesh in Fluent format (i'm pretty sure there is also something to do that among the several applications)
As an example, you can find attached a simple, single-block, structured grid generator for Fluent. It is written in MATLAB but i am very FORTRAN oriented so it should be easily translated. Of course it is just an example, so do not go over 1-2 million cells. The code should be understandable as it is; you have:
- a routine to create a point distribution over a line (newgrid.m)
- a routine to create 3 matrix of points x(i,j,k), y(i,j,k) and z(i,j,k) (createmesh.m)
- a routine to convert the above matrix in a fluent readable .msh file (writemsh.m)
Hope it helps
ssh123 likes this.
sbaffini is offline   Reply With Quote
Old   June 28, 2012, 14:19
I mean the process for my own grid
Old   June 28, 2012, 22:27
Hope it helps
I read UDF and mesh manuals
NOWHERE its been mentioned how to write a mesh code for fluent
Old   June 29, 2012, 04:38
sbaffini's Avatar
Paolo Lampitella
Of course, in the manual it's not written how to write a mesh but how Fluent is expecting the msh file (which is all you need to write it).
As i said, the reference part in the manual is:
User's guide - B.3 Case and Data File Formats - Grid Sections
This has nothing to do with the UDF
Old   June 30, 2012, 19:20
Ill check it
Old   June 30, 2012, 19:24
sbaffini's Avatar
Paolo Lampitella
What version of Fluent are you working on and what versions of the manuals do you have?
Old   June 30, 2012, 19:26
sorry i made the wrong comment on your comment
I will check it
Old   July 1, 2012, 22:24
Hope it helps
thanks
it was useful
Old   July 2, 2012, 16:53
sbaffini's Avatar
Paolo Lampitella
You're welcome.
Still, i recently found some warnings related to some faces when using the above routines (actually just writemsh.m). This does not seem to be a major problem as Fluent can handle them correctly but means that something wrong is done somewhere. I was not aware of this or i wouldn't have shared them, i will share the correct version (as soon as i have it) if you still need it.
Regards
Old   July 2, 2012, 16:56
You're welcome.
Regards
if u share the new version i really appreciate it
I believe that Ansys stuff is cool but they DO REALLY NEED to develop a good grid generator for their stuff
both Ansys Meshing and ICEM have serious grid issues specially when it comes to quadrilaterals and smoothing in boundary layers
reading gambit mesh files using fortran zonexo FLUENT 4 December 15, 2020 13:39
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 09:52
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
