Problem with Cp UDF
Like Tree2Likes
  • 1 Post By upeksa
  • 1 Post By upeksa
Old   December 23, 2014, 04:03
Default Problem with Cp UDF
hosein
ho3ein.agl is on a distinguished road
Hi
I have a very 2D Unsteady simple case without inlet or outlet boundary.
my Cp udf is:
 DEFINE_SPECIFIC_HEAT(cp_pcm_paper, T, Tref, h, yi)
   real cp;
   if (T < 303.0)
      cp = 2200.;
    else if (T >= 303.0 && T <= 304.0)
      cp = 192800.;
	else
      cp = 1400.;
   *h = cp*(T-Tref);
   return cp;
problem is when the temperature of first cell reaches upper than 303 k, the residual of energy equation wont be converge.
I did this:
reduce under relaxation
reduce time step size
change energy solver method
what wrong?
ho3ein.agl is offline   Reply With Quote
Old   December 23, 2014, 05:41
upeksa is on a distinguished road
According to the values of Cp that you have defined, it would be really unexpected if you found convergence in your case.
Whatever are you trying, you should give it another approach.
Cheers
ho3ein.agl likes this.
upeksa is offline   Reply With Quote
Old   December 23, 2014, 08:34
hosein
sorry about cp = 18880000. right cp is 192800.
my main case is modeling melting a PCM (CaCl26H2O). in above case instead air would be PCM.
Heat capacity at constant pressure, cp 1400 (liquid) - 2200 (solid)
Latent heat of fusion, L (J kg-1) 190,800
if i use PCM property instead air , that problem still there. even when i use "else if (T >= 303.0 && T <= 304.0) cp = 2201.;"
refining mesh has no effect on that problem.
Old   December 23, 2014, 11:41
I see a lot of confusion here: if you want to simulate the melting of a substance, you have the possibility in fluent of choosing a model of "solidification & melting".
On the other hand, you have first to know the difference between Cp [kJ/kg-K] and latent heat [kJ/Kg]. You have used them as similar concept but they are completely different.
I have never simulated anything with the melting model, but I pretty sure you can set Cp of both solid and liquid phases as an UDF (or constant), and you can somehow set as well latent heat in the interface of the menu, in a similar way as you can set latent heat in the mass transfer menu in the multiphase model.
Cheers
Old   December 23, 2014, 14:35
hosein
yes i know solidification model must be use in melting simulation . in the first post, i want to test my udf with air without melting model just simple unsteady heat transfer case.
the only way to set Cp in solid or liquid is using 'DEFINE_SPECIFIC_HEAT' macro. in that macro cp is a function of temp.
do you know other way to set Cp function of liquid fraction?
in equation number 13 we have Cp= [kJ/Kg]/k + [kJ/kg-K] = [kJ/kg-K]
all paper i read have been used solidification model not multiphase model or VOF.
Old   December 23, 2014, 15:09
hosein
pleas focus on first post.
I would be thankful if you can run that case in your PC, maybe my PC has issue.
Old   October 19, 2016, 11:44
stalukar
shaonme is on a distinguished road
Hello, I need to know if Cp uses the UDF which includes the heat of fusion also, Is there any necessity to put the value of heat of fusion in the material dialogue box?
shaonme is offline   Reply With Quote
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 07:05
udf loading problem santu Fluent UDF and Scheme Programming 1 May 22, 2015 16:47
Vaporization pressure UDF property problem? lehoanganh07 Fluent UDF and Scheme Programming 1 September 13, 2014 11:59
Problem with my udf july Fluent UDF and Scheme Programming 3 June 20, 2010 07:56
UDF problem mansha goraya FLUENT 0 October 29, 2007 01:31
