Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Two Fluids air and mixture
Like Tree1Likes
  • 1 Post By guihds
Old   April 1, 2014, 09:36
Default Two Fluids air and mixture
Guilherme Henrique Dias Silva
guihds is on a distinguished road
I'm trying to simulate a object with two entries, the first one only air and the second one mixture (CH4 and H2S). How can I do this?
I wanna set a velocity inlet to inlet 1 (air) and set a velocity inlet to inlet 2 (mixture).
Thanks
ozy likes this.
guihds is offline   Reply With Quote
Old   April 25, 2014, 10:23
ozy
oguzayin
ozy is on a distinguished road
If you found the solution please let me to know.
My mail adresse : ooguzaydinn@gmail.com
ozy is offline   Reply With Quote
Old   May 9, 2014, 12:51
Mustafa
Mohawk is on a distinguished road
In creating model you need to draw two inlets and then naming them 8 mesh inlet 1 ,2
And in fluent specify velocity inlet
Mohawk is offline   Reply With Quote
Old   May 12, 2014, 13:16
Default inlet BC's
arrmando
aarratia is on a distinguished road
hey guys,
I am having the same problem. I already have 2 inlets created and meshed. My problem is that when I select "Air" for the first inlet, the other one changes from "mixture" to "Air" aswell. The same thing happens the other way around. What's going on?
aarratia is offline   Reply With Quote
Old   May 28, 2014, 01:06
Niaz Ali Ahmed
niazaliahmed is on a distinguished road
Me too facing the same problem in ansys fluent.
Have you found any solution yet?
In Star-CCM+, we select fluids and the volume fraction of individual phase / fluid appears under the boundaries.
niazaliahmed is offline   Reply With Quote
Old   May 28, 2014, 17:42
Sean Delfel
delfel is on a distinguished road
If it's a multiphase problem, you specify the conditions for each phase at the boundary. You do this by selecting each phase under the "Phase" dialog box in the boundary conditions panel. That way you can specify the velocity (or mass flow) for each phase at the two inlets.
This problem sounds like it could be more of a species transport problem than a multiphase problem -- if you use the species transport model, you specify the mass weighting of each phase at the boundary using the species tab for the boundary. Pretty sure that's explained clearly in the manual.
delfel is offline   Reply With Quote
mixture, multiphase, two entries
air flux through a boundary with air-water mixture Hale OpenFOAM Post-Processing 11 January 6, 2015 13:56
Is it possible to integrate air through a system with mixture of air and water? Hale OpenFOAM Post-Processing 1 September 30, 2013 09:57
Creating a kerosene vapour and air mixture akaero FLUENT 0 September 14, 2011 03:28
Simulation of a mixture of air / CNG (compressed natural gas) jonmec OpenFOAM Pre-Processing 0 November 13, 2009 15:24
air and water vapour mixture - multiphase model Saba FLUENT 0 February 10, 2009 13:05
