February 26, 2012, 21:57 |
Error in CFX Solver for mesh motion
sheth roh
Rep Power: 15 |
I am trying to model flapping motion of airfoil. My questions are 1. After some iterations there is negative volume error being generated so what should I do to avoid that. 2. I tried the remesh option available in cfx solver, but it rotational displacement about centroid or any other point is neglected in remeshing. See image [its from cfx manual], so any solutions? Any help will be appreciated. |
February 27, 2012, 00:07 |
Rep Power: 144 |
I suspect you may need to contact CFX support for help with this.
February 27, 2012, 11:39 |
Edmund Singer P.E.
Rep Power: 21 |
Don't use ICEM CFD Replay method for remeshing. This is only good if you have the conditions you have outlined.
Use the User Defined remeshing associated with an ICEM remeshing script. |
February 27, 2012, 23:04 |
sheth roh
Rep Power: 15 |
RBF motion solver does not work well in parallel | lakeat | OpenFOAM Bugs | 3 | August 8, 2013 06:50 |
CFX 11 x64 solver? problem | Attesz | CFX | 6 | June 7, 2009 09:37 |
FSI error"the connection between cfx and external solver has died unexpectedly" | mortazavi | CFX | 0 | June 1, 2009 05:58 |
CFX Solver to run 10 files sequentially | Raj | CFX | 8 | October 29, 2008 23:20 |
CFX 5.5 | Roued | CFX | 1 | October 2, 2001 17:49 |
