two fluids in CFX-pre
Like Tree2Likes
  • 2 Post By Abou ali
Old   December 30, 2009, 05:27
Default two fluids in CFX-pre
bond is on a distinguished road
pls tell me, how can i assign two different fluids in CFX-Pre seperately for two domains. like water and oil. water domain and oil domains are seperate with seperate inlet and outlets......????
bond is offline   Reply With Quote
Old   December 31, 2009, 04:08
Default CFX Beta Features
Abou ali is on a distinguished road
The easiest method to use different fluids in different domains is by enabling the Beta features of CFX.
In the CFX-Pre window go to Edit/Options, in the options table select CFX-Pre and activate Enable Beta Features and click Ok.
Now go to the simulation tree and right click on Simulation then disable Constant Domain Physics. Finally you can select the desired fluid for each domain.
farzadpourfattah and haytam14 like this.
Abou ali is offline   Reply With Quote
Old   January 5, 2010, 12:08
Antonio P.
pantarei83 is on a distinguished road
I have the same problem, but in my CFX version 10.0 I can't find these commands.
Help me!
pantarei83 is offline   Reply With Quote
Old   January 6, 2010, 15:29
stumpy is on a distinguished road
In older versions you need to set the environment variable "CFX5_NO_CONSTANT_PHYSICS = T"
stumpy is offline   Reply With Quote
Old   January 7, 2010, 04:42
Antonio P.
Hi Stumpy,
I'm new to CFX. Can you tell me hot to set the environment variable "CFX5_NO_CONSTANT_PHYSICS = T"?
Thanks a lot
Old   January 7, 2010, 09:26
shogologo is on a distinguished road
  1. Click on "START" then Settings then open Control Panel
  2. Click the System icon
  3. Go to the Advanced panel
  4. Click the Environment Variables button
  5. Select the "new" button to create a new environment variable
  6. The value of "VARIABLE NAME " should be
7. The value of "VARIABLE VALUE" should be
T
Click on "OK" then Restart system
shogologo is offline   Reply With Quote
Old   January 7, 2010, 11:37
Antonio P.
Thank a lot...
Old   July 21, 2011, 02:45
Mridul
makkks is on a distinguished road
HI everyone,
I have a similar problem.
I have two fluids: air and oil
As discussed above I activated Enable Beta Features and disabled Constant Domain Physics.
It changed at first but when I closed and reopened the simulation again, its not working.
I checked options again but it is set to enable beta and disable physics now.
I m not able to get different fluid in different domain.
Plz help
ps: m working on (Ansys 13,windows server2008)
makkks is offline   Reply With Quote
Old   November 30, 2013, 14:16
wen
wenwen is on a distinguished road
Originally Posted by makkks View Post
HI everyone,
Plz help
Not only disable constant domain in edit/option
but also disable it in outline/case option/general
wenwen is offline   Reply With Quote
Old   August 26, 2018, 17:19
Soumitra Vadnerkar
soumitra2102 is on a distinguished road
had the same problem;
Thanks it worked.
soumitra2102 is offline   Reply With Quote
Exporting mesh to CFX Pre Usman Ali CFX 4 October 22, 2007 12:09
CFX Pre - TGrid Vivek Vasudevan CFX 2 March 20, 2007 07:31
No.of Elements in ICEM and CFX Pre Manu CFX 1 August 25, 2006 08:20
CFX 5.7.1 PRE and solver won't start daniel CFX 1 January 20, 2006 11:09
CFX 5.7 pre Neser CFX 0 January 27, 2005 12:22
