December 24, 2006, 08:05 |
How to extrude 2D Mesh in ICEM CFD?
I am trying to extrude a 2D Mesh from a simple square geometry
this is what i am doing 1. Create the 2D geometry ((a square ) in X-Y plane 2. create a 3D Bounding Box. Give equal no: of nodes for each edge and see the premesh. 3. then I create a "curve", normal to one of the "points" of the square (distance equal to the cell size in the Z-direction) 4. Unless I convert the current mesh to unstructured by right-clicking on premesh, I dont see the Extrude Mesh option in the Mesh tab highlighted. (Is this the case?) 5. I use Extrude Mesh by curve option to create the 3D Mesh 6. When I click export to CFX, I see a warning in ICEM box, "the family BODY has mixed of 2D and 3D elements and this is not allowed in CFX -5" What does the above error mean? Is the procedure that I am following right? I am not using the "Extrude by element normal" method as it is giving large thickness in the Z-direction. One more thing, when to define parts in such a problem so that I can select location for a Boundary Condition later in CFX? I hope somebody responds to my queries |
December 24, 2006, 15:19 |
Re: How to extrude 2D Mesh in ICEM CFD?
You are doing 2D or 3D Simulation. If 2D than extruding one element thick in z or normal direction will definitely work. Procedure-> 1.Make 2D Geometry of Problem.Define Boundaries by parts. 2.Make a 2d Planar Block 3.Associate Edges to curve than associate vertices. 4.Specify no of nodes. 5.Premesh than convert the mesh into unstrutured(only the format) 7.Close Project.Than open only the mesh . 8.Extrude by normal method one element (2D) or more elementsif (3D Simulation.you can also define ur parts name in the extrude tool menu. 9.Save and import to CFX. I hope this will help and work.
Manu |
December 26, 2006, 04:34 |
Hi manu
Thanks a lot But still everything doesnt seem to work as i want it to be I am doing 3D simulation (Does CFX handle 2D simulations, I dont think so.... My geometry doesnt require a 3D analysis, so I want to make a 2D Mesh and extrude it to 3D Please address the following things: 1. In the Extrude Mesh window that appears after clicking on the icon, I select all the elements by typing "a". Even If use the "Extrude by element normal" method with 1 layer I see that the length/thickness/extrusion distance in the third direction "z" is very large!!! Is there any means by which this can be manipulated? Or is this absolutely normal? Is there a way in which I can specify the "extrusion distance" myself so that I can avoid this system-default extrusion distance which in this case appears to be very large... 2. In the Extrude Mesh window, there is provision for defining part names. But it simply asks for name to be given for the sides. In this case there are four sides but not all of them will be assigned a similar boundary. I could not make your "Define Bounadries by parts after creating a 2D Geometry" strategy work 3. After exporting the mesh to CFX, I still see this warning that " the body (name of the body that I created before blocking) has mixed of 2D and 3D elements which is not allowed in CFX -5" Can this warning be ignored or does it have any impact? |
December 26, 2006, 09:41 |
Once you have loaded the 2D mesh - just a surface mesh - look at the parts list. My guess is that the surface mesh is in the part where you originally defined your 'body' to be (for the blocking). You'll probably want to move this surface mesh into a part for the representative surface.
I believe CFX requires one-element-thick mesh for a 2D analysis. Mesh > Extrude Mesh. The volume part name is for the newly-created 3D elements. The Side Part is for the 'sides' of the extrusion. The Top Part is for the opposite end of the extrusion (the 'end' of the extrusion). You specify the Number of Layers and the Spacing Type. The Spacing Type default is set to 'Fixed' and a Spacing of 1. If you want a smaller extrusion layer, change the 'Spacing' value to your desired thickness. If you specify more than one layer, each layer has the 'Spacing' value. Once you have the extruded mesh you can use the Parts branch to separate the surface mesh into appropriate groups. (Create parts, add to parts, etc.) |
December 27, 2006, 00:11 |
Hi Myron, Thanks a ton for the detailed mail!
I actually wanted to decrease the spacing of my extruded mesh.But I wrongly called it thickness, hence the confusion Now I have given a value of 0.01 for spacing and found the mesh to my satisfaction. Even I am able to assign mesh to desired parts I just have one more question. Is the solution influenced by the spacing value?Ideally what should be the spacing value? I tried out a simple problem both in 3D and and by this way of extruding a 2D Mesh. I find that the solutions in both the above cases are sufficiently close to each other But I want to know if something can be done to bridge the difference. Or is it that way only because we are making an approximation in the case of extruded mesh? |
December 27, 2006, 08:22 |
I think in 2D Simulation Extrude distance has no effect bcoz there are no nodes in between the two at ends. But in 3D ( i.e more no of nodes in z directioin)it will greatly influence the result and that will ofcourse depend on the physics of the problem.If you want to do a transient case than definitely you should consider the proper extrude distance. Hope this is what u want to now???
Manu |
December 27, 2006, 09:39 |
Hi Manu,
I am really not able to understand what u mean by 2D and 3D? Are you talking in relevance to CFX? Isnt what u are getting by extruding also a 3D Mesh? |
December 27, 2006, 12:58 |
yes its all revence to CFX.Since you can not do a 2D Simulation directly in CFX so we somehow have to make the code fool by giving an element thick mesh.Yes its a 3D Mesh but not 3D Simulation.Thats wht i meant in previous post.
ICEM CFD 5.0 - 2D to 3D Mesh Extrude | James Date | CFX | 7 | October 22, 2013 04:46 |
Loading previously saved mesh in ICEM CFD | user0314 | ANSYS Meshing & Geometry | 1 | September 20, 2011 13:46 |
[ICEM] Problem with volume mesh in ICEM CFD | kolapoasafa | ANSYS Meshing & Geometry | 2 | September 16, 2011 04:54 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
How to corse mesh in icem cfd? | Priety | CFX | 2 | October 2, 2006 04:57 |
