The difference between frozen rotor and unsteady frozen rotor in turbo machinery?
Like Tree5Likes
  • 5 Post By Far
Old   December 13, 2012, 18:35
Question The difference between frozen rotor and unsteady frozen rotor in turbo machinery?
samane
samane_81 is on a distinguished road
I want to know the difference between frozen rotor and unsteady frozen rotor in turbo machinery?
just for modeling steady and unsteady or something more?
for modeling an axial or radial compressor with fixed speed of rotation(for example 750rad/s) which one is better for interface?and why?
samane_81 is offline   Reply With Quote
Old   December 15, 2012, 14:13
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Frozen rotor is the steady state method which uses the rotating reference frame to save your computational resources by converting inherently transient turbo-machinery flow into steady state. The difference between frozen rotor and mixing plane (stage method as named in CFX) is that mixing plane mixes the flow and apply the average qualities on the interface for upstream and downstream components. While frozen rotor will pass the true flow to down steam and vice versa. So if you are interested in the wake effect on the downstream component performance then you should use frozen rotor method. Its disadvantage is that, if gives you the solution at the single relative position. So if you want to get the wake effect on the downstream component for all relative positions (as happens in reality) then you should go for the true transient method.
There are true transient methods available in the CFX like sliding mesh. They have also introduced some other unsteady methods which relaxes the conditions for the sliding mesh such as equal pitch size on both sides of interface.
Unsteady + frozen rotor (do not call it unsteady frozen rotor) method may used to simulate the vortex shedding in the turbine rotor blade trailing edge. That vortex shedding is accomplished through unsteady solver while frozen rotor is used to couple the Nozzle guide van and rotor domains. So you may be interested in finding the relative position which triggers the vortex shedding or suppresses it.
crevoise, seyed, kaktus10 and 2 others like this.
Far is offline   Reply With Quote
Old   January 5, 2013, 10:44
samane
Dear far
Thank you very much! It helps me a lot!
Old   January 1, 2015, 16:16
Hossein
topsedar is on a distinguished road
Dear Far
I was searching to find out the difference between Stage and Frozen Rotor.
you mentioned that:
may I ask you kindly make a clarification about your statement?
1- what is the meaning of single relative position? ( where do you mean? )
2- when I am not allowed or not using Frozen Rotor model? ( The same question related to Stage model)
Best Regards,
Abedini
topsedar is offline   Reply With Quote
Old   March 18, 2016, 06:14
juzer_700 is on a distinguished road
Can you please explain what do you mean by 'Single Relative Position'?
Regards,
Juzer
juzer_700 is offline   Reply With Quote
Old   March 18, 2016, 06:52
Maxim
-Maxim- is on a distinguished road
it means that the rotor is frozen in one position and is not moving. Your result is basically the flow in that exact moment.
You usually cannot display any periodic 'events' (e.g. pressure pulses from the moving rotor on other objects in the flow). You would need a fully transient simulation for that.
-Maxim- is offline   Reply With Quote
Old   March 18, 2016, 09:32
Thanks for the reply.
That would mean that the relative position is fixed between the rotor and the non-rotating domain for all my timesteps of my steady state simulation.
Am I making any wrong interpretations?
Thanks and Regards,
Juzer
Old   March 18, 2016, 09:41
Opaque will become famous soon enough
You got it, i.e. frozen rotor does not move respect to the stator during the simulation.
Opaque is offline   Reply With Quote
Old   April 6, 2016, 00:12
ali
eng_norouzi is on a distinguished road
Now what is the equivalence of sliding mesh in CFX interface model? is that transient rotor stator or stage?
thanks
eng_norouzi is offline   Reply With Quote
Old   April 6, 2016, 06:04
Far
Sijal
transient rotor stater = sliding mesh. Stage = mixing plane, frozen rotor = multiple rotating reference frame.
Old   April 7, 2016, 02:59
ali
thanks Sijal,
Do you know any example or tutorial for CFX transient rotor stater model?
Old   April 7, 2016, 14:54
Far
Sijal
yes. One is provided with CFX help
axial compressor, cfx, frozen rotor, interface, unsteady
