[ICEM] prism generation
Like Tree8Likes
  • 1 Post By rikio
  • 5 Post By PSYMN
  • 2 Post By PSYMN
Old   September 19, 2009, 01:48
Default prism generation
jsm
JSM
jsm is on a distinguished road
In ICEM CFD, how to avoid the pyramid elements generation while making prism layers. There is any best practices are available?
Kindly give your suggestions.
With regards,
JSM
jsm is offline   Reply With Quote
Old   September 20, 2009, 00:48
Rikio
rikio is on a distinguished road
Send a message via Skype™ to rikio
Generate one layer of prism first, and then split this layer into as many layers as u want.
gnut1989 likes this.
rikio is offline   Reply With Quote
Old   September 22, 2009, 06:04
jsm
JSM
Thanks for your suggestion.
With regards,
JSM
Old   October 12, 2009, 15:00
Default I'll get back to this.
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
I did intend to get to this, but I am traveling now and my internet connection is not good enough to post the ppt...
I will try later this week.
Simon
PSYMN is offline   Reply With Quote
Old   October 13, 2009, 00:45
jsm
JSM
Hi Simon,
Thanks for your efforts. Please post your presentation at your convenient time.
With regards,
JSM
Old   October 13, 2009, 18:58
Default No Pyramid
Alex
apantune is on a distinguished road
JSM,
this might help you....
Mesh -> Global Mesh Setup -> Prism Meshing Parameter -> Advanced Prism Meshing Parameters -> Turn Off : Stop Columns, Refine Prism Boundary Turn On : Auto Reduction.
This setup will stop your prism layer before it intends to generate a pyramid element. You might not get the desired prism height.
Alex
apantune is offline   Reply With Quote
Old   October 13, 2009, 19:15
Alex
Rikio,
if you have a very complex geometry and try to raise one single prism layer (with the total height to afterwards split it) the tetrahedrals sometimes can not be adequately acomodated. With this approach you smash the tetrahedrals by a certain amount in just one single steps (on the step by step approach the tetra are smoothed during the proccess). For complex geometries this can bring you some problems.
Regards,
Alex
Old   October 14, 2009, 02:25
jsm
JSM
Hi Alex,
Thanks for your suggestion. I am looking for similar kind of tips and tricks for prism mesh generation.
FYI : Simon will also post one presentation for prism mesh generation.
With regards,
JSM
Old   October 14, 2009, 16:01
Thumbs up PDF of Prism tips.
PSYMN's Avatar
Simon Pereira
Sorry for the long delay… The ppt is here ftp://ftp.ansys.com/outgoing/simon/Prism_NoPyramids.pdf
The ppt was originally made for a customer using a combination of Fluent and CFD++, neither of which like pyramids very much, on models that were typically hundreds of millions of elements (they didn't want to just "try things").
Other solvers, such as CFX, would prefer pyramids to poor quality prisms, so this may not be the best settings for everyone... Which is why they are not the hard wired defaults... ICEM CFD is all about flexibility.
There are also some general prism tips in there.
pz21, Mazze[ITA], Ram and 2 others like this.
Old   April 4, 2012, 17:42
Default Cfd++
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Hi PSYMN
I want to write mesh for CFD++. Would you please guide me to set the boundary conditions for CFD++ and then output the mesh.
Far is offline   Reply With Quote
Old   April 18, 2012, 09:03
Default problem in prism layer
  #11
SANTOSH
dnsantosh is on a distinguished road
hi
am trying to generate tri/prism on my geometry which ha V shape , wen i try to generate prism by icem cfd it generates penetrating elements and pyramids, can anybody tell me how to avoid penetrating elements between V ( V angle 73 deg sides 80mm, 65mm and need 30mm prism height)
dnsantosh is offline   Reply With Quote
Old   April 18, 2012, 11:16
Rikio
Set the smoothing step to 0 under Global Prism Setting tab. Manually smooth after the prism generation.
Old   April 18, 2012, 22:37
PSYMN's Avatar
Simon Pereira
Another option (depending on your version) would be to go into Prism advanced settings and click the option for PrismV10... I think that was sorted out in later versions, but I forget when exactly.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
Old   February 8, 2013, 06:16
Gopal Shinde
shinde.gopal is on a distinguished road
Thanks for preparing the stuff. But, I am not able to access the ftp. Can you please let me know if the file is still available at the same path and ftp is up. Thanks for the help.
shinde.gopal is offline   Reply With Quote
Old   February 8, 2013, 06:34
Far
Sijal
http://www.cfd-online.com/Forums/ans...efinement.html
Enjoy !!!
Old   February 8, 2013, 11:02
PSYMN's Avatar
Simon Pereira
@ Shinde Gopal,
That pdf was from 2009... But I guess it is still relevant.
That whole FTP site was taken down. We have switched to Google.
Here is the google link.
https://docs.google.com/file/d/0ByIL...it?usp=sharing
Kontestator and majid fahim like this.
Old   February 11, 2013, 07:50
Gopal Shinde
Thanks a lot
@ Shinde Gopal,
Old   February 11, 2013, 07:51
Thumbs up
  #18
Gopal Shinde
@ Shinde Gopal,
Thanks alot
Old   February 11, 2013, 08:08
Gopal Shinde
@ Admin : Please delete this post
Old   September 22, 2017, 03:44
Default Simon Tricks to make prisms without pyramids
  #20
Hari Krishnan Kumar
haristrawberry is on a distinguished road
Can anyone post the PPT or send it to haristrawberry@gmail.com
Thanks
Hari
haristrawberry is offline   Reply With Quote
problem in prism layer generation shrimp CFX 5 March 26, 2010 13:34
Icemcfd: Preventing prism inflation collisions? Joe CFX 1 July 31, 2007 10:13
Prism Mesh Generation Sank CFX 1 July 22, 2005 02:59
need help on Prism Mesh Generation Pete CFX 0 December 6, 2004 03:11
Latest news in mesh generation Robert Schneiders Main CFD Forum 0 March 2, 1999 05:07
