[ICEM] tubes with different diameter - Ogrid questions |
September 10, 2015, 10:46 |
Maxim
Rep Power: 13 |
Hi guys,
I'm teaching myself some ICEM meshing and after doing most of the tutorials, I'm getting the idea of how it works. For a bigger project, I would like to mesh two tubes/cynlinders with a chamfer between them. The bigger one will later be an inlet/outlet. Picture 0 shows the blocks before the vertex association: Picture 1 shows my blocking and vertex/curve association: Picture 2 shows my blocking after applying Ogrid: Picture 3 shows my completed mesh The problem is obviously that either Ogrid cannot split my blocking of both tubes at once, or I cannot find the right options to set it up correctly. 1) Do I have to apply the Ogrid split for each of the tubes individually? 2) Which faces do I have to select for the Ogrid? Right now, I am selecting all flat surfaces (top and bottom, not the cylinder surfaces). 3) Do I have to set the initial associations or blocking differently? 4) Regarding the first picture I posted: Is there a way how to merge the front faces of the bigger tube so that Ogrid doesn't split the bigger tube in a weird way? Of course I can provide more screenshots or information if needed. Thanks for your advices. Best regards, Maxim Last edited by -Maxim-; September 11, 2015 at 04:03. Reason: additional pic |
September 10, 2015, 13:42 |
#2 | |
Rep Power: 18 |
1. Make block for big cylinder. 2. Make o-grid passing through circular faces. 3. Extrude central face of o-grid to make block for small cylinder. 4. Make o-grid passing through small and big circular faces. |
September 10, 2015, 14:02 |
Attique Javaid
Rep Power: 11 |
are you looking for it? |
September 10, 2015, 14:05 |
Attique Javaid
Rep Power: 11 |
associated files regarding that pic are:
https://drive.google.com/file/d/0B4Y...ew?usp=sharing |
September 11, 2015, 03:39 |
Maxim
Rep Power: 13 |
Thank you two for your answers.
I was trying to make to top-down method going to work but extruding a block from an Ogrid face is really helpful in this case! The difficult part though is the chamfer between the two cylinders. I just took it as a third cylinder and extruded the face again. So far so good. Now I'm trying to fix those cells around the chamfer with very little angles. Is there an easy way to model chamfers in ICEM? Last edited by -Maxim-; September 11, 2015 at 05:02. Reason: more success ;) |
September 11, 2015, 05:02 |
Rep Power: 18 |
2 o-grids, for ex.:
September 11, 2015, 05:10 |
Maxim
Rep Power: 13 |
thank you again Antanas, that worked great so far.
My chamfer looks like that at the moment: which gives me cells with bad angles: Can I correct that with cell size settings etc or do I have to set up my Ogrid differently in the first place? Last edited by -Maxim-; September 11, 2015 at 05:14. Reason: edited pic |
September 11, 2015, 06:48 |
Maxim
Rep Power: 13 |
Histogram on a selected volume, Droplet diameter profile | crevoise | STAR-CCM+ | 1 | December 8, 2024 17:54 |
Static structural analysis of two overlapping tubes kept together by pins-ANSYS Mech. | Giulio89 | Structural Mechanics | 5 | May 17, 2013 15:14 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
How to choose the mean diameter value for dispersed fluid? | creddy_trddc | CFX | 1 | October 30, 2011 05:30 |
Importance of Hydraulic Diameter Value for Compressible Flow | RyGuy | FLUENT | 0 | August 6, 2009 11:58 |
