[ANSYS Meshing] Surfaces with high curvature
Like Tree4Likes
  • 1 Post By amin.z
  • 1 Post By Kapi
  • 1 Post By Kapi
  • 1 Post By amin.z
Old   November 12, 2014, 00:02
Smile Surfaces with high curvature
mohammad
mohammad is on a distinguished road
Dear all,
Recently, I am working on a blood pump project. The pump is centrifugal type with highly curved surfaces. Hence, when I import the IGES file, created by SOLIDWORKS, into the ICEM and even after the geometry repairing (making all curves as red line which mean the shared edge of two surfaces), the surfaces do not match their own curves at their boundary (and very small gaps are visible between the surfaces and their curves at their edges, especially in the highly curved areas).
Therefore, later when I create the blocks and Hexa mesh, during the CFD solution, I face strange results such as blood velocity of 1800 m/s!!!!!
My question is if there is a proper method for generating these kind of surfaces or geometry repair or...
I highly appreciate your favour.
Regards,
mohammad is offline   Reply With Quote
Old   November 12, 2014, 02:57
amin.z's Avatar
Amin
amin.z is on a distinguished road
Hey
I haven't experience with ICEM I'm using ANSYS meshing
But I suggest you for import solidworks CADs use sldprt and sldasm formats!
amin.z is offline   Reply With Quote
Old   November 12, 2014, 07:05
mohammad
Dear Amin,
what do you mean by ANSYS meshing?...
How to do that? is it an easy way?
I am not forced to use ICEM but I want to have a Hexa hedral mesh in which I can control the number of nodes along all curves, which is possible in ICEM.
Do you have any other solution for what I need?
Old   November 12, 2014, 07:44
amin.z's Avatar
Amin
Originally Posted by mohammad View Post
Dear Amin,
Ansys meshing is a grid generator like gambit and ICEM
It's available in ansys as "mesh"
I guess the solidworks export format is reason of problem! Check it with another format...
Old   November 12, 2014, 09:09
mohammad
I tried to install the Ansys meshing...but I could not find it in Ansys package...see the photo plz
Old   November 12, 2014, 15:53
Default Surfaces with high curvature
amin.z's Avatar
Amin
If you install ansys you will find ansys meshing in "components system" tab as mesh!
I suggest you before switching from ICEM to ANSYS meshing check your model with another import format in ICEM! Maybe it solves your problem!
mohammad likes this.
Old   November 12, 2014, 18:25
Kapi is on a distinguished road
Hi Mohammad,
Once you have installed Ansys, Open Ansys Workbench.
On the left hand side you will find "ToolBox" and Under that "Component system". In this component system you can find "Geometry" and "Mesh" both.
You can create Geometry from scratch of import your geometry and try to fix it.
Under Mesh, you can control type of element and thr sizing, skewness etc according to your need.
Hope it helps.
Cheers
Kapi
Kapi is offline   Reply With Quote
Old   November 21, 2014, 11:43
mohammad
Dear Amin, Dear Kapi
To solve the problem of high curvature, I imported my solidworks file into the ANSYS MESHING. And the geometry seem perfectly ok. Then, I gave names to the parts and I started to learn meshing the model according to (http://www.arc.vt.edu/ansys_help/flu...7100028.8.html)
In the example presented in the website, the mesh is tetra. However, I am looking for learning hexa meshing.
I want to know if you have some useful tutorial pdf file or link address.
Best wishes
Old   November 23, 2014, 23:13
Hi Mohammad,
When you right click on mesh it gives option to Insert "Method" just like "Sizing" which is by default Automatic.
Once you have selected body, click and choose different type of meshing from the drop down menu as per your preference.
Also, go to help section in the mesh and read about the different type of mesh, it should give you lot of ideas about them.
Hope it helps
Cheers
Kapi
Old   November 24, 2014, 02:02
amin.z's Avatar
Amin
For inflation I suggest this way:
- Right click on model and select inflation
- select the body for geometry
- select the faces you want for inflation in boundary tab
- edit other parameers
high curvature, highly curved surface
High curvature 90 degree bend using SST, eddy viscosity drop?? tinab0binuh Main CFD Forum 0 August 22, 2014 18:26
Air at High Pressure cfd seeker FLUENT 2 September 30, 2013 15:58
curvature correction term, material derivative of a tensor volker OpenFOAM Programming & Development 7 June 3, 2010 09:08
flow with high turbulent viscosity ratio Phillips FLUENT 0 August 24, 2008 19:01
whether DEM or Eulerian approach for high solidup CFDUSERIN Main CFD Forum 0 April 19, 2007 06:35
