[ANSYS Meshing] Pipe bend meshing using MultiZone |
Alex
Rep Power: 49 ![]() ![]() |
There were some requests on how to produce a quality mesh for a pipe bend using Ansys mesher.
Since the basic procedure can be transferred to similar geometries, I decided to write a beginners tutorial for this purpose. Geometry Nothing special here. Create the geometry the way you want. No need to do splits or face imprints. When You are done, switch to the the Ansys mesher. geometry.jpg Meshing Step 1 First thing we should always do when creating meshes for CFD simulations is switching the Physics Preference to CFD. This is not mandatory here, but the mesh will generally be much better suited for CFD. I also switched the relevance center to medium, just to get slightly smaller elements with the default settings. mesh_1.jpg Step 2 Insert a new mesh control method. mesh_2.jpg Step 3 Select the whole volume as geometry for this method. mesh_3.jpg Step 4 Select MultiZone from the method drop down menu. mesh_4.jpg ...continued in the next post |
Alex
Step 5
Insert an "inflation" mesh control. mesh_5.jpg Step 6 Again, select the whole fluid body as geometry. mesh_6.jpg Step 7 Select the outside faces as boundaries for the inflation. mesh_7.jpg Step 8 Choose values appropriate for your geometry and application. The values I put here are just an example to make the result look good. You can generate the mesh now, the result will be quite good mesh_8.jpguniform.jpg ...continued in the next post |
Alex
Step 9
For an even better result, edit the details of the multizone method. Change the Source/Target selection to manual source and select one of the circular faces of the pipe as geometry. Thats it. You can now generate the mesh and contemplate the result. mesh_9.jpg Result mesh_final.jpg |
#4 | |
Farzad Montazery
Rep Power: 11 ![]() |
Rep Power: 13 ![]() |
the last step does not seem to work for me, gives the same result which is like the picture you have given before your last step of change to manual and selecting a face...
Farzad Montazery
I followed the steps, but it worked, do you select your first sketch which you sweep it to make model as a source?
my geometry is made in solidworks but i dont think it should make a difference
#8 | |
Rep Power: 0 ![]() |
I created an O-grid like that but for a straight duct. Now I have 2 questions and would appreciate if you could answer them ![]() 1.) The elements close to the square in the middle of the mesh are pretty big. How can I set their sizes (like the ratio of the last cell before the scare and the first cell at the wall should equal 2) => Right now my settings are: TransitionRatio=0.8, Number of Layers=20 and GrowthRate=1.2 2.) I also want to create an Inflation in flow direction of the pipe, but everytime I try that the inflation for the O-Grid dissapears :/ I hope you can help me ![]() Thanks, greetings from South Germany ![]() |
#9 |
Israel
Is there any other method of producing same type of mesh in ANSYS only?,
Because this method is taking so much of time in my personal computer having 8 GB RAM. Please help me out. I am stuck with this. |
#10 |
Rep Power: 14 ![]() |
I think this is the only way to get such kind of mesh.
If your geometry is big and mesh is fine then it will take time, you cant do much about it. |
#11 |
hello,
could you please explain me which is the effect of the multizone method? what happens if you don't apply this method and which criteria do you use to select the manual source and target faces? many thanks in advance. |
#12 |
Hi delplatl,
The best way to get answer to this question is reading about it. Use help section and read about all type of methods and make a small geometry and try to mesh it with different Mesh methods to get complete idea. Cheers KAPI |
#13 |
Israel
Hi all,
Is there any effect of mesh size on the convergence of solution in FLUENT. I mean to say that in my problem I have divided the entire cylindrical bend into very fine mesh but solution is not being converge but if I reduce the number of mesh or in other words increase the size of mesh element then solution is being converged. Am I doing right thing or should I try try to change any other parameter keeping very fine mesh. Please help me out. |
Sand accumulation in a pipe bend | RTHartley | Fluent Multiphase | 0 | October 22, 2013 07:39 |
[ICEM] Meshing a pipe with 6 inlets | cs1 | ANSYS Meshing & Geometry | 1 | May 29, 2013 11:53 |
axial velocity in bend pipe with adverse pressure gradient | liguifan | OpenFOAM | 0 | July 24, 2011 05:56 |
Meshing of circular pipe in CFX-mesh | Fatnes | CFX | 3 | March 27, 2009 06:29 |
