January 20, 2014, 10:07 |
Blocking: H-mesh inside O-grid
Sindre
Rep Power: 13 |
Hi all,
is it possible to create a H-mesh inside a O-grid in ICEM (ref figure below, trying to illustrate block setup)? (I want to use this to mesh a rectangular cylinder (second figure).) Best regards Sindre |
January 20, 2014, 12:07 |
Sindre
Rep Power: 13 |
Thank you so much for responding, been working on this problem for a while. Can you please explain what you mean by using "blocking inside"? Do you mean that I can hide the surrounding blocks and then only split the center block?
January 20, 2014, 13:53 |
Sindre
Rep Power: 13 |
That worked perfectly, as shown in the first figure
But this leaves me with another question: Is it possible to create a Y-grid inside a O-grid (indicated by red lines on second figure)? (((For information: I found the Index Control by right clicking the Blocking tab in the tree on the left side. User manual states that it is also possible to use the shortkey "i". ))) |
January 20, 2014, 14:03 |
Sindre
Rep Power: 13 |
I've been trying to do this in the same way, but it interrupts the surrounding blocks. Pictures displays the result.
January 20, 2014, 14:44 |
#9 |
Sindre
Rep Power: 13 |
Do you know if it is possible to do it the other way around?
The reason why I'm asking is that I want to use the Y-block to create a mesh around a sharp corner, as shown in the first figure. That is, block 25, 27, 23 and 4 om the second figure. |
January 23, 2014, 10:30 |
#12 |
Sindre
Rep Power: 13 |
Thank you Sijal,
Your method worked out perfectly. The blocking index option was exactly what I've been searching for. I've posted a couple of pictures below, showing the resulting mesh. Sindre |
May 16, 2014, 08:38 |
#14 |
Sindre
Rep Power: 13 |
After requests some more pictures are posted of block topology and generated mesh.
EDIT: This time of a square cylinder. |
June 16, 2015, 08:24 |
#15 |
Tom
Rep Power: 11 |
could you show me how to create y-grid around the corners of the rectangle in ICEM CFD?
June 30, 2015, 10:08 |
#16 |
Siddana ravi Kumar
Rep Power: 11 |
I would like to practice this model. if u dont mind can i have it?
March 18, 2017, 17:07 |
#17 |
Ernesto
Rep Power: 15 |
March 20, 2017, 04:55 |
#18 |
Sebastian Engel
Rep Power: 21 |
Hello Ernesto,
have a look at the attached picture. In the ogrid menu, use "add faces" to select the red-marked faces/edges in the picture. The use "add blocks" to selct blocks which are marked in light red in the picture. Then you should come up with a blocking sindre asked for. With regards, Sebastian centerYblock.png |
March 21, 2017, 07:00 |
#19 | |
Ernesto
Rep Power: 15 |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 08:34 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
2d irregular grid | Remy | Main CFD Forum | 1 | December 22, 2008 05:49 |
[Other] How to mesh the 1st grid point | lakeat | OpenFOAM Meshing & Mesh Conversion | 1 | October 8, 2007 08:13 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 10:38 |
