Home > Forums > Visualization & Post-Processing Software > Tecplot
TECPLOT
Old   September 30, 2005, 13:55
Default TECPLOT
Sue
Hello:
I have simulated the flow in a curved duct and want to see the flow structure in each cross section along the duct centerline axis (not x-axis). I know how to make slices but there must be a way to scan through the duct lengthwise, without making slices section-by-section. Could you please anybody help me on this as it is very important for me.
Thank you, Sue
Old   September 30, 2005, 18:54
Default Re: TECPLOT
Mani
It is quite simple in the case of a structured grid. Are you using a structured grid with one of the (i,j,k) coordinates along the duct axis? Or is your grid unstructured?
If it is a single structured block, you can make use of "Animate" in the "Tools" menu.
Old   October 1, 2005, 13:23
Default Re: TECPLOT
Sue
It was what I wanted. Thank you very much.
Sue
Importing contour maps into Tecplot jcostex Tecplot 1 May 20, 2009 13:48
Problem Exporting to Tecplot Craig FLUENT 2 July 16, 2008 00:21
How to read tecplot file witout tecplot ? Pol Tecplot 11 March 2, 2007 07:26
Using Tecplot for contours display david FLUENT 2 August 23, 2005 23:37
Tecplot can't read data file from Fluent. stephen FLUENT 8 November 21, 2001 21:27
