Home > Forums > Visualization & Post-Processing Software > Tecplot
3D plot in tecplot
Old   May 17, 2023, 04:38
Default 3D plot in tecplot
gokul
gokulbr4 is on a distinguished road
I have simulated a 3D model and the solution file is in the format of .txt file. I imported the txt file into the tecplot and gave 3d cartesian when a dialog box pops up. The problem is I am not able to see my domain or my object when I imported the solution file. When contour is checked in then also I didnt get any contours. Once the vector is check and changed the colour to multi in the zone style i can able to see my domain but when I try to slice it I didnt get any change in colour of that particular slice. can anyone help me in solving this problem? Please find the attached images for reference.
gokulbr4 is offline   Reply With Quote
Old   May 17, 2023, 10:44
Nguyen Duy Trong
ndtrong is on a distinguished road
I think you should check the box of mesh first to active the computational domain
ndtrong is offline   Reply With Quote
Old   May 22, 2023, 18:23
Brandon M
Brandon_CFD is on a distinguished road
Are you able to load this data with the newest version of Tecplot 360 2022 R2? If you need additional help, you can contact support@tecplot.com as well!
Brandon_CFD is offline   Reply With Quote
Old   May 30, 2023, 21:34
Scott Fowler
wsfowler is on a distinguished road
The Tecplot 360 & Tecplot Focus text file loaders typically import the data as I-Ordered (just a line). I'm guessing that's what's going on here. In order to draw slices and iso-surfaces through your data you'll need an IJK-Ordered grid.
The easiest method to construct a grid will probably be to use the Data>Create Rectangular Zone tool, then interpolate the values to the new grid using Linear or Inverse-Distance interpolation.
The quality of the result will depend on the IJK dimensions you give when creating the rectangular zone.
If you want to create a 3D grid using the exact XYZ coordinates in your source file, I'd advise that you contact our support team - they can help you import the data using our Python API or otherwise converting your *.txt data to Tecplot format with the additional information required to import as IJK data.
wsfowler is offline   Reply With Quote
Plot Cp with Tecplot output data Archer-Saber Tecplot 1 December 30, 2019 16:38
How to show reference vector plot in Tecplot 360 EX 2015? fruitkiwi Tecplot 2 August 31, 2017 13:37
[swak4Foam] Foam warnings - related to swak4Foam Salam-H OpenFOAM Community Contributions 20 August 2, 2015 16:40
Plot streamline by Tecplot aiqch Tecplot 0 June 15, 2009 21:57
how to plot cylinder in Tecplot Rui Phoenics 1 October 30, 2002 14:19
