Home > Forums > Visualization & Post-Processing Software > Tecplot
How to increase tecplot significant digits?
Old   April 14, 2022, 08:52
Default How to increase tecplot significant digits when setting contour level?
John E
JohnE is on a distinguished road
Hi,guys.
My original data had 12 significant digits if I use fluent to export data with ASCII format.
When I try to set contour level in Tecplot it seem to be limited within 6 significant digits(when I try manual to set levels with 7 significant digits data but the last digit is automatically removed,Please see the figures I upload)?
How can I increase number of significant digits in tecplot setting cotours level, not the legend lables number format.?
Is anyone know how to solve this problem?
Thanks~~~
JohnE is offline   Reply With Quote
Old   April 19, 2022, 22:41
Scott Fowler
wsfowler is on a distinguished road
Tecplot 360 loads and stores data as double precision. So this is a dialog display issue, not a data issue. There is currently no way to change the precision displayed in those fields.
You should be able to see the full precision in the Data>Spreadsheet.
The Write Data as Formatted Text feature has a "Change Variable Format" dialog - so if you're writing to CSV you can specify the precision there.
I hope this helps.
wsfowler is offline   Reply With Quote
Significant digits of variables in CFX Jerry190607 CFX 4 July 13, 2020 13:44
Significant digits of variables in CFX Jerry190607 Main CFD Forum 0 July 8, 2020 15:55
Tecplot 360 2017 Release 2 manohar1487 Main CFD Forum 0 August 28, 2017 03:08
Significant figures / digits to write out HHOS FLUENT 0 October 10, 2013 09:20
How to increase "Limits MaxPreplotZones" in tecplot ztdep Tecplot 0 August 21, 2009 02:33
