March 15, 2022, 05:46 |
Circulation of vortex
Adithya
Rep Power: 5 |
Hello
I am trying to calculate the circulation strength of a vortex. I am unable to do so. The TEcplot page on this calculation says that the integral can be performed if the domain is created. How do I create the domain just around my vortex? Does anybody know of any tutorial link to this procedure? |
March 16, 2022, 13:12 |
Brandon M
Rep Power: 7 |
Hi Adithya_11,
Does this documentation from the User's Manual help to point you in the right direction? Does this video help to show how to visualize the strength of the vortex?: https://www.tecplot.com/2016/07/19/t...-color-cutoff/ If you have further questions, you could also reach-out to support@tecplot.com and they could take a look at your data. -Brandon |
May 17, 2023, 04:40 |
hussain sallar
Rep Power: 6 |
Hi Adithya_11
I am late to this post but I am also facing this same issue i.e I want to draw a rectangular region in Tecplot and calculate the strength of vortices in that desired region. So far I have tried following without any success: I create a rectangular zone through create zone option in the region of interest and then try to perform integration to calculate vorticity in that rectangular zone. If you have found a solution to this problem, I would be thankful if you share the solution with me. Best Regards, |
Disappearing drain vortex | lasherwc | OpenFOAM Running, Solving & CFD | 9 | July 1, 2020 17:15 |
Vortex or Circulation Region at the outlet or opening | tomage | CFX | 2 | December 30, 2013 08:31 |
Presenation of vortex strength and velocity concept? | fruitkiwi | Main CFD Forum | 0 | September 26, 2012 23:08 |
vortex cause pressure gradient or pressure gradient induce vortex? | fruitkiwi | Main CFD Forum | 4 | June 12, 2012 02:12 |
Vortex Lattice Method: Calculating lift using circulation from vortex ring elements | black&gold | Main CFD Forum | 11 | June 27, 2011 00:51 |
