July 7, 2015, 12:53 |
Solution Time in Tecplot
Adnan
Rep Power: 14 |
Hello all,
I am trying to create an animation in Tecplot and want to display the solution time. I read in one of the discussion forums to enter the following to display the time: &(SOLUTIONTIME). My concern is that this has 15 digits after the decimal point. I do not want so many significant figures in the simulation time display. Does anybody know a way to reduce this or a better way to display the time in the animation? Thanks Adnan |
July 8, 2015, 14:14 |
Scott Rumage
Rep Power: 17 |
The Tecplot user manual is your best reference for this question.
For formatting dynamic numbers and text strings refer to Tecplot 360 manual located here: http://download.tecplot.com/360/current/360_users_manual.pdf page 247. Cheers, Scott |
July 9, 2015, 23:58 |
Adnan
Rep Power: 14 |
Thank You very much. That helped to solve the problem.
&(SOLUTIONTIME%.2f) is a good command to use. |
October 25, 2015, 14:51 |
Younis Najim
Rep Power: 13 |
Do you know how to display time in Milliseconds?
October 26, 2015, 18:32 |
Scott Rumage
Rep Power: 17 |
If I understand your question .... Tecplot does not track the units of measurement for a given data set. For example if the velocity = 10, Tecplot does not "know" if that velocity is 10 m/s or 10 ft/min. It is up to the user to know the units, and direct Tecplot when labeling an axis, or performing additional calculations on the data.
Accordingly if time equals 10, that could be 10 years or 10 milliseconds. Scott |
October 29, 2015, 16:43 |
#6 | |
Younis Najim
Rep Power: 13 |
Multiple floating objects | CKH | OpenFOAM Running, Solving & CFD | 14 | February 20, 2019 10:08 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 14:12 |
plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 08:56 |
How to get the solution of last time step? | lzgwhy | Fluent UDF and Scheme Programming | 0 | September 15, 2010 23:23 |
