How to realize these two functions in Tecplot? |
July 8, 2006, 01:25 |
1)I need a arrowhead attached to the 1D XY line to indicate the time advancing direction. But this can only be realized in 2D streamtraces cases.
2)Another problem is related to contour, I want the positive value on the contour to be showed in solid line and negative value to be showed in dashedline, this function is also unavailable in tecplot, it just show all positive and negative value in the same type of line. Anyone know how to solve these two problems? Or are there some other softwares to realize these two functions? Thanks! |
July 8, 2006, 06:16 |
Re: How to realize these two functions in Tecplot?
I have solved the second problem: contour details->lines check dashed negative lines.
How to solve the first one? |
July 21, 2006, 09:06 |
probably I don't understand because I think you can simply make a draw using the tools
Reading Additional Data Quantities from Fluent into Tecplot | fremder | Tecplot | 9 | December 16, 2016 16:35 |
Importing contour maps into Tecplot | jcostex | Tecplot | 1 | May 20, 2009 13:48 |
Using Tecplot for contours display | david | FLUENT | 2 | August 23, 2005 23:37 |
User-Defined Functions | Boisson | FLUENT | 2 | January 18, 2002 23:09 |
Tecplot can't read data file from Fluent. | stephen | FLUENT | 8 | November 21, 2001 21:27 |
