Home > Forums > Software User Forums > SU2
Error occurs after compiling mutation
Old   May 10, 2024, 09:30
Default Error occurs after compiling mutation
Liming Yang
CFDWhite is on a distinguished road
Hello all,
I intend to compute the classical RAMC example using SU2 NEMO+mutation, however, after compiling, the error shown in the figure appears.
It seems that mutation library could not be found, but I have added the following statement to the bashrc file, as shown in Figure 2.
export MPP_DATA_DIRECTORY=$SU2_HOME/subprojects/Mutationpp/data
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$SU2_HOME/<build_dir>/subprojects/Mutationpp
So I'd like to know what the problem is and how to fix it, and thank you in advance for your suggestions.
CFDWhite is offline   Reply With Quote
Old   May 10, 2024, 09:50
bigfoot
bigfootedrockmidget is on a distinguished road
You need to add the path to the Mutationpp directory, so in your case that is:
bigfootedrockmidget is offline   Reply With Quote
Old   May 14, 2024, 06:12
Liming Yang
Originally Posted by bigfootedrockmidget View Post
I have added the relevant statement, as shown in the red box, but unfortunately there are still errors.
Another question, does SU2 have AIR-7 in its chemical reaction library to accurately calculate RAMC?
Thank you for any suggestions.
Old   May 14, 2024, 07:10
bigfoot
Please check if the mutation library is actually in that subdirectory.
Old   May 15, 2024, 04:09
Liming Yang
I checked the folder, and I did see it as shown in the figure
Old   May 15, 2024, 06:33
bigfoot
and is the .so file in that folder as well?
Old   May 27, 2024, 05:31
Liming Yang
Sorry. I'm not sure what is the .so file that does not appear to be in this folder
Old   May 28, 2024, 17:42
bigfoot
You need to find out where the file libmutation__.so is and point LD_LIBRARY_PATH to that location.
so if the mutation__.so file is in the subfolder lib, you add it to LD_LIBRARY_PATH
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$SU2_HOME/subprojects/Mutationpp:$SU2_HOME/lib/
olaFlow - Errors in compiling and tutorial running GrivalszkiP OpenFOAM Running, Solving & CFD 1 October 14, 2020 18:50
Getting error both interpreting and compiling serene6390 Fluent UDF and Scheme Programming 1 October 27, 2017 01:49
All files present. but solver not compiling saddy OpenFOAM Programming & Development 1 July 29, 2017 10:50
[OpenFOAM.org] Trouble Compiling OpenFOAM-dev using Intel Compiler 15 for use on Xeon Phi foamer123 OpenFOAM Installation 9 August 20, 2015 15:03
Help with KIVA4 source code compiling geothokar Main CFD Forum 0 September 3, 2010 06:40
