April 18, 2024, 13:30 |
Error: USING_UQ: invalid option name.
Federico Vegetti
Rep Power: 2 |
Hi everyone,
I'm doing my master thesis about the fidelity of unsteady RANS with uncertainty on the turbulence model. Looking at the tutorial of SU2 ''Epistemic Uncertainty Quantification of RANS predictions of NACA 0012 airfoil'' (https://su2code.github.io/tutorials/UQ_NACA0012/) I tried to run the test case but this error appears: Line 50 USING_UQ: invalid option name. Check current SU2 options in config_template.cfg. It seems that SU2 doesn't recognise this option, I followed all the passages of the SU2 test but I don't understand why I get this error. Could anyone help me please? Thank you in advice. |
April 18, 2024, 15:02 |
bigfoot
Rep Power: 21 |
This option is now merged with the other SST options: Code:
SST_OPTIONS= UQ I will change it in the tutorial description. |
April 18, 2024, 15:09 |
Federico Vegetti
Rep Power: 2 |
Thanks a lot!
Now it's working. |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 17, 2020 00:44 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 06:37 |
Simple piston movement in cylinder- fluid models | arun1994 | CFX | 4 | July 8, 2016 03:54 |
Low torque values on Screw Turbine | Shaun Waters | CFX | 34 | July 23, 2015 09:16 |
Compression stoke is giving higher pressure than calculated | nickjuana | CFX | 62 | May 19, 2015 14:32 |
