March 22, 2024, 22:24 |
#21 | |
AN
Rep Power: 2 |
March 24, 2024, 17:12 |
#22 |
Catarina Garbacz
Rep Power: 6 |
Yes, this branch is much slower and it dates back a couple years and is not up to date with recent performance developments. We are currently working on bringing this fix to develop branch.
This said, it should work in parallel. It could be a problem with your compilation. If you provide me with the *exact* commands you used, I can check it anything is off |
March 24, 2024, 21:41 |
#23 | |
AN
Rep Power: 2 |
I looked at the instructions on the SU2 official website, should I set Dwith-mpi=enabled? Are there any other options I need to set? |
March 24, 2024, 23:30 |
#24 | |
AN
Rep Power: 2 |
March 24, 2024, 23:45 |
#25 | |
AN
Rep Power: 2 |
Main binary: C:\Users\35014\AppData\Local\Programs\Python\Pytho n38\python.exe Build Options: -Dwith-mpi=enabled Python system: Windows The Meson build system Version: 0.54.999 Source dir: C:\Users\35014\Desktop\SU2\SU2\SU2-NEMO_AUSMPLUSM_Rollback Build dir: C:\Users\35014\Desktop\SU2\SU2\SU2-NEMO_AUSMPLUSM_Rollback\buildmpi Build type: native build Using 'PKG_CONFIG_PATH' from environment with value: 'C:\\msys64\\mingw64\\lib\\pkgconfig' Using 'PKG_CONFIG_PATH' from environment with value: 'C:\\msys64\\mingw64\\lib\\pkgconfig' Project name: SU2 Project version: 7.0.8 "Blackbird" None of 'CC' are defined in the environment, not changing global flags. None of 'CFLAGS' are defined in the environment, not changing global flags. None of 'LDFLAGS' are defined in the environment, not changing global flags. None of 'CPPFLAGS' are defined in the environment, not changing global flags. None of 'CC_LD' are defined in the environment, not changing global flags. Sanity testing C compiler: gcc Is cross compiler: False. None of 'CC_LD' are defined in the environment, not changing global flags. Sanity check compiler command line: gcc C:\Users\35014\Desktop\SU2\SU2\SU2-NEMO_AUSMPLUSM_Rollback\buildmpi\meson-private\sanitycheckc.c -o C:\Users\35014\Desktop\SU2\SU2\SU2-NEMO_AUSMPLUSM_Rollback\buildmpi\meson-private\sanitycheckc.exe -pipe Sanity check compile stdout: ----- Sanity check compile stderr: ----- Running test binary command: C:\Users\35014\Desktop\SU2\SU2\SU2-NEMO_AUSMPLUSM_Rollback\buildmpi\meson-private\sanitycheckc.exe C compiler for the build machine: gcc (gcc 8.1.0 "gcc (x86_64-win32-seh-rev0, Built by MinGW-W64 project) 8.1.0") C linker for the build machine: gcc ld.bfd 2.30 None of 'AR' are defined in the environment, not changing global flags. None of 'CXX' are defined in the environment, not changing global flags. None of 'CXXFLAGS' are defined in the environment, not changing global flags. None of 'LDFLAGS' are defined in the environment, not changing global flags. None of 'CPPFLAGS' are defined in the environment, not changing global flags. None of 'CXX_LD' are defined in the environment, not changing global flags. Sanity testing C++ compiler: c++ Is cross compiler: False. None of 'CXX_LD' are defined in the environment, not changing global flags. Sanity check compiler command line: c++ C:\Users\35014\Desktop\SU2\SU2\SU2-NEMO_AUSMPLUSM_Rollback\buildmpi\meson-private\sanitycheckcpp.cc -o C:\Users\35014\Desktop\SU2\SU2\SU2-NEMO_AUSMPLUSM_Rollback\buildmpi\meson-private\sanitycheckcpp.exe -pipe Sanity check compile stdout: ----- Sanity check compile stderr: ----- Running test binary command: C:\Users\35014\Desktop\SU2\SU2\SU2-NEMO_AUSMPLUSM_Rollback\buildmpi\meson-private\sanitycheckcpp.exe C++ compiler for the build machine: c++ (gcc 8.1.0 "c++ (x86_64-win32-seh-rev0, Built by MinGW-W64 project) 8.1.0") C++ linker for the build machine: c++ ld.bfd 2.30 None of 'CC' are defined in the environment, not changing global flags. None of 'CFLAGS' are defined in the environment, not changing global flags. None of 'LDFLAGS' are defined in the environment, not changing global flags. None of 'CPPFLAGS' are defined in the environment, not changing global flags. None of 'CC_LD' are defined in the environment, not changing global flags. Sanity testing C compiler: gcc Is cross compiler: False. None of 'CC_LD' are defined in the environment, not changing global flags. Sanity check compiler command line: gcc C:\Users\35014\Desktop\SU2\SU2\SU2-NEMO_AUSMPLUSM_Rollback\buildmpi\meson-private\sanitycheckc.c -o C:\Users\35014\Desktop\SU2\SU2\SU2-NEMO_AUSMPLUSM_Rollback\buildmpi\meson-private\sanitycheckc.exe -pipe Sanity check compile stdout: ----- Sanity check compile stderr: ----- Running test binary command: C:\Users\35014\Desktop\SU2\SU2\SU2-NEMO_AUSMPLUSM_Rollback\buildmpi\meson-private\sanitycheckc.exe C compiler for the host machine: gcc (gcc 8.1.0 "gcc (x86_64-win32-seh-rev0, Built by MinGW-W64 project) 8.1.0") C linker for the host machine: gcc ld.bfd 2.30 None of 'AR' are defined in the environment, not changing global flags. None of 'CXX' are defined in the environment, not changing global flags. None of 'CXXFLAGS' are defined in the environment, not changing global flags. None of 'LDFLAGS' are defined in the environment, not changing global flags. None of 'CPPFLAGS' are defined in the environment, not changing global flags. None of 'CXX_LD' are defined in the environment, not changing global flags. Sanity testing C++ compiler: c++ Is cross compiler: False. None of 'CXX_LD' are defined in the environment, not changing global flags. Sanity check compiler command line: c++ C:\Users\35014\Desktop\SU2\SU2\SU2-NEMO_AUSMPLUSM_Rollback\buildmpi\meson-private\sanitycheckcpp.cc -o C:\Users\35014\Desktop\SU2\SU2\SU2-NEMO_AUSMPLUSM_Rollback\buildmpi\meson-private\sanitycheckcpp.exe -pipe Sanity check compile stdout: ----- Sanity check compile stderr: ----- Running test binary command: C:\Users\35014\Desktop\SU2\SU2\SU2-NEMO_AUSMPLUSM_Rollback\buildmpi\meson-private\sanitycheckcpp.exe C++ compiler for the host machine: c++ (gcc 8.1.0 "c++ (x86_64-win32-seh-rev0, Built by MinGW-W64 project) 8.1.0") C++ linker for the host machine: c++ ld.bfd 2.30 Build machine cpu family: x86_64 Build machine cpu: x86_64 Host machine cpu family: x86_64 Host machine cpu: x86_64 Target machine cpu family: x86_64 Target machine cpu: x86_64 Program python3 found: YES (C:\Users\35014\AppData\Local\Programs\Python\Pyth on38\python.exe) Pkg-config binary for MachineChoice.HOST is not cached. None of 'PKG_CONFIG' are defined in the environment, not changing global flags. Pkg-config binary missing from cross or native file, or env var undefined. Trying a default Pkg-config fallback at pkg-config Trying pkg-config binary pkg-config for machine MachineChoice.HOST at ['C:\\msys64\\mingw64\\bin\\pkg-config.EXE'] Found pkg-config: C:\msys64\mingw64\bin\pkg-config.EXE (0.29.2) Determining dependency 'ompi-c' with pkg-config executable 'C:\\msys64\\mingw64\\bin\\pkg-config.EXE' PKG_CONFIG_PATH: C:\msys64\mingw64\lib\pkgconfig Called `C:\msys64\mingw64\bin\pkg-config.EXE --modversion ompi-c` -> 1 mpicc binary missing from cross or native file, or env var undefined. Trying a default mpicc fallback at mpicc mpicc found: NO Run-time dependency MPI for c found: YES Pkg-config binary for MachineChoice.HOST is cached. Determining dependency 'ompi-cxx' with pkg-config executable 'C:\\msys64\\mingw64\\bin\\pkg-config.EXE' PKG_CONFIG_PATH: C:\msys64\mingw64\lib\pkgconfig Called `C:\msys64\mingw64\bin\pkg-config.EXE --modversion ompi-cxx` -> 1 mpic++ binary missing from cross or native file, or env var undefined. Trying a default mpic++ fallback at mpic++ Trying a default mpic++ fallback at mpicxx Trying a default mpic++ fallback at mpiCC mpic++ found: NO Run-time dependency MPI for cpp found: NO (tried pkgconfig and config-tool) meson.build:38:2: ERROR: Dependency "mpi" not found, tried pkgconfig and config-tool This is my meson.log. |
March 25, 2024, 03:42 |
#26 |
AN
Rep Power: 2 |
It looks like there's something wrong with msmpi. But I don't know how to solve it.
March 25, 2024, 09:33 |
#27 |
Catarina Garbacz
Rep Power: 6 |
so the mpi features are not being found, as per the log file:
HTML Code:
mpicc binary missing from cross or native file, or env var undefined.Trying a default mpicc fallback at mpiccmpicc found: NORun-time dependency MPI for c found: YESPkg-config binary for MachineChoice.HOST is cached.Determining dependency 'ompi-cxx' with pkg-config executable 'C:\\msys64\\mingw64\\bin\\pkg-config.EXE'PKG_CONFIG_PATH: C:\msys64\mingw64\lib\pkgconfigCalled `C:\msys64\mingw64\bin\pkg-config.EXE --modversion ompi-cxx` -> 1mpic++ binary missing from cross or native file, or env var undefined.Trying a default mpic++ fallback at mpic++Trying a default mpic++ fallback at mpicxxTrying a default mpic++ fallback at mpiCCmpic++ found: NORun-time dependency MPI for cpp found: NO (tried pkgconfig and config-tool)meson.build:38:2: ERROR: Dependency "mpi" not found, tried pkgconfig and config-tool which mpicc which mpicxx then add those paths to the bashrc file and source it. export MPICC=<path_to_mpicc> export MPICXX=<path_to_mpicxx> |
March 26, 2024, 04:38 |
#28 | |
AN
Rep Power: 2 |
March 26, 2024, 04:48 |
#29 | |
AN
Rep Power: 2 |
I want to transport the AUSMPW scheme in this branch to 8.0.0 code and then compile it, but I am afraid that this branch code is different from 8.0.0 more than AUSMPW scheme, so I want to make sure about this. |
March 26, 2024, 08:22 |
#30 |
Catarina Garbacz
Rep Power: 6 |
1- it's AUSMPLUSM as per the name of the branch, not AUSMPW
2- if you're only able to run it in serial, yes of course it will be very slow, but this is not a problem in the code, but in the compilation you did. The only way I can help with that is perhaps to have an online meeting where I can try and compile the code with you 3- the models are the same yes, but there are structural differences in the way they are implemented. so you cannot simply "copy paste". you'd have to dedicate a bit of time to understand those differences and how to do this correctly |
March 26, 2024, 09:17 |
#31 | |
AN
Rep Power: 2 |
March 26, 2024, 09:24 |
#32 |
AN
Rep Power: 2 |
I have successfully compile mpi mode in linux, and I set mpiexec -np 4, it is a little faster, but the improvement is not very significant. The speed has increased by about 15%. Is this normal?
March 26, 2024, 09:55 |
#33 | |
Catarina Garbacz
Rep Power: 6 |
It depends on how many cores you're using. in any case, it is known that previous versions are slower, the only thing you can do is use more cores |
March 26, 2024, 10:09 |
#34 |
Catarina Garbacz
Rep Power: 6 |
reference for AUMSPLUSM
"Impact of Anisotropic Mesh Adaptation on the Aerothermodynamics of Atmospheric Reentry" - Fábio Morgado, Catarina Garbacz and Marco Fossati |
March 28, 2024, 03:30 |
#35 |
Liming Yang
Rep Power: 3 |
Hello, what additional things did you do to compile successfully? My compilation process didn't report any errors, but it didn't seem to work with mpi.
March 28, 2024, 08:18 |
#36 |
Liming Yang
Rep Power: 3 |
One more question, do you remember the shock position of your original calculation? Have you compared relative physical quantities such as shock position and component mass fraction? Thank you in advance for your answers
March 28, 2024, 09:41 |
#37 |
Catarina Garbacz
Rep Power: 6 |
about compilation, I do the following steps:
./meson.py <build_folder> --prefix = <path_to_su2> -Denable-mpp=True -Dwith-mpi = enabled ./ninja -C <build_folder> install I add the following lines to the bashrc file: export SU2_RUN=<path_to_su2>/bin export SU2_HOME=<path_to_su2> export PATH=$PATH:$SU2_RUN export PYTHONPATH=$PYTHONPATH:$SU2_RUN export MPP_DATA_DIRECTORY=$SU2_HOME/subprojects/Mutationpp/data export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$SU2_HOME/build/subprojects/Mutationpp the point is: your compilation seems to be correct but it seems that mpi is not being found in your machine. You need to check the meson.log again and see if MPICC and MPICXX are found. If these are NOT found, mpi will not work... so that's the one thing you need to address, it seems. in my case, to address that, I also added to the bashrc file: export MPICC=/usr/bin/mpicc export MPICXX=/usr/bin/mpicxx about the questions on the paper, sorry but this has been done some time ago and I'm not first author, so I'd say the only information we have available at the moment is what you can find in the paper. |
April 16, 2024, 07:02 |
#38 | |
AN
Rep Power: 2 |
Thanks for your help some days ago. I carefully read the rollback code and found a lot of different places, including the AUSMPLUSM function to calculate the conv flux residual, the implementation of farfield, sym plane, supersonic outlet and isothermal-noncatalytic wall boundary conditions. I think I've got almost everything right, but there are still a few things I'm not very sure. One of my puzzles is h_k or h in AUSMPLUSM scheme, which is called the pressure sensor. I set "ITER=1" and tried using "cout<<h_k;" to print h_k in rollback and h_k in 8.0.0 on the same grid. To my surprise, there was a noticeable difference. |
April 16, 2024, 07:07 |
#39 | |
AN
Rep Power: 2 |
3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback 3.25229e-316:this is h_k in rollback Simulation Run using the Single-zone Driver 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 1:this is h in 8.0.0 |
April 16, 2024, 07:17 |
#40 |
AN
Rep Power: 2 |
I used "cout" on the 5*5 grid of thermal bath example, h is 1 in 8.0.0, which is agreed with my expectation, because the initial field is given by the free stream condition, the pressure at all points on the grid is the same, so h is 1, but why is it close to 0 in rollback?
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 19:02 |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 11:20 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 12:19 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
